BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Share your BimmerTech PP82DSP Amp Tune Files **Updated 01/15/18
ARMA SPEED
      08-02-2016, 04:38 PM   #89
Bimmer_pnoy
Bimmer_pnoy's Avatar
Drives: 2015 335i xDrive
Smile
Does anyone have a tune for a F30 BSW stage 1 and BSW ghost underseat subs? Thanks
      08-02-2016, 05:36 PM   #90
RoarinRow
RoarinRow's Avatar
Drives: 2012 328i Glacier Silver
2012 BMW 328i  [0.00]
2014 BMW X1  [0.00]
I use this one for my F30 BSW stage 1 and BSW ghost subs. I like it the way it is. To use the file just remove the .pdf extension.
2012 328i Sedan - Glacier Silver - 18" Toyo Proxes 4 Plus Tires with Nürburgring Metal Grey Rims, H&R Sport Springs, VRSF Intercooler, JB+, aFe Air Filter, Magnaflow Exhaust, Carbon Fiber accents, SS Pedals, Bavsound System, BMW CCA member since 2015. First Bimmer - 2000 Z3 M. Second Bimmer - 2014 X1 sDrive28.
      08-02-2016, 05:41 PM   #91
Bimmer_pnoy
thank you very much I'll give it a try.
      08-02-2016, 05:57 PM   #92
RoarinRow
RoarinRow's Avatar
2014 BMW X1  [0.00]
Most welcome! Good luck!
      08-08-2016, 10:58 AM   #93
MCamachoF80
MCamachoF80's Avatar
Drives: 2015 YMB M3
This tune would work well for F80 with the same set up right?
      08-08-2016, 12:41 PM   #94
RoarinRow
RoarinRow's Avatar
2014 BMW X1  [0.00]
Sorry can't speak of the F80. I guess you can give it a try and make adjustments in the DSP app.
      08-11-2016, 02:55 AM   #95
Hyperlink
Drives: 2013 328i xDrive Sport Line
Amp cutting out
Has anyone run into an issue with this amp where you modify some of the settings and the sound turns off when played at full volume during highway driving or something (all speakers go silent)? I modified the BimmerTech file provided by Nelson for the F30 and it cuts off. The only real change that I made was setting the gain/output level on the 2 rear speakers to 0 instead of -2. Curious to know if other people have run into the same problem when tuning the amp for their liking.
Edit to included some additional details.
Upgraded from regular HiFi to BimmerTech Amp
Dip settings for 2 and 4 are set to on.
File Type: pdf Hyperlink - F30 BimmerTech Baseline Modified.afpx.pdf (1.7 KB, 191 views)
      08-11-2016, 10:32 AM   #96
ttomczak
ttomczak's Avatar
Drives: 2015 X5 3.5 M-Sport
Has anyone done a 428 Gran Coupe (F36) with the stock Hifi tune?
Thanks!
2015 F15 X5 3.5i M-Sport SG
Past Rides:
2001 E39 Dinan 5 - 2006 E63 M6 - 2007 335i E93 -
2007 X5 E70 4.8i - 2010 X5 E70 3.0i
2016 428ix M-Sport Gran Coupe - 2014 E71 X6M
      09-04-2016, 03:22 PM   #97
Nelson@BimmerTech
Drives: 2014 M6 GC
New TUNE Alert :
F36 Gran Coupe with Full Bavsound speaker upgrade including ghost underseat woofers.
https://drive.google.com/open?id=0B9...VpUcjZMbjZxOW8
      09-14-2016, 01:28 AM   #98
MBMW
9
Drives: 2014 650i GC
Tuning file for F16 MY15
Sorry guys I know this is a F30 forum but I need help to tune PP82DSP to install in my X6 with OEM speakers and HiFi (676) option.
I'm hoping that someone managed to tune the amp in an F16 to give me a starting point rather than starting from scratch.
