Spark plug and coil change @ 100k on 2008 335i...one anomaly
02-21-2015, 08:30 PM | #1 |
Supreme Galactic Commander (one galaxy over...)
674
Rep 1,778
OK, so this is the second time I've replaced the spark plugs. Last time was at 75k and didn't notice anything unusual then. This time went pretty textbook but I noticed something unusual on the plugs. All were mostly dry except the plug from #2 cylinder which was slightly wet what appeared to be oil, and darker on the threads and tip. Now, my car doesn't use oil and I haven't had any other issues that I have noticed. Does anyone have any idea if this indicates a problem I should address with #2 cylinder? Thx. Pic attached.
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
02-22-2015, 03:37 PM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
Is it just the pic, or is #2 plug missing its crush washer?
Either way, I think I've read of possible hairline cracks in the valve cover leading to oil dribbling into the plug orifice.
02-22-2015, 04:04 PM | #3 |
bOrN To DiE
413
Rep 1,738
good catch there is no washer on that plug.. I dont know if it can cause a problem like that..
02-22-2015, 04:40 PM | #5 |
Rep 1,834
Drives: '05 E90 330i Manual
To me it does look there is a washer, just flush against the plug.
02-22-2015, 08:16 PM | #6 |
674
Rep 1,778
Thx. Yes, there is a washer. Valve cover crack...man, with all that fuel and electric lines routing over the top that has to be a monster job...
Best,
