03-22-2008, 12:19 PM | #23 |
23
Rep 207
Its confusing me, why does it transfer the track names to the idrive?? It doesnt transfer the tracks, I wonder if its just to speed up the menus?
The idrive must have a small hard drive if it can only remember 20,000 track names. |
03-22-2008, 12:55 PM | #24 | |
1er
73
Rep 1,205
@ 128K MP3/AAC = 80GB @ 320K MP3/AAC = 250GB @ 800K lossless (cd quality) = 500GB Using about 4 minutes for an average track, which might be a little on the short side depending on your audio collection. FWIW on my friends car system I can't distiguish between 320KBps and lossless, but on my home stereo I can if I hear them one after the other, but the difference is small and only in certain parts. If I hear something for the first time, I can't tell right away even on my home stereo if it is 320 vs. lossless. |
03-22-2008, 01:46 PM | #25 |
Rep 255
There is the:
Ipod and USB adapter for $400 Ipod Interface adapter for $320 Im not getting the Nav system so I wont have a nice screen to use. Anyone with the ipod and no nav want to tell me how they view songs and navigate? I ordered my car but have a week or so to change it. What exactly do these options do? Is the interface adapter just for the nav system? I also have an 8gig flash drive with all my songs on it. What do you think would be easier to use? |
03-22-2008, 04:43 PM | #26 |
TT > i-vtec
Rep 35
I just learned on my test drive today that the iDrive also plays video files from your iPod or usb device. That's so awesome! Although it's illegal, I have a Pioneer avic DIN and set it up to play video while I drive. I know what you will all say. It's not the safest idea, but it sure does help when I'm stuck in stop and go traffic for an hour.
03-22-2008, 10:16 PM | #27 | |
Rep 645
03-22-2008, 11:09 PM | #28 | |
Rep 104
It makes sense in a way: BMW doesn't want to be seen to support just one type of MP3 player, and this cable can *only* be used with an iPod, while the USB interface works with many devices. There is also a bit of circuitry in that box - it's not just a simple USB-Dock Connector cable. Regards, Paul Martin |
03-22-2008, 11:10 PM | #29 | |
Rep 104
If you are playing a video file on the iPod and then you plug it into the USB adapter in the car it will continue to play the audio but you're not going to see any video on the screen I can assure you. Sorry to burst the bubble. Paul Martin |
03-22-2008, 11:14 PM | #30 | |
Rep 104
If you have the iPod interface adapter (the old one) is a way of interfacing the iPod with the cars radio so that it 'sees' a 6 stack CD player. You have to create special 'BMW Playlists' in iTunes to use the system and it isn't that great. Also, if you want a CD stacker, then you'll have to choose this OR the iPod - you can't have both (unless you have the 6FL option, as above). I hope this is of some use. Cheers, Paul Martin |
03-23-2008, 12:51 AM | #31 | |
Rep 1,597
Oh well, I suppose it's for the best..
03-23-2008, 08:59 PM | #32 |
TT > i-vtec
Rep 35
No bubble bursted here. I assumed that I wouldn't be able to watch while driving like I do now. But just knowing that it will play video even while still is a nice function. Where I'm not accustomed to navigation systems, I was wondering if the dvd-rom will play dvd video. Anyone know?
03-23-2008, 10:13 PM | #33 | |
Rep 104
There is an OEM accessory module which allows TV playback in the 1er (and possibly video input), but it is not factory fitted. Have a look for the accessories catalog. Paul |
03-23-2008, 10:46 PM | #34 |
Rep 1,597
Hooray! There is a light at the end of the tunnel! Thank you for the information :thumbup:
03-23-2008, 10:55 PM | #35 | |
Rep 104
03-23-2008, 11:26 PM | #36 |
Rep 1,657
if you order the ipod/usb option in the US, can it play the songs from your ipod if you don't use playlists?
I'm disappointed that you still have to use the aux jack. it means you're not getting a digital sound. |
03-23-2008, 11:54 PM | #37 | ||
Rep 104
At some point the signal HAS to be analog. Either the iPod does the conversion or the car's headunit does - and it's not going to make a difference which one does it I can assure you! The advantage of the iPod doing the conversion is that all the DRM music purchased from the ITMS can be viewed and played without any issues. ...and let's not get into the whole analog-digital debate - there are plenty of better places to discuss that! If you want that discussion, I'm not going to get involved. Regards, Paul |
03-24-2008, 01:28 AM | #38 | |
Rep 1,657
03-24-2008, 02:48 AM | #39 | |
Rep 104
http://www.ipodlinux.org/Dock_Connector The cable that BMW sells for use with the 6FL option splits the dock connector into a data control and power stream (ie. the USB port) and line-out audio stream (ie. the 3.5mm stereo jack). The only way that the 'audio' can travel over via the USB port is if the iPod is being used as a mass storage device (standard USB-dock cable PLUS it must be PC formatted). If this is the case, then you cannot play the protected AAC files with ANY externally connected device (apart from the computer it is paired with). I hope that clears things up! Regards, Paul |
03-24-2008, 09:52 AM | #40 |
Rep 1,597
Thank you for all your information on this topic Paul!
03-24-2008, 01:47 PM | #41 | |
1er
73
Rep 1,205
I did some research and Harman uses the exact same Wolfson DAC in some of their components, so it is very possible you are using the exact same DAC either way. If anything, I would guess the iPod is superior as I have doubts that Harman builds the boards in the HiFi or base system. |
03-24-2008, 01:50 PM | #42 | |
1er
73
Rep 1,205
03-24-2008, 02:05 PM | #43 |
Rep 7,594
Drives: '19 M2C
The only way to get digital to digital music on the 1er is to plug a flash drive into the USB port in the car.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
03-24-2008, 03:13 PM | #44 |
1er
73
Rep 1,205
