BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 2013 N55 xDrive water pump go bye
ARMA SPEED
      03-13-2024, 01:59 PM   #1
Stellarxz
Stellarxz's Avatar
15
Drives: 2013 BMW 335i
What’s up yall,
So a couple days ago I turned my car on and saw a beautiful check engine light. Opened up the hood and saw a lot of coolant in the coolant tank and couldn’t hear the pump running, so assumed the pump finally went, it’s a 2013 335 with 130k miles and original pump. Checked for codes and saw the following:
- DME active codes -
120208 - Charging pressure control, plausibility
Pressure too high.
120408 - Charging pressure control: Switch-off as consequential reaction.
1A2108 - Electric fan, self-diagnosis, interval stage 1:
Minor fan fault.
CD9010 - LIN, message; electric coolant pump: Missing.
- Transmission active codes -
421722 - DME/DDE interface: Forced upshift due to thermal engine protection request or signal invalid (switch status, warm-up, powertrain, 0x3FB).
So i dropped the car off at a shop near where i am right now and the guy was saying something abt him getting a code that the pump “shorted”, and gave me a quote for $1650 to replace the pump, thermostat, and sum wiring harness thing, all OEM from bmw, and 200 of that is for diagnosis.
So tldr, How do-able is this on my own with it being an xdrive and all, most i’ve done in the past is replacing the valve cover on this car so how difficult is it if i bought the parts from FCP and did it on my own? Also is the quote this guy giving me realistic or should i try to find someone else to work on it? Im located in mass so any suggestions are appreciated!
      03-13-2024, 02:08 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
I think the water pump is less tricky than valve cover, but may depend on your ability to lifting the car up easily/reliably for access. Watch some water pump videos and you'll get a good sense vs. valve cover difficulty.
      03-13-2024, 02:10 PM   #3
Stellarxz
Stellarxz's Avatar
15
I can get the car up on jack stands idk if that’s good enough but i haven’t been able to find any videos on an xdrive, i’ve heard it’s a lot harder? Also any videos u would recommend?
      03-13-2024, 04:47 PM   #4
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
It's not a huge deal tbh
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-13-2024, 05:02 PM   #5
thejeremyman9
4364
i thought kies had one, just search youtube.
      03-14-2024, 09:31 AM   #6
Stellarxz
Stellarxz's Avatar
15
Couldn’t find anything from kies, but ur saying it’s not any different from a non xdrive, and it’s do-able on jack stands? In that case i might go ahead with it, should i go with an OEM pump and t-stat or is the
pierburg OE one fine?
      03-14-2024, 12:05 PM   #7
thejeremyman9
4364
I dont have an xdrive so can't comment on that, and no experience with pierburg
      03-14-2024, 12:26 PM   #8
Stellarxz
Stellarxz's Avatar
15
What abt the mechanic saying something abt it being shorted? He says he got a code that something shorted so that even if i replace the pump it will not work cuz it’s gunna short out again?
      03-14-2024, 01:38 PM   #9
celsdogg
E4 Mafia
325
Drives: E30, E36/5, E46, F22, F30
1990 BMW 325i  [0.00]
1998 BMW 318ti  [0.00]
2003 BMW 325i  [0.00]
2015 BMW 335i  [0.00]
2015 BMW M235i  [0.00]
Seems like that is the way they fail (water pump starts at 11:06):
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
      03-14-2024, 01:56 PM   #10
Stellarxz
Stellarxz's Avatar
15
https://youtu.be/rPUUNhjJjHU?si=WMIIV8QRoZJOSb0X&t=667
So when my guys getting a error that something shorted it basically means that the control module inside the pump probably shorted but the wiring for it should be fine?
      03-17-2024, 12:09 AM   #11
WajahatM
Drives: 2013 AW F30 335i xDrive
Honestly man I did the valve cover+gasket which is pretty straight forward. Literally just moving some wires out of the way, remove fuel rail, and the strut tower brace. Then hella bolts for the valve cover. The hardest 1-2 bolts to access are passenger side in the back. You have to be creative with extensions and swivel attatchments. I think I used 6”+swivel+3”+swivel+1”. I also used an extendible mirror with a light to get a better visual on the bolt which helped a lot. Tbh the part that made it hard/annoying was when I was done and torquing down the bolts and I got to the last one, the head snapped. It’s bc I reused all the old ones. I had to take everything back off, then was able to get out the broken bolt with pliers, no drilling needed. Scary af tho. Just hand tightened them after. Gotta be careful with aluminum bolts bc when they’re torqued once, they stretch bc they’re soft and are prone to breaking easily.
For water pump honestly the clearance is kinda hard. My car has been running on the warmer side and I was going to preemptively change the water pump. I ordered it from FCP euro, lifted the car, then realized it’s gonna be a pain to reach one of the bolts. Would be much easier if I dropped the subframe. So I just returned the part tbh. I plan to change my oil pan with gasket to a baffled one and I’ll do water pump then. Thermostat is pretty easy tho.
