The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Extended BMW 335d PIDs for Torque
      11-10-2015, 11:30 AM   #67
DWR
Drives: 2009 335d
Originally Posted by bono View Post
Hi Guys!
I hope you can help me. I am using BAFX adapter and Torque Pro app on my BMW X5 35d (2011). I purchase this combo primarily to have access to transmission temp. Other owner of 50i reported that he can access the temp. There are two "Methods" available in the app for the trans temp, but both are not working for me... The app states "no data".
Please could you help to get the information on the transmission temp?
Thanks!
There is no OBD data for that in the 335d. It is a BMW specific parameter.
      11-19-2015, 02:48 PM   #68
bono
Drives: BMW X5d
So no chance to check transmission temp with Torque Pro on 35d? Bummer...
thank you for your response!
      01-12-2016, 09:25 AM   #69
omgboost
Drives: 2012 X5 35i
I found this post thru google search. DWR, thanks for sharing. I have the N55 engine in my X5 and use Torque App and trying to get accurate boost readings. Does the custom Boost PID work on the N55 engine also? I know my max may not be 35, but I could change that to like 15 or 20.
As for transmission temp, I think it has to do with the 6 speed transmission used in the d models. I can see transmission temp in my 8 speed, X5 35i. Another member on a different forum wasn't able to see transmission temp on their 6 speed X5 35d as it was greyed out.
      01-13-2016, 08:11 PM   #70
omgboost
Drives: 2012 X5 35i
I had the opportunity to try the custom PIDs and only two of them worked. The MAF and another one, I don't remember which one but the boost didn't generate a reading.
      01-14-2016, 07:46 PM   #71
DWR
Drives: 2009 335d
omgboost, if you have Tool32 you can determine the addresses that are appropriate for your ECU.
      01-18-2016, 09:33 AM   #72
omgboost
Drives: 2012 X5 35i
Hmm, I think Tool32 may have been included in the download for coding the car but I haven't used it in ages since I don't think my cable worked. I'll probably have to live with the stock boost reading Torque gives.
The N55 normal max boost is around 7-10 psi from what I gathered and when I floor it, Torque does give me readings within this range. I'm curious as to whether I need to adjust volumetric efficiency from the regular 85% to something higher. I also have a piggyback tune so I don't know if that will give me different readings, but if it does, the Torque boost reading would seem low.
      01-18-2016, 06:45 PM   #73
DWR
Drives: 2009 335d
You don't need the cable to see the PID addressses.
      01-22-2016, 10:24 AM   #74
Speed-D
Drives: 2011 335d
My oil temp PID doesn't give a read out, is this common?
Would it be possible to get a custom PID with oil temp?
      01-22-2016, 12:07 PM   #75
DWR
Drives: 2009 335d
335d has an oil pressure switch and an oil level sensor. I'm not aware of an oil temperature sensor.
      01-23-2016, 07:59 AM   #76
Speed-D
Drives: 2011 335d
Really? I just assumed there was since I know that is a parameter that can put the n54 in limp mode. I noticed there were no PIDs for oil pressure either, I guess just no one is worried about monitoring the oil system.
      01-23-2016, 08:45 AM   #77
DWR
Drives: 2009 335d
Oil cooing ...
There is an oil-to-air heat exchanger. The design is comparable to that of a coolant radiator. Also, oil-to-coolant heat exchangers are used in the engine oil and transmission fluid heat management system. They ensure the oil heats up rapidly in the cold, while controlling overheating.
Only so many ADC inputs. Emissions has a good share of inputs. Can't monitor everything.
      01-23-2016, 03:41 PM   #78
Speed-D
Drives: 2011 335d
Fair enough, thanks for the replies
      01-23-2016, 06:47 PM   #79
DWR
Drives: 2009 335d
Your welcome.
If you have or plan on the DOC/DPF/SCR deletes, I can describe how to monitor other sensors using some of the unused sensors inputs.
      01-23-2016, 07:40 PM   #80
Speed-D
Drives: 2011 335d
Thanks, but it'll be a while until I do the alphabet soup delete. I want to do the diff first
      02-28-2016, 05:37 PM   #81
335dwanted
22
Drives: 2009 335d
DPF Press Diff
I have been using DWR's October version of his extended PIDs (thanks again DWR!). I have noticed that often times the DPF Pressure Differential reading spikes to the maximum value (95) for a second or so. When this happens it will typically spike repeatedly every 5 seconds or so. This behavior usually happens when the engine is cold but occasionally when warm.
When working, the reading (under full throttle/boost) is around 2.0 freshly after DPF regen and it will reach mid/upper 5s right before regen.
Anybody seeing similar behavior to my spiking reading??
      02-28-2016, 08:15 PM   #82
TDIwyse
614
Drives: 2011 335d
Yes. There is an "offset" error that is common as well as noise in this measurment for low/no pressure conditions. So under no/low flow it's possible that the "pressure" will flip to look like a "vacuum" due to these errors and the resulting measurement flips to that extreme value.
