Is swapping my catless DP out every year my old option?
10-07-2014, 06:25 AM | #1 |
18
Rep 177
I'm running a berk catless DP and need an inspection. Is swapping my catless with the oem the only option for passing?
I have searched a lot and found things like mini cats u put between the DP and sensor but I can't find anyone who's done it and reported on inspection. If I do have to swap my oem DP back in do I need new gaskets?? Do I need two sets of new gaskets? One set for oem DP and inspection and the other set for when I put the catless DP back on after? Thanks in advance Rob
2011 335i e90 MT
Cobb AP3 Tuner, FMIC, CP, DP & Exhaust Afe Stg 2 Intake - Factory PPK v2 Ohlins R&T - M3 suspension bits Spec Stg 2 Clutch Kit & Alum Flywheel, Qualfe LSD |
10-07-2014, 07:31 AM | #2 |
Rep 1,739
I swap mine every time; it's a real pain in the ass. Don't think any of the other options have worked for very long.
Instead of replacing gaskets every time, I just use this orange sealant (forgot what it's called). It's like making a rubber gasket every time. |
10-07-2014, 08:32 AM | #4 |
324
Rep 2,014
You could find a shop that will pass you. Join some of the local clubs in DFW and ask around.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
10-07-2014, 08:38 AM | #5 |
Rep 412
10-07-2014, 12:39 PM | #6 |
Rep 917
Do they do a sniffer test or read the OBD codes in TX? Here they just do a "visual inspection" so if you just have something that looks like a cat they'll pass it.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
10-07-2014, 05:26 PM | #8 |
34
Rep 394
Yeah here in CA I know a few local shops that will pass anyone, only for some extra $$
MHD- VRSF Catless Downpipe - VRSF Charge Pipe - VRSF 7" FMIC - aFe Intake - Alpina Flash - Pure Stage 2 - Pure Inlet - Fuel it! PI - Fuel it! Stage 2 LPFP - N20 3.5bar Tmap sensor - N20 spark plugs -
10-07-2014, 10:24 PM | #9 |
18
Rep 177
In Texas they only hook it up to computer. Two of my sensors read not ready so can't pass.
I can't believe there isn't a better option than switching it out each time. Do u do it urself??? Pita! I ain't got no time for that!
2011 335i e90 MT
10-07-2014, 10:43 PM | #10 | |
Rep 583
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
10-08-2014, 12:31 PM | #11 |
18
Rep 177
I'll try that next
2011 335i e90 MT
