The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Transmission remap - Let's do it ourselves
      05-12-2015, 07:54 PM   #45
Mik325tds
Mik325tds's Avatar
Drives: 335d M-Sport
Originally Posted by DWR View Post
Oh man, if we could get our hands on a calibration template to know what is what. Even in German would be great - right Mik? OK Hoooper, you're in charge of donations for the consultant, ha! I'm laughing now, but that could change...
Yes, that would be something. But who knows, maybe he is as crazy as us and doesn't mind sharing his knowledge?
      05-12-2015, 07:59 PM   #46
Mik325tds
Mik325tds's Avatar
I just flashed the A7610591.0da file for the N57 against all odds .
First test drive really felt a difference. It seemed to shift earlier and quicker somehow.
Unfortunately, my butt-dyno tricked me - the data doesn't really support that:
At least I'm getting better on the steady foot. And I took some screenshots of the flashing process, so hang in there for a tutorial.
      05-12-2015, 08:40 PM   #47
TDIwyse
614
Drives: 2011 335d
Really appreciate your use of data to test and evaluate these efforts. Thank you Sir.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      05-12-2015, 09:19 PM   #48
DWR
Drives: 2009 335d
Hey Mik,
Great work. Can you put some unique symbol on the curves for each cal? The graphs are starting to get busy. Thanks.
Wondering if we should be trying cals for a different engine so we can really measure some differences ... and see those differences in the cals.
      05-12-2015, 09:42 PM   #49
DWR
Drives: 2009 335d
OK, well, you are the foreign language expert on this team. I'll pay for the call ...
      05-12-2015, 10:08 PM   #50
DWR
Drives: 2009 335d
The 30% graph is the best for comparison. Very steady foot, now it just needs an offset calibration.
There's no hope for the butt-dyno. The original shifts are quicker, based on SA duration. Mik, the timescales are in sync, right? I see the speeds (trans out) seem to match pretty close.
We do not know for sure if the "load axis" on the cal maps are throttle, MAF, MAP or some other proxy for load. We are taking a guess at throttle, but on a turbocharged engine that's a bigger risk. Unless we get some additional info, I'm thinking we need to add those to the logs. To keep from extending the sampling period, we would need to take something out. It is pretty easy to see the gear changes from the turbine speeds, so the "gear" parameter could go. Similarly, throttle% and torque are highly correlated. At some point, torque is affected by gear changes, but not the other way around.
      05-12-2015, 10:37 PM   #51
Hoooper
213
Drives: 335D
Lots of new transmissions are controlled highly based on calculated torque. That could be the load category. Shift time desired, pressures, etc based on torque and gear number. Shift points and torque converter lockup based on throttle, speed, and current gear. I can post some fairly simple tuning charts for 4l60e transmissions that might give insight if you think it would help.
      05-13-2015, 11:18 AM   #52
davidjaen
Drives: BMW 335d
I think that there is one BMW 335d alpina... Maybe somebody know something about it.
      05-13-2015, 12:14 PM   #53
TDIwyse
614
Drives: 2011 335d
Question.
Are these logs being done in D or M/S mode? Reason I'm asking is because from some older documentation it appears this, as well as how one was driving previously to the test, could have a large impact on the shift behavior... it also calls out at least 4 basic baseline "maps"...
From BMW Steptronic pdf found on Post # 9 on this thread: http://www.bimmerfest.com/forums/sho...d.php?t=262516
The adaptive transmission control (component of electronic transmission control) adapts the shift
characteristics of the comfort program and sport program to the driver's wish and the driving situation. In both
programs, the adaptive transmission control changes from a basic map to a performance-orientated map, as
required:
· Comfort program in selector lever position "D"
The comfort program is based on 2 characteristic maps: The XE map (extreme economy) and the
E map (economy). The EGS control unit normally selects the economical XE map (= basic map). In
case of particular demands (e.g. load requirements), the system will change to the performanceorientated
E map. If the input signals change in favour of a more "gentle" driving style, the system will
change back to the more economical XE map.