I've taken a lot of data on this behavior, and how to correct the sensitivity for ambient conditions, for my sensor. It's a very useful sensor for measuring all types of airflow characteristics ...
Lots of info here if you're interested and a link to a manufacturers pdf where I got a lot of the equations to describe behavior sensitivities.
http://www.e90post.com/forums/showpo...48&postcount=1
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      03-07-2016, 02:20 PM   #83
Chief Orman
Chief Orman's Avatar
Drives: 335D 2010
Oil cooing ...
While it is not relevant to TorquePro the Carly app does have an oil temp reading...two of them actually. I believe one provides gibberish and the other gives an accurate reading.
      03-08-2016, 12:16 PM   #84
DWR
Drives: 2009 335d
Just curious, what kind of temps are you seeing for the oil?
      03-08-2016, 10:19 PM   #85
Chief Orman
Drives: 335D 2010
basically within 5 to 8 degrees of "engine temps". I sometimes wonder about the German to English translation issues with Carly.
      04-07-2016, 07:00 PM   #86
Psyrick
Drives: 2008 335i 4 door stock
The reason is that the ECU in your vehicle is different than the US 335d ECU.
Here are the IDs and descriptions available for your ECU:
ID Description
0x0001 Anzahl bestätigter DTCs und MIL Status
0x0004 berechneter Lastwert
0x0005 Kühlmitteltemperatur (Sensorwert vor der Korrektur)
0x000B Ladedruck (Sensorwert vor der Korrektur)
0x000C Motordrehzahl - Rohwert vor der Korrektur für OBD Tester
0x000D Fahrzeuggeschwindigkeit
0x000F Ansauglufttemperatur
0x0010 Luftmasse von HFM
0x0011 Ausgangstastverhältnis - Drosselklappe (vor der Korrektur)
0x001C OBD Zulassung des Fahrzeugs
0x001D Location of oxygen sensors
0x001F Betriebsdauer seit letztem Motorstart
0x0021 gefahrene Wegstrecke im Zustand MIL ON
0x0023 Raildruck (linearisiert)
0x0024 Lambdasensor Signal - Equivalence Ratio Bank 1 - Sensor 1 0
0x010E Lambdasensor Signal - Oxygen Sensor Voltage Bank 1 - Sensor 1
0x002C Ausgangstastverhältnis - Abgasrückführregelventil
0x002D Abgasrückführregler - Regelabweichung
0x0030 Anzahl der Warm-ups seit Löschen der DTCs
0x0031 gefahrene Strecke seit letztem Löschen der Fehlercodes
0x0033 Umgebungsdruck (Sensorwert vor der Korrektur)
0x003C Catalyst Temperature Bank 1, Sensor 1
0x003E Catalyst Temperature Bank 1, Sensor 2
0x0041 monitor status since last engine shut off
0x0042 Batteriespannung (Sensorwert vor der Korrektur)
0x0045 Tastverhältnis - Drosselklappe
0x0046 Umgebungstemperatur
0x0049 Pedalwertgeber - ungefiltertes Signal
0x004A Pedalwertgeber - Rohspannung von Sensor 2
0x004C Solltastverhältnis - Drosselklappe
You may modify the custom PID for Boost by changing the ID. Find "170" in the Boost PID and change it to "10B". "1" designates the OBD Mode and "0B" is the ID, as in the list above.
Where do you get this sensor ID list? I'm at wit's end trying to edit a version that will work with my Canadian 335i. When I google "bmw 335i ECU PID list" I get nothing useful. Most results having to do with PID control systems. I've already edited the csv to convert the units to read Celsius for temp and Kg/min for mass flow. The custom PIDs load nicely into torque, but I'm getting no data on the dials either way. Mine's probably a English translated version of the Euro ECU. When I use 'Deep OBD for BMW' app to scan the ECU, everything comes up in German. Or maybe it's a different list altogether since mine's not the diesel version. If I knew it's ID, I'd make a custom PID dial just for the TMAP variable and place it next the original dial for manifold pressure. That way when the manifold pressure exceeds the MAP reading limit, I can simply observe the charge pressure instead.
      04-07-2016, 11:03 PM   #87
Psyrick
After doing this it goes from "No Data" to an constant zero reading.
      04-28-2016, 07:24 PM   #88
DWR
Drives: 2009 335d
I have gotten a fair number of requests for non 335d PID sets.
While I would like to help everyone get better datalogging, that was not the purpose of my post. As I have mentioned before, the information can be extracted from Toolset32. That's how I did it. Unfortunately, I am not expert in the data structures for other BWM models. Moreover, I am not inclined to do the research, as I have plenty on my plate already.
Very sorry this stuff is so difficult. You may want to make a contribution to Pheno and get his Testo software. That is another source of info. Good Luck.
