BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
ARMA SPEED
      01-10-2016, 03:27 PM   #1
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
What parts are required other than the screen itself?
What codes are needed?
My plan is to buy the 8.8" screen on ebay, is there a specific part number i need to look for?
What other requirements are there to upgrade?
This should work with the latest version of hardware and HU_ENTRYNAV with no navigation?
From what I understand this is what I need to do
Screen Swap then code code:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
Appreciate 4
      01-11-2016, 02:08 AM   #2
TePee
67
Drives: F34 LCI MY2019
These are exactly the 2 FDL codings you need.
Then connect L7 High 8,8" screen and enjoy
      01-11-2016, 07:13 AM   #3
kromix
kromix's Avatar
Awesome can't wait!!! Buying the screen now!
Thanks for all your help TePee!!!
      01-12-2016, 04:37 AM   #4
joq3
Sweden
105
Drives: BMW 328i F30 M/T -13
How can I check if I have the HU_ENTRYNAV?
I probably don't have it, but it would be nice.
xlover2198.50
      01-12-2016, 07:03 AM   #5
TePee
67
Which exact production date is your F30?
HU Entrynav was introduced from 7/2014 on.
      01-12-2016, 07:04 AM   #6
Adamr916
Adamr916's Avatar
Drives: 2014 328d
So wait, if I have the HU_Entry screen, and want a bigger screen, all I have to do is swap the screen, not the main head unit and the screen?
zrile91.00
      01-12-2016, 07:07 AM   #7
kromix
kromix's Avatar
No.
HU_ENTRY = can't be done.
If your car has HU_ENTRYNAV (Introduced 7/14) then you can do it.
Appreciate 3
zrile91.00
ADHD199.00
      01-26-2016, 09:27 PM   #8
Coolala
Japan
38
Drives: 2013 F30
Hi TePee,
Other than the coding, do I need to change the CID cable (monitor cable) as well?
Thanks!
      01-26-2016, 10:41 PM   #9
kromix
kromix's Avatar
Originally Posted by Coolala View Post
Hi TePee,
Thanks!
I haven't done it yet, but I will be creating a DIY on this when my car arrives. From what I read you don't need to change the cable, only the screen, PlugNPlay.
DIY coming soon in about 2-3 weeks
Appreciate 3
      01-27-2016, 12:27 AM   #10
Coolala
Japan
38
Drives: 2013 F30
Great! I'm now not sure if HU_ENTRYNAV appears for 3/4 series only or even 1/2 series will have this after 7/2014 production.
      01-27-2016, 06:25 AM   #11
TePee
67
I can also confirm that you don't need another cable. Just the big screen and the 2 FDL codings.
You should find Entrynav from 3/2014 or 7/2014 on, depending on BMW series 1/2/3etc. and whether you have navigation (Business) or not (Radio Professional).
      02-09-2016, 05:31 AM   #12
DeeKay
DeeKay's Avatar
Denmark
553
Drives: 2021 Tesla Model 3
How do we check the system version? I have a 10/2012 F30 with Business navigation (6" screen) - I know it's a retrofitted system, so it might be a tad newer than the car. Am I able to switch the screen to a big one? Would LOVE that upgrade!
| 2021 Tesla Model 3 |
      02-09-2016, 07:27 AM   #13
NikF30
Drives: F30
F30 Screen Size upgrade
Hello everyone - I have Business Nav with 6.5" screen.
Can I buy the bigger screen and straight swap?
How do I swap the codes?
      02-09-2016, 07:55 AM   #14
TePee
67
Guys as wrote before you need to have HU Entrynav which was introduced from production 2014 March or July on (depending on if you have Business Nav or just Radio Prof, both are Entrynav).
If you have 2012 year, then you can't have Entrynav, thus no 8,8" screen retrofit possible.
      02-10-2016, 04:13 AM   #15
DeeKay
DeeKay's Avatar
Denmark
553
Damn'it! So we would need the full system swap to NBT to go bigger?
      02-10-2016, 07:23 AM   #16
palumbo77
26
Drives: bmw f31
If you want I have an 8,8" display to sell.
Contact me in PM for information.
      04-03-2016, 12:20 PM   #17
kromix
kromix's Avatar
Here it is Car with 8.8 Screen upgrade.
Love it!!
bigdnno98288.00
      04-03-2016, 05:00 PM   #18
Rwillis92
Drives: 2012 BMW 328i N20
Ok so I'm a little confused, I have the regular screen and its 2013. What do I need for this retrofit?
      04-03-2016, 06:07 PM   #19
kromix
kromix's Avatar
Sadly too expensive for you, would need HU_ENTRNAV, or retrofitting the CPU that powers the car..... It started in cars I believe July 2014 or something around then.
      04-03-2016, 06:35 PM   #20
Rwillis92
Oh well, so what about Bluetooth streaming audio?
      07-03-2016, 12:37 AM   #21
bill_f31
114
Drives: BMW F31 M Sport
I'm about to upgrade the 6,5 screen on my 08/14 (HU_ENTRYNAV) F31 Touring to the 8,8 one.
My car is pre-LCI and I have already retrofitted the BMW Integrated Navigation System on my 6,5 screen.
Do you think that a 8,8 screen from an LCI model (part number 65509387453) can be retrofitted to my car or I need to instal the 8,8 screen from pre-LCI model (part number 65509292248)?
Are there significant differences between these two 8,8 screens?
Also the split screen function of the 8,8 screen needs some coding to work or it is automatically set as a menu option as long as the 8,8 screen is installed?
Any help would be hugely appreciated. Thanks in advance.
      07-03-2016, 05:11 AM   #22
TePee
67
The LCI 8,8" screen won't work with your HU Entrynav! It uses different voltage. You have to install the pre LCI screen.
Normally when you code 8,8" screen and broad display everything will work in proper way, including split screen etc.
The question is whether this is the case or not when you have Integrated Navigation?
