M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      04-15-2024, 10:58 AM   #1
Feras89
Drives: BMW F10 M5
How to improve on the track?
I finally got to take my 2013 M5 with manual transmission to the track. I would like your input on how to improve knowing that this was my first ever track day “advanced level on the sim”.
The car is a beast in a straight line but in the corners, not so much. I ran the whole day with traction control on. The traction light was coming on a lot (even in a straight line!). I was not abusing the gas pedal and was smooth in my inputs as much as possible. Corner exit was always hampered by the traction control. Corner entry and mid corner performance was great in sport plus suspension setting. Car is very level and able to hide its weight pretty well. I got so sketched by the traction control that I didn’t dare turning it off.
The other issue was tire pressures. Pressures were 40 after one of the sessions. I had to deflate them a bit (started session with 35). Felt 40 was too loose. Keeping it around 35 was be t for me.
Im running a stage 2 BM3 with cattless downpipes and PS4S 305 tires in the rear. Tires are a couple of months old so pretty new.
What’s your experience with traction control and tire pressures on the track? Is it better to go back to stock tune on track days?
      05-05-2024, 09:13 PM   #2
vafan13
Drives: Sakhir Orange F10 M5
With PS4S on stock rims I'd shoot for 35-36 hot and check for rollover. Chalk is good for this.
I run with MDM mode for traction control. Regular mode is going to really limit you and likely wreck your rear pads.
I probably wouldn't run a stage 2 on track but you're catless and if your oil and coolant temps stay OK, you're probably fine.
If you intend to track it with any regularity, do yourself a favor and buy some 19x10.5 track wheels and run 305/30r19 200 tw tires. Be happy to talk more about this if you dm me.
tire pressure, track, traction control
m5post
