BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Additional Rubbing?
proTUNING Freaks
      03-31-2024, 08:36 PM   #1
mprotacio
13
Drives: 2017 440i xdrive
Additional Rubbing?
Im currently running 19x8.5 et 35 on 255/35/19 squared pireli winters and im rubbing on full lock out and i was wondering if itll get worst if i lower the car on H&R Springs or coil overs? Was also looking to get the same size set for summers.
      04-01-2024, 10:03 AM   #2
weehe126
Drives: 2017 340i
You shouldn't be rubbing with that tire size. Where in the wheel well are you rubbing?
      04-01-2024, 10:04 AM   #3
mprotacio
13
That’s what Alohatoad told me. I’m rubbing on the inner fender on full lock.
      04-01-2024, 11:06 AM   #4
alohasurftoad
Drives: 440i gran coupe w/mppsk
I have noticed that winter/snow tire shoulders are often more square and tread width wider, which causes it to be broader/meatier than a non winter/snow counterpart in a given size.
I dont believe you'll have the rubbing issue with a 255/35/19 summer.
when you lower your car, slight neg camber is added which changes the orientation of the tire as it rotates about the kingpin axis, when turning the steering wheel. also the point of contact where the tire was rubbing (unlowered), also shifts higher on the liner.
I have noticed full lock rubbing is often eliminated from lowering. It would be interesting to see if lowering eliminates the rub with your winter/snow tires...
      04-01-2024, 11:14 AM   #5
mprotacio
13
Originally Posted by alohasurftoad View Post
I have noticed that winter/snow tire shoulders are often more square and tread width wider, which causes it to be broader/meatier than a non winter/snow counerpart in a given size.
Hmm interesting haha I will test and get back to you then!
      04-01-2024, 11:20 AM   #6
mprotacio
13
Also I don’t think I can add camber if I run springs 😅
      04-01-2024, 11:42 AM   #7
alohasurftoad
on macpherson type fronts, with a lowering spring, the spring/damper assembly is shorter and the the angle of the kingpin axis changes slightly. the geometric change results in the slight negative camber being incurred.
      04-01-2024, 12:07 PM   #8
mprotacio
13
Ahhh that’s for clarifying! I’ll throw in an update when everything is done!
      04-01-2024, 04:06 PM   #9
mprotacio
13
Oh also what are your thoughts on rubbing 245/35/19 instead. 👀
      04-01-2024, 04:36 PM   #10
alohasurftoad
245/35/19 will definitely not rub
      05-10-2024, 11:32 PM   #11
mprotacio
13
Finally got an update here. 19x8.5 et 35 lowered on h&r sport springs. 255/35/19 Pirellis. No more rubbing on full lock
