BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Fog light coding question
Studio RSR
      07-23-2018, 03:27 PM   #45
ALEX_BMW
ALEX_BMW's Avatar
Drives: F30 335i 2015 SEDAN
Originally Posted by oranga View Post
Originally Posted by ALEX_BMW View Post
Greetings to all, someone knows the code to turn on my foglight with a bmw f30 halo light both at the same time.
Read through this thread, especially my posts, and you should be able to turn on ur foglights with ur halos.
Thanks!!
      07-26-2018, 06:26 AM   #46
Frazc
Drives: 435d xDrive
Originally Posted by XC007 View Post
Originally Posted by enes28 View Post
Hello everyone.
I have a queiston with fog lights and high beams.
How can we do that in F30; when turn on high beams, fog lights are on like a below video
Do this:
MAPPING_SIDEMARKER_L_FUNCTION = 05 (High Beam)
MAPPING_SIDEMARKER_L_OUTPUT = 0B (Fog Lamp L)
MAPPING_SIDEMARKER_L_PWM_LEVEL_STANDARD = 89 (13.7V)
MAPPING_SIDEMARKER_L_FIXED_PWM = 00 (pwm)
MAPPING_SIDEMARKER_L_PRIORITY = 03 (bottom priority)
MAPPING_SIDEMARKER_R_FUNCTION = 05 (High Beam)
MAPPING_SIDEMARKER_R_OUTPUT = 0C (Fog Lamp R)
MAPPING_SIDEMARKER_R_PWM_LEVEL_STANDARD = 89 (13.7V)
MAPPING_SIDEMARKER_R_FIXED_PWM = 00 (pwm)
MAPPING_SIDEMARKER_R_PRIORITY = 03 (bottom priority)
So does this just flash the fogs or does it change anything else? I want to have my front fog flash because nobody sees the headlights flash during the day!
      09-25-2018, 12:27 PM   #47
Hybrid330e
Member
Hybrid330e's Avatar
17
Drives: 330e M Sport F30 LCI
Hey oranga, what if all i want is to be able to active the fogs with the fog switch whether i have the DRL of lowbeams? have you found a way to do this?
      09-25-2018, 01:06 PM   #48
oranga
87
Drives: 335 6mt
No, I didn't look into that for myself, but that's a good question. I'm not an expert on coding, but I don't think you can code that behavior, at least not by changing the light mapping - which is the extent of my coding knowledge.
Maybe someone with more expertise could chime in.
There could also be a wiring solution, depending on how adventurous you are. In one of my old cars, the fog light switch would only work if the lowbeams were on, so I bypassed it and could turn the fogs on/off regardless of situation.
      09-25-2018, 01:36 PM   #49
Hybrid330e
Member
Hybrid330e's Avatar
17
Thanks! I will look into it and post my findings.
      10-14-2018, 07:56 PM   #50
Hybrid330e
Member
Hybrid330e's Avatar
17
So I coded the fog light switch to be operational when the selector is in parking lights! Fogs + angel eyes
Using BimmerCode :
Front Electronic Module > EXPERT MODE > 3060 LceMaster > NSW_EIN_AUF_LDS_STL > Select "aktiv"
Thanks to BReardon58
https://f30.bimmerpost.com/forums/sh...38;postcount=2
AndrewC198910944.00
      06-18-2019, 03:59 PM   #51
Johny212
9
Drives: F30
Kinda old topic but ima try, maybe some 1 can help me. Replaced normal halogens to led ones and did some coding. No results, leds are not working,, even no turning on.
F30 LCI
Did coding this way:
Fog light lamp- bulb -> led
Fog light Cold monitoring: Not Active
Fog light Warm monitoring: Not Active
and in expert mode:
FEM_BODY
3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right
3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right
3061 NSW_R_IS_LED -> aktiv : LED Foglights front right
3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right
3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left
3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left
3061 NSW_L_IS_LED -> aktiv : LED Foglights front left
3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left
3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_abbiegel_L_output -> nsw_l : Foglight when turning
3062 Mapping_abbiegel_R_output -> nsw_r : Foglight when turning
3073 KL_ENABLE_RE -> KL_Ein : Foglight when turning
3066 KL_ENABLE_LI -> KL_Ein : Foglight when turning
3073 C_CLC_ENA -> enable : Foglight when turning
3073 C_BLC_ENA -> enable : Foglight when turning
3063 Mapping Nevelschw L Part of WL soft-on nicht_aktiv : Foglight left as welcome
3063 Mapping Nevelschw R Part of WL soft-on nicht_aktiv : Foglight right as welcome
Any ideas?
      06-19-2019, 12:18 PM   #52
atzebmw
Germany
588
Drives: Tesla Model 3
Originally Posted by Johny212 View Post
Any ideas?
I do not know where your problem is coming from but i would try to code all back to standard and then try again.
If the lamps after that still do not work they are probably broken.
