BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > M3 Photos/Video/Media Gallery
Mporium BMW
      05-03-2017, 02:48 PM   #111
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
Originally Posted by Leglessracing View Post
Originally Posted by warp10 View Post
Yeah. We had to trim the window frame a fair bit but came out quite nice.
The livery was designed for a local exotics dealership that sponsors the car.
They do look much better than my white grp ones! Have you got a full view of the livery? I'm trying to find ideas!
Here are the renderings.
      05-03-2017, 02:48 PM   #112
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
      05-03-2017, 03:54 PM   #113
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Sorry here are the pics
      05-03-2017, 05:17 PM   #114
Leglessracing
121
Drives: M3 E92
I'm liking that! Need to get on top of mine!
E92 M3 - Frozen Black Race car sold
F80 M3 - Fire Orange sold
E92 M3 - Frozen Grey Track day car Current
      05-06-2017, 09:42 PM   #115
Dr///M3
9
Drives: E92 M, E46 M, E36 M
Coming along!
      05-23-2017, 03:36 PM   #116
Leglessracing
121
Drives: M3 E92
So it's been a while, and I have been held up waiting for the PDU10 to arrive from Syvec's so my loom has only just been started. Still the parts are arriving though!
Bimmerworld brake cooling plates look super sexy Jonathan@BimmerWorld
And a setrab 13 row cooler ready for my diff from the guys at Do88 do88 a super service once again!
///Mobbin1478.00
      05-23-2017, 04:52 PM   #117
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Did you change diff ratio?
      05-23-2017, 05:08 PM   #118
Leglessracing
121
Drives: M3 E92
Not yet, I've got my eye on a few different diff's so it's just a matter of chosing the supplier. Will be dropping a plated one in for sure though. I've seen a few standard diff's boiling the fluid so a cooler is a must now
      05-23-2017, 08:21 PM   #119
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Oh yeah. I run a cooler on mine.
Been talking to Elise racing. Sharp guys. Nice that they have a solution for the DCT guys that want to run different diff ratios.
      07-28-2017, 08:20 AM   #120
Leglessracing
121
Drives: M3 E92
So guys, it's update time!
I'm sure some of you has seen the update on other social media platforms but here we go
So it looks like I missed my engine part of the build out in 2015. Shrick medium lift cams have gone in along with the sump baffle kit while the motor was being repaired. 2 holes needed addressing. A/C delete too. Shell bearings were not bad at all, but have been replaced with the VAC kit and ARP Bolts
Stock piling Pagid prototype, RS29 front and RS19 rear pads
      07-29-2017, 03:15 PM   #121
Leglessracing
121
Drives: M3 E92
As I'm going through my thread, I missed this update too. Suspension parts haul from the awesome guys at bimmerworld last year and a few things from VAC too
Bimmerworld*Front swaybar endlinks, Front race arm conversion, Rear adjustable wishbones,*Rear toe arm,*Rear upper camber arm,*Rear guiding link,*Rear trailing link bearings,*Rear lower camber arm bearings, Rear clevis set,*Aluminum solid subframe mounts,*Aluminium differential mounts, 82mm premium wheel studs,*Solid engine and gearbox mount
Arp rod bolts
VACmotorsports seat mount kit, oil pan baffle kit
      07-29-2017, 03:33 PM   #122
Leglessracing
121
Drives: M3 E92
Time for my rear aero solution. I drew up my design for a chassis mount to be fitted in the boot. With the help of Pete at PSDesigns it was made up and ready to go. I've then gone and had a swan neck wing made to match up to it. Will see how this goes with the view to develope onto another wing. Here's some more pics for you all!
      07-30-2017, 01:56 PM   #123
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
This is awesome. Do goes through the top of the trunk?
      07-30-2017, 03:44 PM   #124
Leglessracing
121
Drives: M3 E92
Yep it will do. I'm running a C/F trunk too. The setup I'm using can also be extended when a fuel cell is installed to clear it too. This is currently only a 155cm width wing, once developement is complete, I'll be going up to 170cm and developing end plates too
      08-09-2017, 02:24 PM   #125
Leglessracing
121
Drives: M3 E92
The wing has been all be dry fitted now and ready to start tests
      10-18-2017, 08:00 PM   #126
Leglessracing
121
Drives: M3 E92
So guys, it’s time for a well over due update! Things are moving along, at a slower rate than I hoped for but progress is progress.
Wiring ready to connect up
Race CANBUS dashboard
Motorsport24 GTR vented bonnet
Bosch Motorsport M4 Clubsport abs unit
Fuel filters fitted so plenty of fuel now being used!
      10-18-2017, 08:01 PM   #127
Leglessracing
121
Drives: M3 E92
Here is the current wing solution. This is the Karboniuos composites e92 dual plane wing. It has been specially adapted with mounting carbon lugs. This wing is absolutely amazing and with any luck, should be able to generate huge downforce!
Karbonious Carbon dual plane wing with custom mounting on the top
Dual plane wing CFD
      10-18-2017, 08:07 PM   #128
Leglessracing
121
Drives: M3 E92
Now that the wing is here, I have been able to do a dry run with the wing in the chassis mounted wing bridge. All fixings on this has been made out of titanium to keep any weight that goes into this as minimal as possible. Anyway here’s some pics!
      10-18-2017, 08:21 PM   #129
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Drool
      10-18-2017, 10:39 PM   #130
GORDON.M3
GORDON.M3's Avatar
1430
Drives: E92 M3 • F25 X3 M-Sport
Amazing build, why did the block have a hole to begin with? What happened? Is the block salvageable?
      10-19-2017, 02:54 AM   #131
Leglessracing
121
Drives: M3 E92
With the car being a write off, it was impossible to see the condition fully until it was stripped down and removed from the car. We were hoping all was well because it ran for the inspection but alas it had to be fix
The block was salvageable and was repaired in no time at all
      10-19-2017, 02:57 AM   #132
Leglessracing
121
Drives: M3 E92
So after over 2 and a half years it is up and running! The super B battery makes light work of spinning the engine over and has it running in no time at all. It also sounds awesome without the airbox installed. Hopefully it will be on the dyno in the next few days for a full power run
https://www.youtube.com/embed/LzVWrKw01N4
///Mobbin1478.00
m3post
