Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > XI Staggered Tire Calculation Tables
      10-25-2014, 01:19 PM   #1
rosica
Drives: s2000
2001 S2000  [0.00]
2007 333xi  [0.00]
After so many posts asking “will this staggered tire combo work”, I decided to make the following charts to help out.
Any difference above the generally accepted 1% is crossed out on the chart.
The factory staggered setups are marked in BLUE.
From my personal experience I like the factory 18” staggered setup vs my 235/275 19” setup. Why? 17” looks too small on a e90 and 19” offers so little sidewall bent wheels are inevitable.
Enjoy!!
PS: The tire data was takes from S-04 and Pilot SS, there could be variably among brands and models
̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶s̶1̶4̶ >F20C->1̶.̶8̶t̶-> n54
Appreciate 11
      10-25-2014, 08:03 PM   #2
BklynTico506
Pura Vida
BklynTico506's Avatar
Costa Rica
13
Drives: Monaco Blau '08 E90 Xi
This is great info. Much better than guessing when using the tire calculator.
      10-26-2014, 04:15 PM   #3
khanh1289
Drives: 2008 BMW 328xi Coupe
thanks!! this is awesome!
      10-26-2014, 04:21 PM   #4
kisho
Quiet till poked
Drives: E90 325xi
2006 325xi  [9.50]
This needs to be a sticky
      10-27-2014, 07:47 PM   #5
gtaccord
Drives: 2009 BMW 335xi
Can you make it to show positives and negatives? The front tire diameter should be larger than the rear and then within 1%. Smaller does not work.
      10-28-2014, 08:51 AM   #6
mashimarho
mashimarho's Avatar
2111
Drives: E92 M3 & F80 M3 & G82 M4
THIS is nice.
Mashimarho.com /// Instagram /// Facebook /// Youtube /// sales@mashimarho.com /// (425) 582-7939
      10-28-2014, 08:53 AM   #7
mashimarho
mashimarho's Avatar
2111
Mods need to sticky this..
      10-28-2014, 06:22 PM   #8
rosica
Drives: s2000
2001 S2000  [0.00]
2007 333xi  [0.00]
I can and in negatives in a few days. I haven't heard before that the front needs to be bigger, what is the reason?
      10-29-2014, 09:49 AM   #9
chepy24
chepy24's Avatar
30
Drives: 2009 alpine white 335i xdrive
this is awesome makes it sooooo much easier!! thanks! sticky please
      11-05-2014, 07:54 PM   #10
rosica
Drives: s2000
2001 S2000  [0.00]
2007 333xi  [0.00]
Negatives added, I am still not convinced it matters.
      11-06-2014, 05:51 PM   #11
ucdbiendog
Drives: 2008 335xi E90
my first set of winter tires (some continental variety), i tried staggered at :
Front: 225/45R17
Rear: 255/40R17
I would get the traction control light at speeds over 50 mph, so it may be manufacturer dependant (check tire specs). So I switched them out and used a square setup. Problem solved.
      11-06-2014, 06:08 PM   #12
madbim
madbim's Avatar
Drives: 08' E90 335xi
shouldn't a tires rolling diameter be a more accurate way to measure?
      11-06-2014, 07:53 PM   #13
rosica
Drives: s2000
2001 S2000  [0.00]
2007 333xi  [0.00]
Front: 225/45R17
Rear: 255/40R17
That setup should work, but there is variability among brands.
I used diameter. There also is circumference and revolutions/mile. I have those too, the results are basically the same.
      11-06-2014, 09:54 PM   #14
gtaccord
It does. Thanks.
      11-09-2014, 02:34 PM   #15
weareweird69
88
Drives: 2014 X5 35d
Thanks for this! I too vote it to be a sticky.
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
      12-31-2014, 05:43 PM   #16
BklynTico506
Pura Vida
Costa Rica
13
STICKY this already. I've come back to it a number of times, and seen threads made that could have been answered if this information was readily available.
      01-11-2015, 08:52 PM   #17
bimmerdreamz
bimmerdreamz's Avatar
Drives: 335xi
Thanks a lot OP! So much easier and clear.
      01-12-2015, 09:30 AM   #18
evon54
Drives: 2008 335xi
so 245 fronts fit?? i thought it would rub on XI?
      01-12-2015, 10:15 AM   #19
Give_Em_The_DD
Drives: 2010 black 335xi coupe
Where was this last spring! Lol
      01-12-2015, 10:16 AM   #20
Give_Em_The_DD
Doesn't rub on mine...245/35/18 all the way around on PSS
      01-12-2015, 12:52 PM   #21
evon54
Drives: 2008 335xi
Can we go 20's?
245/30 295/25?
      01-16-2015, 07:43 AM   #22
evon54
Drives: 2008 335xi
So tire rack said 235 is the widest we can fit in the front and 265 rear?
what offset is needed for 245 and 275?
