07-09-2023, 05:03 AM | #68 |
Rep 2
Can anyone confirm that this will fit a MY2018 (pre-opf) F82 ZCP with stock downpipes? I'm interested in buying this exhaust but I'm not 100% sure the exhaust fitment is the same between EU (pre-opf) and NA cars.
Also, maybe I missed it, but did anyone do sound level measurements with valves open/closed with stock downpipes? |
07-10-2023, 05:34 PM | #69 | |
76
Rep 101
07-10-2023, 05:39 PM | #70 | |
523
Rep 339
through the videos we did do DbA testing. check out the videos on our youtube to see the sound levels |
07-10-2023, 07:01 PM | #71 | |
76
Rep 101
f80 catless https://www.youtube.com/watch?v=qGKxw3FZHa4 f80 high flow cat https://www.youtube.com/watch?v=io2u6egQrf8 f80 stock cats https://www.youtube.com/watch?v=hPi9voZ12s8 Or is there a different video? |
07-16-2023, 05:16 AM | #73 | |
Rep 2
With regards to the volume, that sounds very reasonable, the MPE is loud for an OEM exhaust but not that loud. I'm mainly worried about getting banned from Zandvoort (local track) since they have a ridiculously low limits of 92dB (on paper at least, I've heard cars that are definitely much louder than that). |
07-31-2023, 02:47 PM | #74 |
Rep 783
Got mine in this weekend and installed. Not a great clip of it and doesn't really describe the actual tone but I tossed a few revs with the flap closed and then a few with the valve open.
https://www.youtube.com/shorts/bKFScVme58U My setup is stock intakes with drop-in filters, Mosselman turbos, 3.5" catless fatboy downpipes, into this valvetronic setup. I must say, it's QUITE loud at lower RPM and part-throttle but really evens out at WOT in higher-rpm's. I'll hopefully get some videos of a good drive-by soon and show what it sounds like from the outside. Overall, fitment was top notch and the ONLY challenging part of the install was the top downpipe bolt. It's just pretty tight in there. Otherwise the usual stuff - exhaust hangers are a bitch to do, and everything else was a breeze. I obviously have to adjust the tips to be even/equal but not bad for a first shot at eyeballing them.
Mosselman-powered M4 - 698/714 | 2.9 Whipple 2004 Cobra - 690/645 | Instagram
HotRodM4691.50 McIntoshMotorSports187.00 |
07-31-2023, 04:44 PM | #76 |
24398
Rep 191,249
Congrats
08-02-2023, 08:36 AM | #77 |
79
Rep 323
To Valvetronic Designs,
I wanted to take the time to say thank you very much for your hard work. I received my F80 exhaust Sunday and finally opened the box and I have to say that even the attention to detail in the packaging was exceptional. This company even supports Veterans which is very refreshing. Thanks again, Ian |
Sullivanm3135.00 |
08-02-2023, 11:38 AM | #78 | |
523
Rep 339
Thank you so much for your support! We are proud to serve veterans like yourself. Thank you for your service and sacrifice. We look forward to you getting your system installed and enjoying an unparalleled sound experience |
Full_of_fit78.50 Sullivanm3135.00 |
08-03-2023, 08:13 AM | #79 | |
18
Rep 60
08-03-2023, 09:28 AM | #80 |
24398
Rep 191,249
Congrats!
08-03-2023, 10:04 AM | #81 |
79
Rep 323
08-03-2023, 12:04 PM | #82 |
24398
Rep 191,249
My pleasure
08-13-2023, 10:12 PM | #84 |
76
Rep 101
well it didn’t fit… the mid pipe section that attaches to the downpipe doesn’t align with the bolts from the dow pipe. i think they are too close together when i compare it to the stock mid pipe section
08-13-2023, 11:05 PM | #85 |
523
Rep 339
That is very strange, please email us and we will send you a replacement section
08-14-2023, 01:20 PM | #86 |
76
Rep 101
08-14-2023, 11:02 PM | #87 |
39
Rep 182
Drives: 2018 M3 zcp smb
So can you not use the stock valve setup with this exhaust?
