M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      01-04-2015, 02:52 PM   #23
E90Fleet
South Africa
1312
Drives: BMW
Originally Posted by Used2be View Post
Thanks for this, it makes perfect sense but I've never come across them before. My 11/2012 build M5 doesn't have them, and the replacement pads don't have them. Why would they be on some M5 and not others?
My service manager told me that the electronic pad wear sensors will indicate pad replacement at about 3mm of pad thickness.
Correct when the pad with the sensor reaches 3mm the car will ask for replacements. The other pads will vary slightly due to pads wearing differently depending on their position on the car.
I had a look at the pads, BMW changed to the pad with the Weights/absorbers in about April 2014. The pads before that did not have them.
If you anyone had their pads changed since then on the earlier cars they would have the new pads
From April 2014 Pad
Pre-April 2014 pad
BMW if you are reading, I need a job, Please.
      01-04-2015, 03:45 PM   #24
skypx
Veteran U.S. Army
skypx's Avatar
Germany
62
Drives: ///M
Originally Posted by E90Fleet View Post
Yes, just quote the SIB number "SIB 34 06 14" to any BMW USA dealer.
I did quote that exact SIB number, SA didn't have a clue.
      01-08-2015, 04:06 PM   #25
DrewM5
Drives: SG E60 M5
Unfortunately, I doubt this is what is causing my squeal since mine goes away if I bed in the brakes and comes back after a wash or rain. I think mine is caused by deposits on the discs.
2014 M5 Competition|Space Grey|Black Merino Full Leather|Anthracite Trim|Executive package|LED Lighting Package|Drivers's Assit Package|B&O Sound System|Bel STiR Plus 9500ci|IND Side Markers and Side Vents|Exhaustmeister|HRE P101 Satin Charcoal/Michelin PSS (Summer)|601/Pirelli Sottozero Serie II (Winter)|Coded by V12
      01-08-2015, 04:29 PM   #26
E90Fleet
South Africa
1312
Drives: BMW
Do your pads have the vibration absorbers ?
      01-09-2015, 08:32 AM   #27
DrewM5
Drives: SG E60 M5
I have no idea.
      01-09-2015, 10:19 AM   #28
PatrickC23
PatrickC23's Avatar
Drives: '16 991.1 911 GTS, '16 F85 X5M
2013 BMW ///M5  [0.00]
Ive not had any brake squeal since I tried the wheel cleaner trick. And ive only applied it 3 times.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red
      01-09-2015, 02:12 PM   #29
Propofoln
Speedster
51
Drives: 2023 BMW X7 M60i
Anyone have any success at the dealership and getting this SIB serviced?
      01-09-2015, 03:46 PM   #30
Nqwjx30
Nqwjx30's Avatar
64
Drives: 15' F10 M5
Yes I just got this done. Details here
http://f10.m5post.com/forums/showthr...8#post17198128
      01-13-2015, 11:28 AM   #31
Orich
37
Drives: 2014 M5
Hi,
I am in Canada and have MY14 LCI M5, I called the dealer reference SIB340614, and they couldn't find such service bulletin for my VIN. I called BMW Canada and no luck either, as they couldn't find anything in their system.
Do you happen to have the official SIB information in addition to the SIB number? I'm thinking of an BMW USA recall pdf that detail the fix, so I can take it to the dealer.
Thanks
"Speeding is like farting - you have to know when it’s inappropriate." - James May
      01-15-2015, 01:58 PM   #32
E90Fleet
South Africa
1312
Drives: BMW
Originally Posted by Orich View Post
Hi,
Thanks
Its a USA SIB, so may not be available in other countries yet.
Unfortunately my access agreement says I cannot post them up here.
It basically says the dealer must remove the pads and check if any of the the vibration absorbers are loose. If a loose one is found they must replace the pads.
If no SIB for this exists in Canada yet they wont do it for free.
They may be testing if it works in the USA first before releasing it in Canada and the rest of the world..
      01-15-2015, 02:00 PM   #33
Orich
37
Drives: 2014 M5
Hi,
Thanks
I hope Canada will get it soon
      01-15-2015, 02:01 PM   #34
E90Fleet
South Africa
1312
Drives: BMW
You can see in the picture from the thread mentioned above what the dealer did in the US for Nqwjx30
Pads checked, loose absorber found, pads replaced
      01-15-2015, 07:39 PM   #35
Swashplate
Swashplate's Avatar
Drives: in Anger.
Just had this done and the ended up replacing the master cylinder also due to a soft pedal.....
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      02-15-2015, 02:27 PM   #36
CFisher
Drives: F10 M5 Black Sapphire
Just had service done on mine - late production 2013 MY (Steel brakes) - SA did find the SIB...but told me my pads were not of the type indicated on the SIB . So the squeaking was completely normal.
So...after NOT using the oil I asked them to use for the change ...they sent me on my way...I have had nothing but screaming brakes since then! They actually got worse!
To be fair...it's been single digits around here and I have not had a chance to "re-bed" them in - but SA reports only a test drive was done with a brake fluid change.
I've tried contacting SA for his response but so far it's been phone tag.
So...IMO SIB listed might help for a subset of y'all out there...but not for me. My brakes were bearable before...but they border on horrible (noise wise) now.
      02-16-2015, 12:08 AM   #37
Salespunk
Drives: Slow
I took my car in for service and asked them to do the SIB. Picked up the car a few days later and got half a block before I realized the brakes sounded worse, not better. Looked at my printout and sure enough the dreaded "Could not replicate".
Drove into the dealership the next morning and grabbed the shop foreman for a ride. We got half a block before he stated that mine was the worst he had ever heard. He wasn't sure if they would have to change just pads or pads and rotors. They have had my car for several days now so I assume they are still trying to chase it down.
On a side note, they gave me a 428i Convertible which has been great since it has been in the mid 70's all weekend!
      02-16-2015, 09:15 AM   #38
Propofoln
Speedster
51
The SIB fixed about 80-90% of my squeal. They still make some noise, but not near as before the SIB
      02-16-2015, 10:32 AM   #39
Punitive
148
Drives: F90 M5
So does this apply to 2013's? My car is squeaking like crazy.
      02-16-2015, 01:13 PM   #40
CFisher
Not sure anybody really knows. In my case...I have a late year 2013 w steel brakes...and my SA told me the pads I have were not part of the SIB...so they didn't do anything except the regular service/change brake fluid.
      02-16-2015, 03:12 PM   #41
Jaragator
Jaragator's Avatar
Drives: 2013 Sapphire Black F10 M5
Same here. Said my 2013 not covered, but they did it anyway. No squeals so far (although I didn't have it too bad to begin with)
      02-16-2015, 07:38 PM   #42
Salespunk
Drives: Slow
Mine is a 2013 and they did it without question
      02-26-2015, 12:56 AM   #43
Punitive
148
Drives: F90 M5
You guys are lucky, they declined the replacement on my '13 and of course couldn't replicate the noise.
      02-26-2015, 11:55 PM   #44
mjr24
1655
Drives: M8 Comp GC, X7, AMG GT53
CFisher, have you noticed them much worse when it's been cold out? Mine have been horrific on my M6 the last few weeks (consequently, since the dealer said they "cleaned up" the pads and rotors).
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
m5post
