10-31-2019, 01:06 PM | #89 |
639
Rep 1,029
Don’t ignore your worn down brakes! 🤯 If you’re experiencing loss of braking power, or wobble during braking, it’s time to replace your rotors and pads! All of our experts will make sure you’re back on the road safely and with better braking power! Don’t wait till you rear end someone in a sudden stop! 🤣 Don’t hesitate to contact us for your braking needs. Just send us a PM or call us! Easy. 🙏 📞: +1 (800) 438-2808 Text: (949)-558-6307 |
11-04-2019, 01:56 PM | #90 |
639
Rep 1,029
BOOTMOD3 TUNE LOADING... 😈 When you pair this tune with our SSR Downpipes; it turns into a whole different monster than stock! 🔥 Why you ask? You’ll gain horsepower and torque, higher RPM limiter, and the desirable burble exhaust note! All available here at SSR Performance! 🙌 PM us for any questions! Call 1-800-438-2808 Text 949-558-6307 |
11-06-2019, 01:56 PM | #91 |
639
Rep 1,029
Freshly installed Maximumpsi Crankhub on this F80 M3! 🔥 Imagine tracking this M3 without a single worry about the Crankhub?! This can be you, we’re only a call or PM away! PM us to get started today! 📞: +1 (800) 438-2808 Text: 949-558-6307 |
11-13-2019, 02:32 PM | #92 |
639
Rep 1,029
⚠️ CRANK HUB FAILURE = ENGINE FAILURE ⚠️ Attention F8X S55 owners! Are you aware about the OEM Crankhub Issue? The original crank hub is flawed because it allows the timing gear to spin independently from the crank! Worse case scenario, the valves contact the pistons requiring a complete overhaul! 🥵 Unfortunately, it’s unpredictable and happens to all DCT, manuals, stock or modified engines! We had to replace engines due to this HUGE flaw. We offer and install the solution here at SSR! The MaximumPSI keyed Crank Hub! This allows you to drive hard as you want, without any issues! This procedure requires extensive work and an experienced tech to do this work. Fortunately for you, we service these S55 crank hubs often so you have the peace of mind. 👨*🔧 If you’re interested, or have any questions, please PM us or call us. We will be ready to assist you. 📞: +1 (800) 438-2808 Text : 949-558-6703 |
11-14-2019, 01:01 PM | #93 |
639
Rep 1,029
http:// You asked, we delivered! �� WE’RE GIVING YOU 30% OFF ON ALL H&R LOWERING SPRINGS! Get your car looking AMAZING, and perform even BETTER for LESS! �� This deal only will last until Black Friday so start calling our phones or PM us to get your set installed ASAP! �� (special only applies with installation) ��: +1 (800) 438-2808 (Say your from the forum and ask for mark) Text: 949-558-6307 |
11-15-2019, 01:46 PM | #94 |
639
Rep 1,029
Today’s 2010 E92 M3 OEM Rod Bearings are out! This particular set wasn’t too bad for 92,568 miles on the clock. We’ve seen worse with 25,000 miles, but you should still get the Rod Bearings upgraded no matter how you drive your car! This applies to all S65 engines! If you happen to own an S65, this is a MUST NEED! Don’t wait till it’s too late. Simply give us a call today get started; our experts will be ready to assist you! ⚙️ PM us to get started today! 📞: +1 (800) 438-2808 (Mention your from the forum) Text: 949-558-6307 |
11-16-2019, 07:58 PM | #95 |
2361
Rep 2,960
When Mission Performance (Alex) recommended I gap my plugs after my engine and tranny tune (not necessary but suggested) - I went to SSR and had them take care of things. While there I enjoyed watching them work on a couple exotics while wrenching on my lowly 340 HA. Top notch guys.
