07-11-2022, 01:27 PM | #1277 | |
2944
Rep 21,754
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-18-2022, 11:48 PM | #1278 |
41
Rep 47
Just bought a F83. It came with 18” wheels.
After reading this thread, I am planning on 18mm front and 15mm rear. Do I need an alignment after or not? |
12-19-2022, 01:47 PM | #1279 |
8265
Rep 18,851
Drives: BMW
No alignment is needed after installing spacers.
12-27-2022, 04:25 AM | #1280 |
Sicario
1130
Rep 1,248
Drives: 2018 M3 ZCP
Not gonna comb through a million posts lol, but if you have 666M and are now running PS4s and have 15mm spacers you will need to change to a 12mm spacer. I have rubbing when hitting decent bumps. Did not really consider this when I went with the PS4s.
Ryan King
2018 M3 ZCP |
12-27-2022, 12:43 PM | #1281 |
2944
Rep 21,754
PS4's run wide vs the PSS star spec tires that come factory. I would say 10mm is good to go with the PS4's.
12-27-2022, 01:20 PM | #1282 |
Sicario
1130
Rep 1,248
Drives: 2018 M3 ZCP
I ordered 12mm already, lol.
Ryan King
2018 M3 ZCP |
01-27-2023, 08:07 PM | #1284 |
Center Employee
301
Rep 97
Hello, no rubbing at all with this combo. However I only ran it like that before switching out the wheels for about 2 weeks.
02-08-2023, 12:15 PM | #1285 |
Rep 14
Hey All,
I need spacer help for my ‘18 F80 with 666 wheels, lowered on EMD springs. Tires are 265/35/20 front and 285/35/20 rear. I wanted to run 12mm front and 15mm rear but they wouldn’t fit. I swapped it and ran 15mm front and 12mm rear, but was rubbing pretty badly especially up front. I want to go to 10mm all around, 5mm not worth it in my opinion. Before I order and waste more money, does anyone have any advice? Thanks! Last edited by NickJBill; 02-08-2023 at 01:01 PM.. Reason: Adding pictures |
02-08-2023, 01:46 PM | #1286 | |
2944
Rep 21,754
I would go with the 12mm up front and 10mm rear. 10mm all around would also work but think the 12mm would look better.
02-08-2023, 02:27 PM | #1287 | |
Rep 14
I already rub a tiny bit on the wheel well, but the rubbing I got was from fender. Thanks! Last edited by NickJBill; 02-08-2023 at 02:35 PM.. Reason: Adding picture |
03-15-2023, 08:55 AM | #1288 |
258
Rep 358
Drives: 2017 BMW M3 ZCP
Garage List 2001 Honda S2000 [0.00]
2006 Mini Cooper JC ... [0.00] 2020 Audi SQ5 [0.00] 2017 BMW M3 Competi ... [0.00] |
Hi,
Have 2017 F80 ZCP Stock suspension 666M wheels - MP4S tires - 295 in rear. Would 12mm, 10mm rear work? If so, could you send me a quote. Thanks |
03-15-2023, 06:55 PM | #1289 |
2944
Rep 21,754
PM sent
03-20-2023, 08:54 AM | #1290 |
Rep 32
Hello... Just picked up an F80 and looking for spacers for flush fit. what size would i need?
2015 F80 M3 - NON COMP 19" - 437m wheels stock suspension adaptive suspension Carbon Ceramic Brakes 275/35/19 PSS STAR rear 255/35/19 FSS (No star) front |
03-20-2023, 06:31 PM | #1291 |
2944
Rep 21,754
PM Sent
03-26-2023, 11:38 PM | #1292 |
89
Rep 166
Hi Kevin,
Can you PM me with a quote for pAir of 12 mm (fronts) and 10mm (rear) spacers for my 2019 F83 running 666M wheels, shipped to 55344. Thanks! |
03-27-2023, 01:05 PM | #1293 |
2944
Rep 21,754
PM sent
05-15-2023, 05:49 PM | #1295 |
2944
Rep 21,754
PM sent
06-05-2023, 06:21 PM | #1296 |
15
Rep 16
Hey Kevin,
I installed some MS 12mm on the front of my M4. 666M with 265/30/20 Michelin Pilot Sport AS so its pretty square. Lowered on EMD spring. Love the look, but I rub on even the smallest bumps. Would sizing down to 10mm be enough to solve most of the rubbing (dont care about fender liner rubbing, just the rubbing on the bumper tabs)? I have a hard time believing 2mm would make a difference, but maybe I'm wrong. Thanks! |
08-02-2023, 11:24 AM | #1297 |
Rep 3
Kevin - I have a 2018 M3 Comp that I'm about to put Eibach Euro V1 springs on. Would like to maintain OEM+ look and based on research on this forum I'm thinking 12mm front and 10mm rear. Any thoughts on that setup?
If that makes sense to you, can you quote 12mm and 10mm shipped to 75013? Thanks Last edited by F80_Aggie; 08-02-2023 at 11:30 AM.. |
08-02-2023, 12:48 PM | #1298 |
Rep 911
Any suggestions on 255/275 19's for stock suspension for a non CP 2015? My new Star Spec tires are narrower than the PSS's I had and the look is bugging me. Lol
Im leaning towards 12f/10r because I'd rather not do the usual 15/12. |
aggressive, eas, extended lug, lugs, macht schnell, offset, spacers |
