new 300hp 335i turbo engine - turbo whine?
07-18-2006, 09:27 AM | #67 | |
49
Rep 286
07-18-2006, 10:08 AM | #68 |
Rep 364
Having just sold a A3 with the new 2.0T FSI engine (which shares not 1 part with the age old 1.8T), I can tell you it did suffer from very noticeable lag high up in the rev range. At regular speeds the lag was disguised by a strong natural torque helped by DI and variable valve timing.
Turbo LAG is not only at low revs, in fact it is usually more noticeable at high rev / high power situations immediately after you have eased back on the throttle then re-applied it. Because the engine needs more charge volume at high revs the turbo has to spin even faster (i.e. needs more exhaust pressure) to flow the intake volume at the required pressure. The lag time will therefore be longer at higher rpm/output than at low rpms. However in theory the 3.0TT should be off the turbos some what by the upper rev range, helping to reduce the problem. But to also quote edmunds: ...the turbocharged 335i has a more docile, relaxed manner. It feels confidently capable but doesn't tug at the leash like an M3... nuff said... NA all the way?
330i M-sport SG + black leather :rocks:
07-18-2006, 10:27 AM | #69 | |
Rep 5,732
I truly hope that the 335 will not suffer from it - I can live with some lag at high rpms, since that will be less of an everyday annoyance, given that to feel the lag you will need to drive in a very spirited way. |
07-18-2006, 10:29 AM | #70 | |
49
Rep 286
http://www.neowin.net/forum/lofivers...p/t369709.html |
07-18-2006, 10:34 AM | #71 | |
49
Rep 286
07-18-2006, 10:40 AM | #72 | |
Rep 5,732
Sorry I was not clear enough-I DO NOT LIKE TURBO LAG; there. I have driven and owned turbo cars, I like the power and flat torque curves (on the better turbo engines), but I have yet to drive a turbo that does not have a turbo lag. And the 2.0 t in the VW/Audi empire uses the same block as the 1.8t, so while the electronics, Di etc are all new, it is not a clean-sheet design. Now I HOPE that the 335 does not have it (turbo lag), because I like the spec sheet on that engine, but none of us can really say since no one has really driven the new engine. As tests and first drives such as the Edmunds article review come out, we can all get more info. We shall see - ultimately the only way for me to overcome my turbo alergy is to drive the 335-Ah well, there are worse things in life PS "NOT LIKE IT", the "it" referred to the turbo lag, not the 335 engine. |
07-18-2006, 10:48 AM | #73 | |
Rep 364
The VAG 2.0T FSI engine (Golf / A3 etc) is very good at hiding low rpm turbo lag so most users, most of the time experince very little sensation of response lag. It is still there, but the natural torque of the engine helps to hide it whilst the turbo spins up to do it's business. BTW this engine uses a relatively LARGE low pressure turbo, not a small one as indicated in the article you linked to. Day to day regular driving it is great. But just like the Edmunds reviewer says about the 335i, it's when you're modulating the throttle at high revs/outputs that the feeling of 'elasticity' is present between throttle on and power rise. I also had mine on a dyno and the lag was there for all to see and hear at high outputs. Then had it chipped to 259bhp / 299lbft and, of course, the lag was worse. BTW : the 2.0TFSI does LESS to the gallon than my 330i, so much for turbo MPG.
07-18-2006, 10:54 AM | #74 | |
49
Rep 286
07-18-2006, 11:00 AM | #75 | |
Rep 5,732
Come on Tony-keep it real-the torque and MPG of the diesel turbos have more to do with the diesel part than the turbo part. The turbos on the diesels add to the top end power to enhance their acceleration. Diesels have tremendeous low-end torque, but (traditionally) run of steam very quickly, which made their acceleration numbers in the past horrible-turbos are there to aleviate this. If your going to compare comparables, keep the apples together and the oranges together. Otherwise, you're making a great fruit salad but not much of a meaningfull discussion. BTW-I a not a turbo hater, I have just gotten sick of the lag on my A4 1.8t after four years, which was by far the best (smoothest) turbo that I drove up to that point. So from the moment I drove the e90 I promissed myself not to touch a turbo again unless that lag has been dealt with to my satisfaction (there will ALWYAS be turbo lag-the only question is how toned down it is-on the 335 it seems to have been toned down at low rpms to the point of irrelevancy, which is good). |
07-18-2006, 11:03 AM | #76 | |
Rep 364
If it's acceptable 90% of the driving time then people will buy it. I like the last 10% from time to time though.
07-18-2006, 11:17 AM | #77 | |
49
Rep 286
07-18-2006, 01:13 PM | #78 |
Rep 972
Drives: people mad
This has gone on far too long, so I'm bowing out of this thread.
__________________________________________________ __________________
2006 BMW 325i, Jet Black, 6MT, ZSP, Black Leather, Aluminum, Power Seats, Logic 7 |
07-18-2006, 01:52 PM | #79 | |
49
Rep 286
07-18-2006, 02:21 PM | #82 | |
Rep 710
07-18-2006, 04:13 PM | #83 | |
Rep 5,732
07-18-2006, 04:15 PM | #85 | |
Rep 5,732
You are correct on this - the 335 will get better mileage here (NA) once the Di can fully be exploited and do the lean burn that it can do (and does) in Europe, where the improvement in fuel efficiency is in the order of 15% compared to the 3.0 litre non DI non turbo engine. |
07-18-2006, 04:35 PM | #86 |
Rep 4,172
Interesting debate. I, like Bimmerista, decided after my last turbo engine'd car that I would avoid turbo until lag was dealt with in a way that satisfied me. Until now that hasn't been done, however I am hoping the 335i does it. All indications at this point are that it will, since as far as I can tell it will feel "lagless" during 99% of my regular driving (and will have all the benefits of a turbo throughout). Obviously a healthy test drive is in order; In any even the fact that we can have this discussion at all means BMW has done (or at least we think that have) something right with this engine. This is the first turbo I've had any interest in at all in almost 10 years.
Cheers. |
07-18-2006, 05:37 PM | #87 |
781
Rep 2,638
...it always amazes me when enthusists resort to insulting retorts etc. on message boards... this is for fun right?
~Frost
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017) 335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016) Prelude (5MT) (1995) |
07-18-2006, 05:41 PM | #88 | |
Rep 1,457
