2010 2011 BMW 5 Series Forum F10 Control arms wishbone wear in months |
02-23-2022, 02:44 PM | #1 |
Rep 48
Drives: BMW 535D F10 -11
In need of constant change of control arms (front) every year on my F10 535d -11.
Its lowered 45mm front and 40mm rear. Even when the wishbone are newly installed, I feel that the right front is not 100% stable when going reverse on a small curb or pavy road. The right side is also a bit lower then the left. New springs are put on also. Can it be because of the aggresive lowered springs? |
02-23-2022, 05:41 PM | #2 |
1312
Rep 2,595
You tightened the bolts for the control arm bushings in the normal position, correct? e.g. at ride height and not with the suspension drooped.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
02-24-2022, 12:52 AM | #3 |
Rep 48
https://ibb.co/Z6qy1dV
Since it is this part that is going loose quickly, they say it has not to do with it. |
02-24-2022, 10:21 AM | #4 |
1312
Rep 2,595
The ball joint is failing? Did you actually check for play in the ball joint?
2015 BMW 535xi
02-24-2022, 11:54 AM | #5 |
Rep 48
It was squeaking, alot, and the damask was completely destroyed, om both of them.
02-24-2022, 06:45 PM | #6 |
Rep 1,060
If bushings are tightened before the weight of the car is compressing the suspension, residual torque in the bushings holds the car up. They will eventually relax (commonly mistaken for shocks/springs settling) but the torqued bushings are then prone to accelerated wear.
I would suspect this (as Unspec pointed out). |
02-24-2022, 10:56 PM | #7 | ||
1312
Rep 2,595
2015 BMW 535xi
02-25-2022, 01:56 AM | #8 |
Rep 48
Can it be another part that is wasted so it creates huge tension on the wishbones? Because, even when the whisbones are new, I feel that its not 100% stable when driving up a smaller curb or uneven roads while turning.
02-25-2022, 04:53 AM | #9 | |
Rep 1,060
The only thing left to check would be the knuckle then? If the ball joint wasn't seating properly in the knuckle perhaps it could give the loose feeling the OP is concerned with? Thrust arm bushing? This would not explain the accelerated wear on the ball joint, but might explain the loose feeling. This is odd. Are the ball joints failing on both sides, or just the right side which sits lower? Has the alignment been checked? |
02-27-2022, 03:37 PM | #11 | |
Rep 48
Ah, knuckle.. any part more that can cause this loose feeling? Both sides, yes. The thrust arms are also in need of replacement withing 2-3 years. AND I am in need of alignment every few months. |