      06-20-2019, 01:50 AM   #53
Johny212
9
Drives: F30
Did it already, gonna check properly halogens
      07-25-2019, 01:08 PM   #54
Linc0909
Linc0909's Avatar
Drives: 2013 328i,
Originally Posted by Takkey View Post
Hello!
FEM_BODY 3062 LceLampMapping2
MAPPING_NEBELSCHW_L_FUNCTION = 03
MAPPING_NEBELSCHW_R_FUNCTION = 03
If automatically come on when small lights.
MAPPING_NEBELSCHW_L_FUNCTION = 01
MAPPING_NEBELSCHW_R_FUNCTION = 01
However, Foglight switch is disabled.
Set values to =01 for R and L, works great. Fogs come on auto with headlamps set to 'auto'.
Down side; it is not indicated on the dash that they are on.
Thanks for your contribution to the post
There is a fine line between being a hero, and being a victim.
      08-23-2019, 08:59 AM   #55
Beachparty
Drives: F30 335i
Hi !
Maybe a dumb question has I'm fairly new to coding a bimmer but… when you say 01 or 03.etc... that is changing the hex value in expert mode right ? (0x01 or 0x02 etc ??)
Thanks !
      09-10-2019, 07:42 AM   #56
chrisdelyon
chrisdelyon's Avatar
France
Drives: BMW
I wonder if any of you know how to code the headlights so when they are in automatic mode they will immediately turn off after leaving a dark place, for example a garage or a tunnel, instead of taking about 2 minutes which is what happens, at least on the latest models.
Hello, have you got find the line for change the value. switch off 30sec about.
actually i confirm about 2 minutes i have a mini f56 01/2016.
and i have a other car E87 2011 and switch off about 20sec.
thanks you...
      09-15-2019, 05:56 PM   #57
radarlarry
radarlarry's Avatar
26
Drives: BMW 328i f30
This works really well. Fogs are auto on w/ low beams. However, switch does not work. No problem. Nor, does the fog light symbol appear on the instrument panel. Also, no problem!
Mine were set to 08. Just changed to 03.
      09-16-2019, 04:06 PM   #58
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
You can code the fog light switch to work (I don't remember the specific coding off hand). Also, there is no front fog light indicator in the F8X cluster like in the F3X clusters. If you look at the right angle, you can see all of the indicators in the cluster and there is no front fog light one (you can also further confirm it if you do a cluster lamp test).
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      09-16-2019, 04:11 PM   #59
radarlarry
radarlarry's Avatar
26
My f30 does have a fog lamp indicator. It just doesn't light up now after coding the fogs on with dim headlights.
      09-17-2019, 01:54 AM   #60
chrisdelyon
France
Drives: BMW
Yes, i confirm, i have E87 5 dorrs, and the indicator is switch off when i proced coding. if i remove the coding the indicator is ok. the green light dashbord
and this is the same for mini F56 01/2016. I have tested with bimmercode for serial FXX and inpa , ncsexpert for serial EXX .
and I search the codding for
thanks you...
      09-17-2019, 06:42 PM   #61
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
Oops, rookie mistake on my part. I did not realize you had a F30....
      09-26-2019, 05:11 PM   #62
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Using BimmerCode :
https://f30.bimmerpost.com/forums/sh...19&postcount=2
I know it's been a while but thanks so much for this! That's all I wanted and you just saved me a whole lot of time, reading, and trial & error work
Poochie9107.50
      11-14-2019, 09:05 AM   #63
peshety
Drives: BMW f10
Hello. How to code: when I turn on high beam lights to turn on automatically fog lights and cornering lights? All to light together.
      01-12-2020, 08:57 PM   #64
EvntHrzn
Drives: BMW F10
You can code the fog light switch to work (I don't remember the specific coding off hand)...
Does anyone know the coding for this? It would be greatly appreciated.
I have searched but it's such a specific thing that I haven't had much luck.
This thread has been a great help in customizing the functionality of my fog lights and how I want them to work with the other lights, but having the switch still be functional would be the cherry on top!
FYI, I'm mapping my fogs to come on automatically with low beams (so werte value of 03 from that list on page 1)
      01-12-2020, 09:07 PM   #65
John in VA
1001
Drives: 2015 228i M Sport
Your post is a bit unclear, to me, but here's the link to modify the switch to work: https://f30.bimmerpost.com/forums/sh...d.php?t=877278
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      01-12-2020, 09:20 PM   #66
EvntHrzn
Drives: BMW F10
Thank you but I meant something else, which I obviously didn't communicate clearly.
As others in this thread have done, I have coded my front foglights to come on when I turn on my headlights (low beams), however, coding this makes the physical fog switch not work anymore.
So when I saw what jmciver wrote about there being a way to code the switch to still work after coding the fog lights to come on with the low beams, I figured I'd revive this and ask how, in case anyone else knew.
John in VA1000.50
