335i Alternator failed?
06-20-2016, 06:20 AM | #23 |
Rep 1,178
Geez sad to hear.. nah i wont be driving it. Only drove it home before the engine became hot.. waiting on a new battery so its just sitting in the garage. I left it unlocked and opened the door now the doors wont shut because windows are all the way up. Gotta love technology..
06-23-2016, 11:39 PM | #24 |
Rep 1,178
Okay seems like car will be off the road for a few more days. Replaced the battery with oem and tested the alternator. New Battery is fine but electronics are still messed up due to the alternator pushing 18 volts instead of 12 volts and my mechanic told me that its the end of the road for the alternator since it is providing such high voltage that it's effecting the ecu. The car needs to be towed in and get the alternator replaced before it can be driven. I could've blown 2k on mods and detailing and it goes to repairs. Fekk!
06-23-2016, 11:57 PM | #25 | |
Rep 3,131
Drives: 2011 335i e92 DCT
06-24-2016, 01:55 AM | #26 |
44
Rep 249
Woah 18v !? That is rather broken. Hope you're back on the road soon mate. Let us know how you go.
As for alternator output I'm getting around 14.3 / 14.4 v as per hidden menu display with the engine running and in motion. |
06-24-2016, 08:22 AM | #28 |
Rep 1,178
Uh so 14.4v is the norm.. Yes, 18v is abnormally high and I shut the engine off immediately after starting it to try the new battery to avoid damage to the ecu.. i can't believe the alternator gave up so early. It's getting towed on Monday to Active to get alternator replaced and then we gotta set up the window memories again as it defaulted due to battery disconnect. I hope I won't have to adjust any electronic setups for the roof mechanism. I can't wait to get her back on the road and enjoy her. Thanks guys, I'll keep you posted..
06-24-2016, 09:12 AM | #30 |
Rep 1,178
Okay thanks I will keep them in mind. Here is the thing that's itching my brain. I posted the link below..the guy said that he had the same high voltage issue after replacing battery but the errors went away after registering the battery which he did not do straight away. Therefore did not need a new alternator. Could battery registration fix my issue by letting the ecu know that the old battery is no longer there and result in registering new parameters of the new battery and re adjusting the voltage? I'm curious because when we replaced the battery this morning, the battery did not get registered as the tool was at the shop. Could it be that the fault is still ongoing because the ecu thinks its still the old battery? Does anyone have a tool I can use to reset the battery to see if the problem will go away before I get it towed on Monday? I'm curious now and think I have a chance of saving the alternator by registering it first to see if I can fix the problem and save myself the money for a new alternator.. What are your thoughts? I could be misdirected to think that it's the alternator when all I need to do is register the battery?? http://www.bimmerfest.com/forums/sho...d.php?t=572496
06-25-2016, 01:39 AM | #31 |
Rep 6,285
This is exactly why the new battery has to be registered as tge battery ages the charge cycle differs to compensate. When a new battery is installed its important to register it as overcharging can occur
06-27-2016, 03:29 AM | #35 |
Rep 1,178
Car should be ready for collection in 2 days as the alternator is being replaced. I'd like to thank you all and member VTL for coming out on Sunday to diagnose and register my battery. Should be good to ler her rip in 2 days. Can't wait!
06-27-2016, 05:23 AM | #36 | |
11 second stock turbo club. 11.6@120mph
115
Rep 1,181
I wish you all the best though and hopefully you have dodged a bullet!
JB4 ISO - 3" Catless Downpipes - RB Inlets to be fitted - BMS DCI - VRSF 7" intercooler - Charge pipe & Raceport BOV - BMW PE exhaust - Stage 2 fuel pump - BMS E85 Flash/ E50 mix, running map7 - NGK Plugs - BMS Catchcan - RB pcv valve - Quaife LSD - 19'' Beyern wheels - Msport suspension - M3 rep sideskirts - Aero front lip - Lux V5's - Mid kick rear spoiler - Dark tint - Msport steering wheel with M3 paddles & trim
06-27-2016, 07:12 AM | #38 |
Rep 1,178
My gawd Heath!! You're giving me a fright. Thank you for the kind wishes and hopefully I have dodged that bullet.. if that happens I'll sell the damn thing i did not drive it for more than 5 minutes once the issues arose. How long did you drive it for to get home?
06-27-2016, 07:18 AM | #39 |
Rep 1,178
Heath I have found this.. did your build date fall in between the following build dates below? Mine is in november 2007 so i should be good. Fingers crossed until Wednesday.
Oh found the extra info: For some of you N54 engine owners out there. SI B 12 18 07 Engine Electrical Systems October 2007 Technical Service SUBJECT N54: Running Issues with Various Faults in DME MODEL E90, E92, E93 with N54 from 6/10/07 to 8/18/07 E60, E61 with N54 from 6/10/07 to 8/18/07 SITUATION Vehicle runs poorly, misfires, and may not start. One of the following fault codes, or the combination of the codes, is stored in the DME: 30BA , 30BB or 2ACC. Subsequent fault codes like 29CC, 29CD, 29CE, 29CF or 2ACB may be stored in the DME as well. Service Engine Soon Light may be illuminated. CAUSE Defective diode in DME. CORRECTION On a customer complaint basis and only if the vehicle is in the effected production range, replace the DME and reprogram/recode the complete vehicle. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Please refer to the latest KSD for all applicable labor operations and allowances. If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used. Defect Code 12 71 00 15 00 |
06-28-2016, 03:26 AM | #40 |
Rep 1,178
Hi guys, the alternator is replaced and turns out that the new battery is faulty. The battery will be swapped for another tomorrow and car should be good to drive.
06-28-2016, 06:27 AM | #41 |
Rep 6,285
06-28-2016, 04:38 PM | #43 |
Rep 6,285
06-29-2016, 05:07 AM | #44 |
115
Rep 1,181
Failed alternator mate. This was a while ago now : )
