TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      07-17-2019, 06:15 AM   #1
aggressor_eg
Drives: BMW X5
BMW X5 E70 Error Code P0019
Would you please help to solve this issue in my car
my BMW X5 2009 has Low Oil Pressure warning in the dashboard, the RPM is not stable and fluctuating, also the motor performance is significantly degraded.
I flushed the OIL however this issue not solved.
I did online research and some threads mentioned something about changing the crankshaft sensor, I'm not sure if this will fix the issue?
I did an OBD scan I got the below error code:
VIN retrieved from Vehicle
VIN: WBAFE81099L095076
Make:BMW Year:2009
----Confirmed Trouble Codes Scan Report----
4 Confirmed Trouble Codes Trouble Codes:
1. P0019
Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor B
2. P0302
Cylinder 2 Misfire Detected
3. P0300
Random/Multiple Cylinder Misfire Detected
4. P0303
Cylinder 3 Misfire Detected
      07-17-2019, 06:55 AM   #2
ryansbmw
Drives: 2013 X5 35i M-Sport, 2010 535x
Im not sure if the oil pressure light is related to the codes, but since your codes tell you the camshaft sensor is faulty I would get that fixed 1st. A failing sensor will absolutely mess with performance of the engine.
VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
Need coding or modules reset? PM me
      07-18-2019, 04:27 PM   #3
aggressor_eg
Drives: BMW X5
Thank you for your reply
I did find some factory manual troubleshooting suggestions:
P0019
Exhaust camshaft 2, tooth offset to crankshaft
Possible causes:
- Cam sensor
- Solenoid valve
- Timing
- VANOS servo unit
- Timing chain
      08-12-2019, 10:08 AM   #4
kcotton
Drives: X5 35d
Please help me to understand...
Sensors seem to have a much higher failure rate then the physical parameter that the sensor are supposed to monitor... So why not simply remove sensors?
Every time a got a check engine light, they replace a sensor but not the thing that could cause the real issue.
      04-17-2024, 07:19 PM   #5
SupermanSpec914
SupermanSpec914's Avatar
Drives: 10 X5M 06 M5 06 Carrera S
just giving a lead to anyone who may come across this old post. I had crankshaft camshaft codes vanos codes, random misfires 4,5,6,8 exhaust turbo charger coolant pump. dsc codes. in short everything going wrong. Disconnected the ibs and reset adaptations. everything is gone. IBS was faulty
xbimmers
