06-06-2009, 01:16 PM | #1 |
26
Rep 221
Starting my audio project today.
Well, I think I know what I am going to do. I just placed an order for an AudioControl LC6i and two SWS-8x (4ohm) subs. Next, I am looking for the best deal I can find for an Alpine PDX-5 amp. My girlfriend works for a company who has a vendor that sells them Alpine products, so I am going to see if she can get me a deal.
I plan to keep the factory components in front and back, and see how they sound with more power pushing them. I really don't have any complaints about them now, but the car has so little low-end, something has to be done. I have the non-logic7 hi-fi, btw. |
06-06-2009, 02:07 PM | #2 | |
Rep 13,018
06-06-2009, 08:04 PM | #4 |
26
Rep 221
BTW, do you know where I can get a wiring diagram, Technic? I want to try and make the install as easy as possible, so I need to know which wires are which. Ideas?
06-07-2009, 09:15 AM | #5 | |
Rep 13,018
06-07-2009, 10:19 AM | #6 | |
26
Rep 221
I can't wait for the parts to get here... |
06-08-2009, 04:19 AM | #7 |
Rep 914
You're doing a similar install as me. I've just successfully installed an LC6i and PDX-5 and for the timebeing am running the OEM HiFi speakers. I'm on my second PDX-5 as the first one I bought was faulty.
The levels on the LC6i have to be turned up fairly high as the signal from the HU is not as strong as a speaker level signal which is primarily what the LC6i is designed to accept. Also it may be better to reverse the inputs on the LC6i as normally it will take the signal from the rear inputs and duplicate to create rear and sub outputs (the PDX-5 requires front/rear/sub inputs to work properly). If connected up the standard way and you fade to the front then the subs will be faded out also which you do not want. The sound is obviously much louder and I'm surprised how well the OEM components stand up to the extra power. The subs though are stretched and can't really cope at anything above mid volume. I've got a pair of SWS 8x subs ready to go in as well as Focal KRS100 components up front. Just need to find the time to install them... |
06-08-2009, 06:07 AM | #8 | |
Rep 13,018
06-08-2009, 07:25 AM | #10 |
Rep 13,018
Thanks...
Although the LC6i works in this OEM HU/HiFi setup the Matrix is the better device for this application, as the signal that need to be processed is a low level signal (albeit a high voltage signal). So what is really needed is a line driver and not a line converter... |
06-08-2009, 08:06 AM | #11 |
Rep 914
I thought the LC6i was both a line driver and line converter?
http://www.audiocontrol.com/t34/1761...tegration.html Either way, it works flawlessly. |
06-08-2009, 09:39 AM | #12 | |
Rep 13,018
The Matrix is a plain line driver -no level converter- so it is perfect for "drive up" a low level signal as it is input, no attenuation anywhere. So it is more efficient in this particular application. The only benefit of the LC6i over the Matrix is its wire inputs, as the Matrix require RCA plugs. So connection to the OEM HU outputs is straight forward. |
06-09-2009, 10:30 PM | #13 |
26
Rep 221
Interesting stuff, although I can honestly say about half of it is greek to me. The subs will be here tomorrow, so I will be installing them myself. The amp will be here Friday, and I am having a reputable local shop do the wiring/install of LC6i and amp/tuning. These guys have all the mic's and digital media needed to properly tune the system so I figured I would leave that part up to them.
I just hope they will be able to tune the factory component speakers to get all the ranges neccessary. I don't want to have to upgrade to aftermarket mids/highs. I guess only time will tell, and when I hear the car on saturday I will know for sure. |
06-10-2009, 05:36 AM | #14 | |
Rep 13,018
06-10-2009, 06:39 AM | #15 | |
Rep 914
06-10-2009, 05:44 PM | #17 |
57
Rep 2,251
NICE! Let us know how it sounds when you get it all installed!
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
06-14-2009, 06:02 PM | #18 |
26
Rep 221
Well, everything is done and i sounds great! Its wonderful to be able to hear a full range of sounds again, especially the lows. The subs are very cean, yet can be very powerful considering what they are. I had a local shop called Sounds Good To Me install the amp and LC6i and tune the system. They did an amazing job and I love where they put the amp.
The only issue I have at this point is that I can hear a faint (very faint, but the car drives so quiet its easy to hear) static sound coming from all of the speakers, even when the head unit is turned off. My guess is that this is because even with the head unit off, the amp is still switched to on. I noticed that the amp comes on everytime the car 'wakes up' which is pretty much anytime you open a door or do anything that the car can sence. I need to find a correction to this problem, maybe it's as simple as finding a different source for the amp remote cable? |
06-14-2009, 08:00 PM | #19 |
26
Rep 221
Well, I have verified that the amp remote is the small black cable from the stock wiring harness, which is the OEM remote. It is just strange that I can hear the faint hissing of the speakers whenever the amp is on. I tried looking to see if this was a problem of too much amp gain, but I don't even see an amp gain adjusment on the PDX-5. Hmm.
06-14-2009, 08:31 PM | #20 |
26
Rep 221
Ok, well I found the removable panel to adjust the gain. All my gains were on minimum. When you turn them up, it defiantely makes the hissing problem worse. The only gain I adjudsted was for the subs. I brought that up to about 1/4 turn, if that. That way I can have a little bit more bass when I really want it. That did not affect the hiss, as it is only coming out of the door speakers.
Maybe this is just something I didn't notice before and am just paying attention to now. When the system first boots, I can hear the slight beeping and spinning of the CD-player starting in the speakers, with a louder hiss. After a couple seconds, the beeping disappears and the hiss becomes the faint hiss I described above. I does not affect the performance of the system, it is just kind of a nuisance when I want it quiet in the car. |
06-15-2009, 08:06 AM | #22 |
Rep 914
I have no hiss on my system and I have the following settings:
- LC6i gains about 80% - PDX-5 gains at minimum - LC6i ground isolation: Isolated I have taken the OEM remote wire and used that as remote turn on for the LC6i rather than signal sensing. Then I have utilised the remote out from there to the PDX-5. The LC6i should be shipped as new with the ground isolation jumpers set to the isolated position although it's probably worth double checking this. The other options are 200 ohm or ground. |
