03-20-2024, 04:05 PM | #1 |
Rep 13
328d Various codes
Hi everyone, I have a 2016 328d.
Getting the following codes: 241200 - Monitoring fuel injection rate: Fuel injection rate too low compared to lambda value and air mass 2C1E00 - Monitoring fuel injection rate: Fuel injection rate too low compared to lambda value and air mass 2A6D00 - Smooth-running regulator, cylinder 4: Correction quantity outside permitted range 24C000 - Injector cylinder 4, zero-quantity adaptation: Activation duration correction too high Any idea where to start troubleshooting? |
03-21-2024, 01:32 PM | #2 |
Rep 37
Injector no 4 is highly likely bad and i would start from there. You can view smooth running values with a proper diagnostic tool but probably no point.
Get all injectors flow tested in a bench if you want to be absolutely sure or i would just buy a new injector and code it at some point or get it coded. You can also probably find the injector for sale on ebay or your parts store from bosch itself. No need to buy straight from dealer if they charge a arm and a leg. Find the correct code for the injector from realoem or bmwfans and do the replacement yourself if possible. Its relatively easy for N series engines because you do not need to remove intake manifold. You would need a new copper washer aswell that goes between injector and engine head. Engine is probably running quite rough on idle. |
03-22-2024, 11:35 AM | #4 | |
Rep 13
As far as rough idle, it only lasts for 10 seconds, and it's not incredibly rough, just a few rpm spikes, but regardless - this is an injector on it's way out more than likely. Thanks for your time Edit: Realized you're from Estonia. Really cool people. Last edited by dazzles; 03-22-2024 at 11:37 AM.. Reason: Estonians are awesome |