11-18-2019, 04:50 PM | #96 | |
639
Rep 1,029
Regards, Mark De Guzman SSR Performance |
11-18-2019, 04:55 PM | #97 |
639
Rep 1,029
Time to have some fun with this M2 Competition! 🏁 We are upgrading his turbos to Pureturbos Stage 2 Turbos and upgrading his CrankHub! 🙌 Boost weather is coming sooo....❄️😉 PM us to get started today! 1 (800) 438-2808 |
11-19-2019, 02:47 PM | #98 |
639
Rep 1,029
VRSF Intercooler is about to get installed on this E90 335i for maximum cooling and performance! 💨 Gain more consistent power figures for longer periods of time ideal for racing. PM or call us to get started today! 📞: (800) 438 -2808 (Say your from the forum and ask for Mark!) Text: 949-558-6307 |
11-20-2019, 01:04 PM | #99 |
639
Rep 1,029
Another fun N54 project in the works! Precision turbo paired with the Doc_race kit installed properly by your finest truly! 🔥 Anything from a 600LT to a 335i; we can work on it all 😈 We’re only a call away to make your dreams come true. PM us to get started today! 📞: (800) 438 -2808 (Say your from the forums, ask for Mark!) Text: (949)-558-6307 |
11-21-2019, 01:00 PM | #100 |
639
Rep 1,029
New OEM Flywheel & Clutch getting installed on this 328i! 🏁 His old flywheel and clutch were toasted and it was time for a fresh setup! We work on all transmission types and do all services! If you’re in need of any type of transmission services, please call us or PM us now! ⚙️ PM us to get started today! 📞: (800) 438 -2808 (Say your from the forums!) Text: 949-558-6307 |
12-02-2019, 01:29 PM | #101 |
639
Rep 1,029
We are doing a BMW F-Series Dyno Tuning Special! Get your BMW SSR Dyno Tuned for $1,299! 🤯 91OCT, 100OCT, and FULL E85 tunes available! Get more out of your car with SSR Performance! Call us for more information! _____________________________________________ PM us to get started today! 📞: (800) 438 -2808 (Say your from the forums) Text: 949-558-6307 |
12-04-2019, 11:48 AM | #102 |
639
Rep 1,029
POWERHOUSE 💪 Another M4 with Pure Stage 2’s, Intake, and Chargepipe in for a SSR Stage 2 Dyno Tune! Get the most of out of your BMW F Series with SSRperformance Dyno Tune today! 🏁 Video and numbers coming soon! 💻 _____________________________________________ PM us to get started today! 📞: (800) 438 -2808 (Say your from the forum) Text: 949-558-6307 |
12-07-2019, 06:23 PM | #103 |
639
Rep 1,029
Treat your F8X S55 with some SSR Goodies for the holidays! Check out this SSR Power Pack 2 custom powder coated to match this Yas Marina F80 M3! Gain comfort and power knowing your Chargepipes won’t explode under load and gain horsepower with our SSR intakes engineered for maximum performance. All in stock and available through our website or in-store. Installation also available in-house. Please give us a call or PM for more information! _________________________________ PM us to get started today! (800)-438-2808 Text: (949)-558-6307 |
12-10-2019, 12:07 PM | #104 |
639
Rep 1,029
Returning customer equipped with our SSR Stance Package came back for a service! What does the F8X SSR Stance Package comes with you ask? Emmotion Lowering Springs, and SSR Spacers resulting in a nice, clean stance for ONLY $450 FREE SHIPPING! Lower about 1 inch all around with improved spring rates for enhanced handling! Installation in-house available. _____________________________________________ PM us to get started today! 📞: (800) 438 -2808 Text: 949-558-6307 |
12-12-2019, 01:51 PM | #105 |
639
Rep 1,029
Prepping for surgery! Thankfully another BMW S65 E92 M3 will be saved with upgraded Rod Bearings with ARP Bolts! Unfortunately the OEM Rod Bearings fail and can cause catastrophic engine failure! If you want to learn more, please watch our YouTube channel explaining more about the process. Simply search “SSR Performance” in the search bar. If you’re in need in this service, please PM or call us today! 📲 _________________________________________ PM us to get started today! 📞: +1 (800) 438-2808 Text: 949-558-6307 |
12-16-2019, 02:01 PM | #106 |
639
Rep 1,029
G20 330i dropped on H&R Springs for the ultimate STANCE Nothing like better driving dynamics and aesthetics! All available here at SSR Performance. If you’re interested in any suspension work, please PM or call us today! _________________________________________ PM us to get started today! 📞: (800) 438-2808 Text: 949-558-6307 |
12-17-2019, 12:40 PM | #107 |
639
Rep 1,029
FIRST ANNUAL TOY DRIVE!! Now until Friday, bring a toy or 12 to our Orange location and get a free sticker!! We will be driving the toys to the kids this Saturday so make sure you bring something by!! Happy Holidays!! _____________________________________________ PM or Call us for any questions or inquiries! 📞: (800) 438 -2808 Text: 949-558-6307 |
12-19-2019, 02:42 PM | #108 |
639
Rep 1,029
Gift your F8X with the SSR Performance Power Pack 3! Increase the RAW power and noise of your ///M! All tested and engineered in house in our facility. Available in Fashion Grey, Impact Black! Custom Powder coating available. _____________________________________________ PM or call us to get started today! 📞: (800) 438 -2808 Text: 949-558-6307 |
01-06-2020, 06:53 PM | #109 |
639
Rep 1,029
Another day, another N54 in for some maintenance work! @parkerrepp swung by to get his brake pads and rotors replaced to ensure maximum safety. He also recently had his oil filter housing gasket, oil pan gasket, drive belt, and pulleys replaced. Keep your car running clean and like new with SSR Performance. Simply call or DM us! |
01-08-2020, 08:02 PM | #110 |
639
Rep 1,029
New VRSF Chargepipe and Tial BOV getting installed on this N54 335i! Have you upgraded your Chargepipe(s)?! Did you know that the stock Chargepipe(s) break and crack under BOOST? The issue is commonly found on the N54, N55, and S55 engines. This can leave you on limp mode when you least expect it. Upgraded Chargepipe(s) will solve this issue and gives you a peace a mind during BOOST. PM or call us now to upgrade your Chargepipe(s)! 📲 _________________________________________ (800) 438-2808 Text: 949-558-6307 |
328i, 335i, f30, installs, socal |
