BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Can an existing error be removed from the system without actually fixing the problem?
      12-16-2013, 03:37 PM   #1
tarekjreidini
tarekjreidini's Avatar
Lebanon
27
Drives: BMW 325i 2006
Question Can an existing error be removed from the system without actually fixing the problem?
I have an airbag error on my 2006 e90 that I do not want to fix, is there some software way that would fix my christmas-tree-looking dashboard?
The airbag error comes with a seatbelt icon which is always on AND an error sign. It's very annoying
I can get an OBD cable if I have to
Thanks
      12-16-2013, 04:18 PM   #2
RedRaiderDavid
32
Drives: 2017 X3 35i X Drive M Sport
2009 BMW 328i  [0.00]
You can clear the error but unless you correct the problem it will come right back. AFAIK you can't disable sensors.
      12-16-2013, 04:46 PM   #3
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Which airbag is it?
or is it passenger occupancy sensor mat in the seat?
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      12-16-2013, 07:09 PM   #4
tarekjreidini
Lebanon
27
Originally Posted by makkan00 View Post
Which airbag is it?
i think its the second one seeing as how the seatbelt reminder doesn't ring anymore when a passenger is with me with his seatbelt off
anyway all I want to do is remove the error from the dashboard I don't care about anything else
      12-16-2013, 08:28 PM   #5
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
There was a recall for the seat mat sensor in the US. Not sure about other countries.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
airbag, coding, delete, error, remove