· Sport program in selector lever position "M/S"
The sport program effects dynamic, sporty shift characteristics. In the sport program, there is the basic S
map (sport) and the performance-orientated XS map (extreme sport). If an extremely dynamic driving
style is called for, the system will change from the S map to the performance-orientated XS map.
      05-13-2015, 12:17 PM   #54
DWR
Drives: 2009 335d
Hoooper, that would be very helpful. Thank you.
      05-13-2015, 12:29 PM   #55
DWR
Drives: 2009 335d
Originally Posted by TDIwyse View Post
Question.
required:
Thanks TDIwyse, great infomation. I believe the reason Mik is trying to fix the load on the transmission during the logs is to avoid the switching between map 'types'. In the calibration files, there are certainly enough maps to cover many senarios - it does not make it easier, as you can imagine. There are 2 forms of adaption, the one you describe and one that adjusts timing between the application and release of clutches. Luckily, the later isn't something we need to worry about ... yet anyway.
      05-13-2015, 12:47 PM   #56
DWR
Drives: 2009 335d
I believe shift time desired is going to be very hard to find, using this method, as I'm guessing it is not a 2 dimensional map. And yet, that has to be one of the most important parameters for many of us. We have our work cut out. Really hoping for a lucky break(s).
      05-13-2015, 12:58 PM   #57
DWR
Drives: 2009 335d
Question. Are these logs being done in D or M/S mode?
Sorry, I did not answer the initial question. Mik is most interested in gaining mpg, so the tests are in D (Mik correct me if I'm in error)
I think that is the part that is surprising me the most. Most of the differences between the cal files are outside of the maps. The majority of the maps do not change. There is a group of maps that seem to be the exception - now if we could just figure out what they control!
      05-13-2015, 01:33 PM   #58
Works
Works's Avatar
30
Drives: G30 530e B48 + E82 135i N54
If you guys happen to figure out how to get the DS (S/XS) shift and tc lock map to work with D's (E/XE) rev map the rest of the world would be eternally grateful. This combo would then give birth a new D mode with economical shift points with crisp shifts and early tc lock.
I would be so happy..
      05-13-2015, 01:50 PM   #59
Hoooper
213
Drives: 335D
I guess it depends on the format. I don't know much about code, especially hex code, but I would expect the presentation for desired shift time which is probably between 0.2 and 0.5s to be very different from all other values which the lowest maybe being something like 3 for the 2-1 shift mph minimum and the rest of that table being much higher.
      05-13-2015, 03:19 PM   #60
DWR
Drives: 2009 335d
Yeah, BMW literature says 300ms. So a value around 300 is likely. Unfortunately, with 50,000 addresses, there are many places where that value exists and in 6 consecutive addresses or more. Yikes!
      05-13-2015, 03:40 PM   #61
Hoooper
213
Drives: 335D
Will do ASAP, they are on my tablet at home
      05-13-2015, 05:10 PM   #62
Mik325tds
Mik325tds's Avatar
Yes, please! That will be very helpful.
      05-13-2015, 05:14 PM   #63
Mik325tds
Mik325tds's Avatar
Question.
DWR is correct, I did the logs in D and am pretty sure the car is in XE mode as I drive mostly for economy. Also, I reset the adaptions after the flash and drove on a level surface.
      05-13-2015, 05:39 PM   #64
cptcrunch
Captain Crunch
cptcrunch's Avatar
168
Drives: 2016 340i
Interesting data sets and logging. I'll be following your progress closely
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno
Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade
      05-13-2015, 06:31 PM   #65
mob17
mob17's Avatar
400
Drives: E92 335D
Are you able to code the car/tranny to switch DTC on (one press) automatically when switching to DS mode?
      05-13-2015, 07:36 PM   #66
Mik325tds
Mik325tds's Avatar
I'm not sure if that is a coding option. I'll look out for it when I go in next with NCSexpert. It turns out, flashing a new SW turns off the coding for the flappy pedals behind the wheel. Will need to correct that later. Don't need them for now.