It would've been nice if the DSP had an auto tune feature
I also need a harness, contacted Technic and Binner-tech but nothing yet
Thanks guys
      09-14-2016, 02:50 AM   #99
Lancelot
France
568
Drives: 2017 m550i
Thanks guys
Well it does have one via the autiotec fischer software, you need to purchase an additional measure microphone to do that, like this one which worked very well for me https://www.minidsp.com/products/aco...urement/umik-1
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      09-15-2016, 08:33 AM   #100
mateusz0147
Drives: BLACK 2015 BMW 328I XDRIVE
i have this same problem and i use just use the bimmertech tune. does any1 have a fix for this. my car is set at 0 and 0 and dip settings for 2 and 4 are also on.
      09-16-2016, 02:30 AM   #101
Lancelot
France
568
Drives: 2017 m550i
Dip switches are of no use here;
I had the same issue, and it's gone since I restarted my configuration from scratch, instead of bimmertech files.
I think it is related to the signal input detection switches, they are supposed to switch if a signal is above a given threshold => try to disable auto switching altogether and see if that works.
DCM Menu => Signal Management tab => AUX source selection set to manual and see if that resolves.
      09-28-2016, 09:00 PM   #102
n55silverado
mercenary
n55silverado's Avatar
Drives: 2021 X5
I am running the BavStage1 tune provided by Nelson. At about 75% volume I experience the same thing that other's are experiencing.
After resetting can I load a bimmertech tune?
      10-11-2016, 05:15 PM   #103
NickyNoNeck
Drives: 2011 335i xDrive Jet Black
Same issue with sound cutting out because of rear speakers. Have Helix Blues in the back. My inputs are set to manual. I had to cut the gain down to prevent it from happening. Was going to reach out to Audio Fischer to see what they suggest.
      10-14-2016, 10:48 AM   #104
Hyperlink
Hi NickyNoNeck ,
Good idea. Let me know if you get a response from Audio Fischer regarding this issue. It's annoying that I have to tune down my gain just to get the audio not to cut out.
      10-15-2016, 06:10 PM   #105
Nelson@BimmerTech
Drives: 2014 M6 GC
Hi NickyNoNeck ,
Are you guys using stock tunes? If not what kind of modifications are you doing to the tunes?
      10-16-2016, 04:10 AM   #106
MSportTune2
Aland Islands
80
Drives: F30 MSport
Anybody has a BimmerTech RHD tune for BSW + ghost sub?
      10-20-2016, 02:29 AM   #107
Hyperlink
Hi Nelson,
My changes to your original F30 tune are attached to a post I previously made in this thread (#95). The intent of my changes were made to make the car's audio experience similar for each passenger (not driver oriented) and also provide more bass to the front and rear door speakers (the door spears are pretty capable of providing decent bass from my test tunes).
1. I modified the slope to -12 for the center, front, and rear speakers. When I tuned my alpine system (800w amp) in my Mustang we used -6 db/oct and -12 as 24 dB/octave lead to us hearing where the sound responses started to fall/cut off.
2. Slope on the sub woofers were also changed to -12db/oct. Similar reason as above.
3. I changed the gain on the front and rear to 1db as the rear was sent to -2db and the fronts were set to 1db. This way the same amount of gain is going to the door speakers.
I tried to tune my custom build from scratch using a flat tune (similar to arminvb's tune), but I had to reduce the gain on all channels significantly before I got to point where it would stop cutting off. Even in arminvb's tune the gain was tuned down to -5db on the center, front, and rear speakers which is kind of what I ended up doing. In the end I was better off just using your custom F30 tune with a few modification to the center, front, and rear.
I'm still really happy with the purchase and would recommend this amp to anyone with the F30 tune, I'm just trying to get the loudest sound with the least amount of distortion. I know that this amp is very capable so I'm just going to keep messing with the tunes.
Once I get this polished up I'll buy myself the BimmertTech reverse camera.
      12-06-2016, 11:28 AM   #108
eatsleepblink281
32
Drives: 2019 X3 M40i
Wanted to see if anybody has more tunes they can share so I can try for my car with Bimmertech amp with standard hifi speakers? Thanks
      02-22-2017, 06:09 PM   #109
Nelson@BimmerTech
Drives: 2014 M6 GC
I know quite a few of you have been waiting for this tune. F30 Bavsound speakers with Ghost woofers.
https://drive.google.com/open?id=0B9...XFaWDZ5akZkV0k
      02-22-2017, 08:42 PM   #110
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
List Updated page 1
My Build Thread can be found HERE
