05-17-2010, 02:40 PM | #1 |
Rep 1,046
Cons of coilovers
One of the first modifications that people seem to do is buy coilovers for their car. I'm sure it's obviously that the handling improvements and ability to adjust ride height and damping is the major reason for this. I was curious to know if there's any benefit i'm missing?
More importantly, what are the downsides (other than initial cost)? Do they last as long as the stock setup? Thanks.
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
05-17-2010, 03:18 PM | #2 |
10
Rep 274
The only downside I can see is the potential to void your warranty on the suspension. If you have problems with your suspension, your dealer may blame the coilovers for the problem and not cover the repair under warranty. This could happen even if the coilovers had nothing to do with the problem. If your dealer is reasonable with tolerating mods and/or you have a good relationship with your SA, then you might be OK. Regardless, it's still a warranty risk. If you're not planning to track the car, I would not go with coilovers. Good luck!
Current: /// F10 M5 /// Sakhir Orange Metallic /// Comp Pkg /// Driving Asst Plus /// Exec Pkg /// Carbon Ceramic Brakes /// Bang & Olufsen System
Past: E30 M3 /// E28 M5 /// E92 M3 |
05-17-2010, 03:40 PM | #3 | |
68
Rep 2,194
I would personally not touch the suspension if I were not planning on tracking it hard. Occasional track days don't even warrant coilovers and its more for the serious track enthousiast.
2012 E92-M3 Space Grey on Fox Red, DCT
2011 B8 S4 S-Tronic , Black on magma red |
05-17-2010, 03:58 PM | #4 |
Rep 1,046
As I'm closing in on purchasing an M, I've just been reading through common mods. Just trying to figure out why certain mods were done and the pros and cons.
95% of the time I would just use it for spirited driving, 5% an occasional track day. Just curious what mods were worth while to tighten up and already fantastic performer.
05-17-2010, 04:08 PM | #5 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Don't go the C/O route if you aren't familiar with suspension set-up. After a couple of times adjusting your ride height, you'll have the corner balance so messed up the car will drive like a Toyota truck with one bad shock and a broken spring.
A coil over set-up needs to be corner balanced since it is possible to load the individual wheels differently depending on how you adjust the spring perches. |
05-17-2010, 04:13 PM | #6 | |
Rep 1,562
that is a good point too because when i got my coils way back when, i didnt realize at the time that a corner balance and alignment would be needed every time you adjust the height of the coils. these things and the costs associated with them are the cons i would relate with coilovers. |
05-17-2010, 04:20 PM | #7 |
Rep 1,046
Grills and gills aside, I'm not much into visual mods.
What would yall recommend as 'low hanging fruit' for modifying an M3 other than exhaust? Dinan Stage 1 suspension? I wish the car had more steering feel (even in sport mode). I thought it was interesting that no one has squared up the tires like IND did in Project Oregon Gold Rush (275/40-18 all around). I'm rambling, but getting y'alls input on mods would be great!
05-17-2010, 04:43 PM | #8 |
Rep 9,034
People haven't gone square because this car has a tendency to hang the tail out easily.
As for Dinan Stage 1, just get Eibach springs, E36 M3 bump stops and you're almost there. You would just need to shave down the spring hats to be there. Don't know how hard that would be to do.
05-17-2010, 04:56 PM | #9 |
14
Rep 249
Corner balanced is highly recommended along with alignment after install. The only downside here is if you paid for your EDC as there is no coilover on the market that will retain the EDC funtion.
05-17-2010, 05:23 PM | #10 | |
Rep 1,046
What do you think are the best mods for the street M3?
05-17-2010, 05:26 PM | #11 |
Rep 213
I am sure the balance of the car would be off after installing springs only. Bad thing is I don't think you could corner balance a car lowered on springs.
RPI GT Race Exhaust ~ RPI Scoops ~ BMC Air Filter ~ 19" BBS LM DBK ~ JL Motoring VRS Front Lip ~ Vorsteiner Diffuser Type I ~ KW Clubsports
My RPI GT Race Dyno vs. Stock: http://www.m3post.com/forums/showthread.php?t=239228 Last edited by jimmyeatsworld; 05-17-2010 at 05:33 PM.. |
05-17-2010, 05:31 PM | #12 |
Rep 213
Cons: more money for c/o than springs, not being able to use edc, and money for corner balance.
I want to add that I lowered the car for aesthetics initally, and for performance. I personally like to keep my oem parts intact for resale thus going the c/o route. If you are not getting aftermarket wheels I would not lower the car. I wouldn't ruin the handling of the car if I had the choice.
My RPI GT Race Dyno vs. Stock: http://www.m3post.com/forums/showthread.php?t=239228 Last edited by jimmyeatsworld; 05-17-2010 at 05:47 PM.. |
05-17-2010, 05:32 PM | #13 |
Rep 1,046
So if suspension is out, what would you modify?
05-18-2010, 03:25 PM | #14 | |||
Rep 1,210
I don't think you should be too scared to modify this car. It was that way when the E46 M3 first came out and it's apparently the same way with the E9X M3 too. Rightfully so though, it's a very expensive car! However, suspension is one of those items that can be reversed completely. When installed correctly, there's no real reason it would damage the vehicle. |
05-18-2010, 03:49 PM | #15 | |
Veni Vidi Vici
89
Rep 2,750
I've run a square set-up for over 30k miles with several track days. I still think maximizing the front and rear rubber is the way to go for track days. I run 265 in front and 295 in the rear for track, now. Ground-Control sells an EDC compatible coil-over set-up. It has to stay relatively mild as far as spring rates go due to stock damping rates. I'm a fan of the Dinan stage 1. |
05-18-2010, 07:22 PM | #17 |
28
Rep 176
I'm very happy with the Dinan Stage 1. My car is not tracked so I didnt go with coilovers. Most of the other guys that work down here at tuning shops that have worked on my car agree that the Dinan works very well with the EDC. It is a bit pricier but alot of guys have said the H&R's handle terrible. Most said the Eibachs are the best low cost alternative if the Dinan is too pricey. I went with the piece of mind knowing that if BMW won't fix a suspension issue, Dinan will. Good luck
05-18-2010, 07:50 PM | #18 |
Rep 3,833
IMO, the only downside to coils is cost. Other then that, they are simply the best solution.
Pick your coilover carefully though, one that will match your driving style and fit your needs.
05-18-2010, 10:13 PM | #19 | |
Rep 1,046
05-18-2010, 11:41 PM | #20 |
Moderator
675
Rep 4,737
To be honest, if you never see the track, there is absolutely no point to get a coil over kit. The stock suspension is tuned to both comfort and sportiness to perfection by zee M engineers...
If you see the track less than a handful of times a year, the most I would go for is perhaps adding some more camber by 1) lowering springs and/or 2) fixed camber plates. (or just pull the pins on the front upper guide support) Can you do better than stock? Sure. A well-designed, higher-end coil over kit (i.e. 2-way adjustable kits) can definitely be more capable than the stock suspension. However, it is just as important to tune them in correctly (i.e. ride height, camber, toe, damping), so you must either have a good fundamental understanding of car suspension and/or know someone who does. |
05-19-2010, 01:08 AM | #21 | |
Rep 9,034
If you do track and get coils, there are plenty of race shops that can help you set up the car.
05-28-2010, 08:47 PM | #22 | |
1446
Rep 1,614
Comparing the suspension on an M3 vs a pinto is not apples to apples. |
