F30 Performance brakes in E92 335i
10-10-2023, 09:19 AM | #2135 |
Rep 4
I have a question that I have tried reading through the pages for the answer. Maybe I missed them?
I have a 2009 e90 328i. Recently got the m performance brembo front (370mm) and rear (345mm) with rotors. Front is in, waiting to get the rear calipers back from machinist. My question is: for the rear parking brake, do I need to put 335 rear parking brake since 328i has smaller parking brake? (to accommodate the 345mm rotors) If so, do I need to change the knuckle? Thank you in advance. Learned a lot from this thread |
11-29-2023, 12:24 AM | #2136 |
Car Enthusiast
911
Rep 1,309
Drives: E92 328i 2007 SC
Basically just a 328 brake pad spring/seat attachment welded to a 335 brake shoe. Don’t know where my pictures are but I bet if you search something regarding 328/335 rear pad conversion I bet it will pull up. Or go back through the conversation. Good luck and you will love the setup.
Guess you can look for my posts. I definitely posted about it and just had a muffler shop cut and weld it for me. And I was not the first one to do it for sure.
E92 328i|6MT|ESS SC VT-1 (G.2)|3 stage|22 RPD SC/Meth tune|AA Headers|Snow Performance Meth Injection|Rotiform KPS|R139|PS4S 275.245.19|M3 front|M3 side skirts|MTEC rear|Akrapovic C tips|Koni Sport (Yellow)|Eibach PS|Hotchkis SB|C high-kick spoiler|C mirror Covers|C trim|LCI tails|M3 Control arms|M3 MS|Black E trim|Black kidney's|Full LED Conv|BMW F30 370/345 BBK|ECS SS|ECS Strut Tower Brace|034 Engine-Trans-Rear Mounts
12-06-2023, 03:04 PM | #2139 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Not true. The M3/M4 came with a 18 inch wheel, the 513. I run them on my 335is with the 380mm rotors
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
12-12-2023, 12:35 PM | #2140 |
29
Rep 60
I installed brakes on a Bmw E92 from a Bmw F82 380mm/370mm.
Tell me, is it necessary to install the brake master cylinder and vacuum brake booster from M3E92? I currently have the master cylinder and vacuum booster installed from a 325i. Last edited by Igor.v_a; 12-12-2023 at 01:16 PM.. |
Seattlesquash911.00 |
12-12-2023, 01:16 PM | #2141 | |
Rep 531
Drives: 2007 E70 4.8i, 2008 E90 335i
The M3 master cylinder should be installed or you might not be pushing enough fluid for the larger brakes. The larger cylinder will also make the pedal more firm and require more effort to push. I have e90 M3 brakes on my 335i and I didn't change the booster. The booster is the amount of assist you get rather than the amount of fluid you move so it is optional. Some have said that the M3 and 335i booster are the same but they are a different part number so the M3 likely has a different amount of brake boost. The M3 booster may offer more assist to counter act the larger master cylinder which would increase pedal effort. Or they could have said "this is a performance car, the brake boost should be less and the driver should have to apply more effort than what a non performance minded driver would expect." I wouldn't bother changing the booster unless you feel the pedal effort is too high. It should be higher than stock with the M3 master cyl given that it has to move more fluid in the same stroke. I haven't it to be too firm for me or my wife with the e90 M3 brakes and a regular non M booster. It seems fine to me without going through the hassle changing it.... I even have and M3 booster that came with the master cyl and didn't bother with it. Does anyone know if the e90 M3 booster has more or less assist than the non-M?? The 335i and 325i seem to have the same booster. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
12-12-2023, 01:21 PM | #2142 | |
29
Rep 60
But vacum amplifiers are different. |
12-12-2023, 04:09 PM | #2143 | |
Rep 531
It would need a check valve (and/or a pump), so that it holds vacuum under boost. At least that is how other more simplistic turbo cars that I have owned work. I haven't looked that closely at my 335i actually. Or do you just mean brake booster by "vacuum amplifier" I thought I checked the boosters and they were the same for hte 335/325. -Rich
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. Last edited by rbryantaz; 12-12-2023 at 11:48 PM.. |
12-12-2023, 04:58 PM | #2144 |
Rep 552
i would, after upgrade it felt little softer and longer travel, m3 master only fixed it.
12-12-2023, 11:26 PM | #2145 | |
29
Rep 60
But, if it is possible to improve the braking system by installing a master cylinder and vacuum booster from the M3E92, I would like to do it. I would like to understand whether it is worth doing this or not. How much does this improve the braking system? |
12-13-2023, 12:45 AM | #2146 | |
Car Enthusiast
911
Rep 1,309
12-27-2023, 03:47 PM | #2148 |
Car Enthusiast
911
Rep 1,309
Not a coding expert but you can do it yourself. Set to performance brake option, or take it to independent shop w scanner etc, what I did and paid like $50 and took 5 min + he coded out my bulb check as I did a full LED conversion and did not want to mess w any resistors.
01-03-2024, 09:51 AM | #2149 |
37
Rep 80
I'll have to look into coding for my setup of the Fxx 340/345mm Brembos combined with an E9x M3 master cylinder. The initial bite isn't as strong nor the pedal as firm as stock, but the brakes are still very effective.
05-01-2024, 11:39 AM | #2150 |
198
Rep 263
Hey guys,
I'm about 90% done with this upgrade but I have my 2cents. The rear brake conversion on specifically, the all wheel drive LCI rear hub is very tight, if not 'barely' fitting. It looks as if there is a tighter tolerance between the emergency parking brake and the ears of the rear caliper. As such, fitting the Fxx rear caliper w/ an adaptor has much less tolerance and in fact, everything is a SNUG, SNUG fit. I have to use a rubber mallet to get the caliper into place. I haven't run the car yet but the caliper ears now touch the parking brake backing plate.
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam |
