Replacement battery
06-27-2017, 10:26 AM | #1 |
Rep 559
Replacement battery
The local indi. recently replaced my 90amp hr agm battery with a 95amp hr. I have noticed that it now charges as high as 15.1 volts. He has checked it with his laptop and found no faults. Question. does the car have to be informed that the battery amp hr is different or does know automatically?
06-27-2017, 11:26 AM | #2 |
529
Rep 2,503
Could be a sign your alternator is bad.
BUT Did the Indy register the new battery? Sometimes a failing battery can be over charged if you have lots of toys in the car. I've seen 15v before. Also, double check your car is coded correctly. I guess it's a AGM battery? The coding should be A090 in your vehicle order or B090 for standard 90a battery. A 95a battery fits in with the parameters for 90a coding. |
John320d30.50 |
06-27-2017, 11:41 AM | #3 | |
Rep 559
If the 95amp battery is within the parameters of the 90amp coding everything should be all right? Thanks. |
06-27-2017, 11:43 AM | #4 | ||
529
Rep 2,503
06-27-2017, 11:59 AM | #5 | |
Rep 559
All agms. first 2 batteries were agms. |
06-27-2017, 01:25 PM | #6 |
Rep 559
