RB cap review and RB cap/Valve install
12-22-2014, 09:15 AM | #45 | |
Rep 1,643
2007 E92 335i MT
01-14-2015, 10:40 PM | #46 |
Rep 23
02-02-2015, 01:53 PM | #47 |
30
Rep 216
Unable to get the RB cap in
Hi All,
Attached is the image of my RB cap. I'm having issues actually screwing it in. I'm being very careful and trying not to over-tighten it, but it doesn't seem to go in anymore than it has now. Any ideas? http://1drv.ms/1DpyI7V Thanks, John |
02-02-2015, 03:22 PM | #49 |
24
Rep 31
The cap is indeed a work of art, but I had the same problem - the cap would thread in straight, but 'tighten up' at the same point shown in the photo above. I didn't want to give it too much force and potentially ruin my intake manifold, so I'm still running the plastic one, which threads in with no issues (so we know the valve is in straight).
02-02-2015, 03:39 PM | #50 |
Rep 1,571
Hey guys.
This is the first we have heard of this. Wish you would've emailed as we don't test fit each unit, so perhaps there was/is some batch issue. Apparently we need to test fit what we have to ensure they are all good. If you would be so kind as let us know when you ordered as well, hopefully not as of late because we just had like a hundred or so made... You two and any other who may have the same issue send them back and we will get you out another that is test fitted. Sorry about the inconvenience, thought our machine shop had the production on this unit rock solid by now but apparently not. Thanks, Rob |
02-02-2015, 03:44 PM | #51 |
30
Rep 216
02-02-2015, 03:45 PM | #52 | |
Rep 1,571
When did you purchase? |
02-02-2015, 03:46 PM | #53 | |
30
Rep 216
I bought it from you over a year ago, but I did not touch the PCV Valve myself until recently when I had walnut shell blasting done. I just checked it was December of 2013 and I e-mailed you. |
02-02-2015, 03:49 PM | #54 | |
Rep 1,571
I'd say we are either looking at a blem'd unit (or some #), something install related, or a quite of few quiet consumers lol… Rob |
02-02-2015, 03:53 PM | #55 |
Rep 1,681
Mine looked like that and it was because I had not seated it correctly. I didn't realize it until I went to install it and it wouldn't screw on all the way. After I took it back off and made sure it was on all the way, it installed fine. Mine was purchased probably around the same time as yours, maybe January 2014.
02-02-2015, 03:54 PM | #56 | |
30
Rep 216
Do you think you might be able to send out a test fitted unit for me? I can pay for the part, it's no big deal. I just hope the PCV plastic part is not cross threaded already. |
02-02-2015, 03:55 PM | #57 | |
30
Rep 216
02-02-2015, 03:55 PM | #58 |
Rep 1,571
I just test fitted 5 random units from our latest batch. All perfection.
If you guys believe your unit is incorrectly designed, send it back and we will get you another. I do not want to rule out that we had a "bad batch" somewhere along the line, but its the first we have heard of anything if we did. Thanks, Rob |
02-02-2015, 05:14 PM | #59 |
Rep 1,004
http://imageshack.us/a/img197/3171/7ohv.jpg
hey rob i just realized when i installed my valve back in september i used the oem plastic cap, i shaved some of those 4 plastic tabs shown in the first pic of your cap down to get the pcv to fit in the oem cap, i have to pull it out when the snow clears but how bad would it be if there was no space between the pcv and the cap? meaning i cant remember if i cut the tabs off altogether. thanks Last edited by mike082802; 02-02-2015 at 05:15 PM.. Reason: clarification |
02-02-2015, 05:28 PM | #61 | |
30
Rep 216
1. Ivan unscrewed everything, took the RB PCV valve out too. 2. He tried to put the cap in with the O-ring without the valve and felt the same resistance. Took the cap back out. 3. He took the O-ring off and was able to put the cap fully in, it felt really snug though. At least that verified nothing was cross-threaded and he could feel the resistance. Then took the cap back out. 4. He then fully seated the RB PCV valve in first, tightly. 5. He then put the O-ring back on and was able to put the cap completely in and the thread was definitely not stripped. Sorry for the false alarm, but if anything, the RB cap is a very snug part. :P Figured I would give everyone a heads up. Thanks for the DIY robc and Rob Beck for your attention! |
02-02-2015, 07:46 PM | #62 | ||
Rep 1,571
Let me know. They are in stock. Quote:
Thanks, Rob |
02-02-2015, 08:00 PM | #64 | |
Rep 1,571
Thanks, Rob |
02-22-2015, 03:05 AM | #65 |
Rep 56
I was under the same impression when I installed RB's valve and OCC. The OCC was never catching any oil and I thought it is useless after the PCV upgrade... until I had to replace the valve cover gusket. I disassembled the breathing tube and left it on my table overnight. In the morning I found significant amount of oil on the table. Guess what, that oil never reached the OCC and was accumulating in the tube! I guess the OCC is installed higher (or the tube runs higher) than the PCV/valve cover.
02-22-2015, 03:12 AM | #66 | |
Rep 4,764
I really have no way to take it off right now. I will try ordering a new one the next time I get some maintenance done (maybe in the summer of '15). Thanks, Scott |
