~DIY: $130 Rear View Camera with OEM integration (vendors will hate me)~
12-09-2014, 01:13 PM | #67 |
Bad Driver
58
Rep 392
So is this possible to do if I have CIC (not retrofitted) and no PDC?
By reading through the thread, it looks like I must buy the PDC module also? But no one is sure if this will work? |
12-12-2014, 11:23 AM | #68 | |
689
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
you should just unlock your cic vin so you don't need the emulator for it to work and then retrofit the back up camera and use emulator for that.... if anyone is interested in unlocking their CIC I have a great guy that can do it in 15 min remotely no matter where you are located!!! just pm me for details!!
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
12-12-2014, 02:19 PM | #69 |
689
Rep 2,719
Drives: M3
oh nice, so you just tapped into the existing wires and didn't even have to bypass them... that's awesome! no cutting just stripped and soldered those onto existing wires right?
12-14-2014, 08:40 PM | #71 |
Rep 1,527
I just attempted to code this retrofit for a customer and all was successful until he tried to OP's check. The CIC screen pops up (just a black screen), but there's no image from the camera. All connections were checked. Any ideas...
Edit: Wasn't getting a power source from CIC. Ran power directly from battery and camera now works. BUT... No CD/DVD playback... Says invalid format. |
12-28-2014, 09:54 PM | #72 |
Rep 1,527
I didn't see a response to cover this, but PDC is "NOT" required. The car I mentioned above doesn't have PDC (front or rear). It was wired just like the OP covered, except camera is drawing power directly from battery.
12-29-2014, 04:33 PM | #73 |
Rep 655
so I got all the parts, took me 5 months to start the installation, handle installed, and when I have removed the Navi I noticed that mine looks different and cables are also different colors plus I don't have any numbers on the black connector so not sure where the new cables should slide. Anyone can help me here, will try to attach some pictures to this
01-03-2015, 12:00 PM | #75 | |
60
Rep 227
01-04-2015, 11:31 AM | #76 |
17
Rep 194
I think any harness like that one will do the job, I've found a couple others here
http://www.ebay.co.uk/itm/1209771965...%3AMEBIDX%3AIT http://www.ebay.co.uk/itm/2515753317...%3AMEBIDX%3AIT Just means you can splice into the harness wires instead of the cars wiring to keep everything original and undamaged should you decide to remove etc. The one in the link you mentioned doesn't ship to the UK so I'm going for one of the two I've linked instead, hopefully the fit will be good as i have had ISO connectors in the past which haven't fitted brilliantly so fingers crossed. |
01-04-2015, 01:39 PM | #77 | |
Rep 1,068
01-04-2015, 01:41 PM | #78 |
Rep 1,068
Very good news. I dont want pdc just a backup camera. Ill need to likely remove my cic emulator to make this work though?
01-05-2015, 10:58 PM | #79 | ||
60
Rep 227
'11 LBM E90 335i M-Sport (Current)
'12 AWP II MDX Tech (Hers) '07 NBP TL Type-S 6MT (Sold) "From a Lifesaver to a Soulsaver" <-- Click |
01-06-2015, 09:44 PM | #80 |
Rep 1,031
Drives: 335 E92 DCT
Hoping someone can chime in a help me out here.
I've had all the components install, Camera, emulator and coded successfully. But I'm stuck at a hurdle. I can't figure out what I'm doing wrong here. The wires for the reverse camera at the back doesn't seem like its getting power perhaps at the correct connection points.
Certified Australian
01-06-2015, 10:19 PM | #81 |
Rep 1,857
That wire is suppose to power the camera when you put the car into reverse. Don't connect the camera directly to the battery, you DON'T want it powered on all the time.
01-06-2015, 10:23 PM | #82 | |
Rep 1,857
Has anyone used this cable yet???
01-06-2015, 10:34 PM | #83 | |
689
Rep 2,719
Drives: M3
01-06-2015, 11:23 PM | #84 |
48
Rep 376
01-07-2015, 02:24 AM | #85 | |
Rep 1,031
Drives: 335 E92 DCT
But there is still that one single RED wire? where the hell does it go? I'm not sure what I'm doing wrong here Where did you connect the following wires as pictured in my previous post??? HELP! Thanks
01-07-2015, 08:22 AM | #86 |
Rep 1,857
According to the ebay seller, it works with both CIC and CCC.
01-07-2015, 08:23 AM | #87 | |
Rep 1,857
Did you connect the other end to the white wire coming out of the emulator? Re-read step 5.
01-07-2015, 01:49 PM | #88 | |
Pura Vida
13
Rep 297
reverse camera |
