07-29-2015, 05:13 PM | #67 | |
Rep 1,481
I have not tried the other ones you mention, but if they work on the F3x they should also work on the F8x.
2015 Mineral Grey ///M4 6MT
07-29-2015, 05:16 PM | #68 | |
Rep 3,834
Daily: G12 750 MSPORT Weekend Car: E90 M3
07-29-2015, 05:22 PM | #69 | |
10
Rep 106
07-29-2015, 05:29 PM | #70 |
Rep 1,481
I assume you set FEM_BODY > CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK to "aktiv"? Did you try going back to check if your coding stuck? Also, keep in mind that coding changes may require a bit of time to take effect.
07-30-2015, 09:21 PM | #71 | |
10
Rep 106
Perhaps listing options of test cars would be a good idea. And there are some things that I think we can reasonably assume are not package dependent. Like unlock on engine off or changing number of turn signal blinks. |
07-30-2015, 09:24 PM | #72 | |
10
Rep 106
Unfortunately a lot of the other stuff I tried still isn't working, and at the time I did go back to see if the coding stuck. I'll be spending more time this weekend playing with it. |
07-30-2015, 10:04 PM | #73 | ||
Rep 3,834
07-31-2015, 11:28 AM | #74 | |
10
Rep 106
Sorry to split hairs here, I just feel like you're making it sound like I'm being ungrateful, when really this seems to just be a misunderstanding. |
07-31-2015, 12:27 PM | #75 | ||
Rep 3,834
08-04-2015, 10:40 PM | #76 |
Rep 3,834
Updated thread with VO Coding instruction for Euro LED Headlight coding (anti-dazzle). I coded this for the X5M and a few F80s, works beautifully.
08-05-2015, 09:34 AM | #78 | |
Rep 3,834
09-29-2015, 09:38 PM | #80 |
127
Rep 357
So I thought I coded the Euro anti-dazzle on my LEDs. However, I can't see any difference. Did I do something wrong? Do you enable the anti-dazzle with the adaptive headlight button or is that option enabled all the time?
09-29-2015, 09:55 PM | #81 | |
Rep 3,834
09-29-2015, 10:07 PM | #82 |
127
Rep 357
Yeah. That is what I meant by activating the adaptive headlight. It turns on high beams when there aren't any other vehicles but as soon as I am near another vehicle, it turns off all high beams just as before I coded the euro anti-dazzle, or so it seems.
Also, do you know a way to disable the bulb check? I installed some rear LEDs and they flicker on start up. |
09-30-2015, 10:40 AM | #83 | |
Rep 1,427
09-30-2015, 02:00 PM | #84 |
127
Rep 357
Ahh. Very interesting. That may explain it.
09-30-2015, 04:21 PM | #85 |
Rep 3,834
You are correct.
10-06-2015, 06:35 PM | #87 |
General
10461
Rep 40,867
Yes, If you use Mac, you must use Bootcamp or a Windows VM.
10-07-2015, 03:18 AM | #88 |
Lurker Extraordinaire
10
Rep 49
bmw coding, f80 coding |
