10-13-2022, 12:59 PM | #67 |
23
Rep 18
I'll give that a try as it looks to be in my neck of the woods.
Unfortunately I don't fill up that often as my F10 isn't my 'daily', but next time it will be on the cards. Texaco website has a PDF of locations of stockists - looks to be some in the South and South East too?
Current: F10 M5 LCI, F25 X3 30d M Sport.
Past: E90 330D M Sport, E60 530D M Sport (x2), E63 630i Sport, E39 528i Sport, E34 520i SE, E28 520i. Last edited by Hiduminium; 10-13-2022 at 01:05 PM.. Reason: Additional information. |
M5Rick60075.00 |
10-13-2022, 04:51 PM | #68 | |
General
60075
Rep 19,554
Hiduminium22.50 ///M Power-Belgium63367.00 |
10-14-2022, 07:34 AM | #69 |
General
60075
Rep 19,554
Be wary of the small Shell station in South Croydon on Brighton road, if you stay there more than 15 min you get a PCN in the post, how nice of them...not.
10-19-2022, 08:25 AM | #70 |
General
60075
Rep 19,554
Found this vid on comparison of top fuels for F10 M5's with ethanol content and the winner is not v power but one with zero ethanol and 99 RON.
10-24-2022, 07:40 PM | #71 |
General
63367
Rep 24,672
Very Interesting .Thanks for sharing !
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick60075.00 |
10-29-2022, 07:33 AM | #72 |
General
60075
Rep 19,554
Sunak has said he'll end the war on the motorist before he became PM, we'll see if he keeps that promise and not let it go under the carpet like with the last woman that left.
Waiting when he'll reduce fuel tax for starters. |
11-02-2022, 02:18 PM | #73 |
General
60075
Rep 19,554
Texaco 99 Performance E5 is the best one for your M, it's 1.80 around my way and finally found a station that stocks it.
Texaco 97 Supreme is alongside it but is E10 so no good for the M. *edit Just saw 97 Supreme with E5 now on a pump, ok for the CLK. Gov.rulings now mean the new Texaco 99 Supreme Performance + could now have ethanol added, another up to date test is needed.If it has then you're better off with Tesco M99 price wise. Last edited by M5Rick; 11-04-2022 at 03:35 PM.. |
11-19-2022, 07:42 AM | #75 | |
135
Rep 159
To compare I did fill my tank with a regular Sainsburys petrol and added a bottle of petrol additive from Redex, run a few miles to get the feeling - there was none. Any savings were literally evaporated as lower spec petrol seems to burn faster or not holding up regardless of the additive. I then filled the tank with the Texaco 99 and the difference was eye watering. Efficiency, cleaner function, better throttle response. No comparison. I get it is more expensive but imo it is worth it. |
11-20-2022, 03:24 PM | #76 | |
General
60075
Rep 19,554
MarcF10135.00 |
11-21-2022, 08:10 AM | #77 | |
135
Rep 159
I was passing by a random day and needed refuel anyway so I went in and the pump was there. 1 pump out of 10 or so.. My point is if you happen to be passing by your Texaco, perhaps it's worth taking a look in case they have it... |
M5Rick60075.00 |
11-22-2022, 07:46 AM | #78 | |
General
60075
Rep 19,554
Instead if 'issing about looking for it I asked them to tell me a stockist nearest to me. |
11-25-2022, 04:50 AM | #79 |
General
60075
Rep 19,554
Thinking about it more it's a bit worrying if you are actually getting the tex fuel you pay for as with the mix up with stickers to the one near me.
Inspectors can shut a station down if fuel is found to be wrongly marked or is contaminated in some way, at this particular one there appeared to be no new hole built for the 99, when I asked he didn't reply !! I think I'll stick to Momentum99 for the moment. |
11-25-2022, 06:10 PM | #80 | |
211
Rep 250
11-26-2022, 10:42 AM | #81 |
General
60075
Rep 19,554
All the tanks are allocated to the fuel grades and diesel so they would have to do another hole for the 99 being a new fuel, one for diesel,one for 95 ULD,one for 97ULD and a new hole for the new 99.
02-14-2023, 03:54 PM | #82 |
Rep 5
Apart from finishing the tank from previous owner, I've only ever put in 95 RON, from the cheapest place I can find.
It runs perfectly, and it's not like we need the last couple of bhp! I think you might be worrying about nothing. |
02-16-2023, 03:06 AM | #84 |
Rep 5
The manual says to use 98 to achieve nominal performance and economy.
It also says 95 is OK to use. It's no skin off bmw's nose for the customer to use more expensive fuel, but the economy benefit doesn't cover the cost difference so I guess it's up to you if the last % of performance is worth the cost. |
02-16-2023, 06:02 AM | #85 |
General
60075
Rep 19,554
^ Good for you buddy but you're down on power and detergents using cheap 95. I wouldn't buy an M car from anyone knowing they were running it on that long term and all 95 fuels are now E10 which is said to damage rubber and other seals.
02-16-2023, 08:07 AM | #86 |
Rep 5
The car is designed and tested to be used with e10 95ron, why would you be put you off buying one used as such?
Makes me laugh that people won't put e10 in their cars, but then get it mapped to use e85. . Anyway, I'm not trying to be argumentative, just offering the point of view that people don't need to be concerned about what fuel they use. It's not like putting cheap oil in. |
02-16-2023, 09:33 AM | #87 | |
General
60075
Rep 19,554
02-17-2023, 10:58 PM | #88 | |
52
Rep 175
