12-07-2023, 08:26 AM | #46 | |
1905
Rep 2,093
Gone are my days of crawling around under the car changing oil & filters etc I remember having a mare with one of my Honda's that the filter decided to weld itself against the housing
12-07-2023, 10:09 AM | #47 | |
Rep 1,017
Unlike a lot of other cars, you do actually get the full sumps worth out of the suction pump |
danb19791904.50 |
12-07-2023, 04:58 PM | #48 | |
82
Rep 192
https://youtu.be/UwNNptRt1ig?si=4ZEXLdiO3BMxODsl The only thing I don’t have it a jack/axle stands which is what will make it annoying. |
12-08-2023, 04:45 AM | #49 | |
Rep 811
Just some of the annoyances:
12-08-2023, 04:55 AM | #50 | |
Rep 1,993
Drives: F30 335d
To take the inlet manifold off involved taking off the undertray, cat, turbo and exhaust manifold in that order, simply because the inlet manifold bolts were inaccessible. I enjoy working on my 335d, it's quite straightforward although some of the instructions in TIS are contradictory. If I had a spacious garage & equipment I wouldn't be afraid of doing tasks such as a timing chain replacement/taking the head off, etc. However since I can only work on the drive and therefore at the mercy of the weather I know my limits.
if I've helped - an Appreciate would be, er, very appreciated!
12-08-2023, 06:43 AM | #51 | |
Rep 1,017
My old MK5 GTI had the most ridiculous air box known to man. Mounted on top of the engine on stand off pegs, which are mega tight. So the airbox casing ends up snapping, or the rubber mountings rip out of the air box and stay on the pegs At £450 a pop, busting the airbox is an expensive mistake. And after you have wrestled the airbox off, you then have to undo about 10 screws to separate the two halves like a clam shell, and then of course, they don't want to go back together again properly afterwards, ffs And lets not go there with mounting a filter/intake right above a scorching hot turbo The Xenons on that car have to come out to change the bulbs. No way I could get my shovel hands in those tight gaps. No jacking points other than the pinch welds, so you can't use axle stands unless you trolley jack onto something you really shouldn't. Bundy fittings on the fuel filter, which is by the rear wheel and exposed to mud, crud and everything else. So they corrode in nicely. As does the clamp holding the filter to the petrol tank, meaning a whole new tank is the fix. Etc etc. I've never seen a German car quite as DIY friendly as a modern BMW. Everything is easy to get to, the car is easy to get off the ground and onto stands.....they're just great to work on! Even the plastic jacking points on the sills are so unmissable, you'd have to be a complete moron to miss them, unlike VAGs with vague arrows on the sill covers pointing at an equally vague pinch weld designed for widow maker jacks. I'm so over VAGs |
Eddamoo391.00 |
12-08-2023, 07:47 AM | #52 |
Rep 811
12-08-2023, 08:53 AM | #53 |
Rep 1,017
12-26-2023, 10:12 AM | #54 |
82
Rep 192
Well well well, first dry day in sometime and I’ve gone ahead and changed the oil/filter.
Glad I did it now as it was a piece of piss. Hardest thing was getting under the car with no jack or ramps. Had to position it on the kerb to give me about room to get under. No idea when the filter was changed last but it looks well past it’s best. I’ve put 6.5L in but as you’ll see from the attached images, it’s not showing max? Should I put the rest of the 500ml in that I’ve got? Also, just over 5L come out??? Is that normal if oil has not been changed for some time. Thanks |
12-27-2023, 04:18 AM | #55 | |
1905
Rep 2,093
'Just over' 5l came out, but you've put 6.5l in? Am I reading that right? Was your car level when you did the oil change? You put in what came out (ie I do an oil change, 5l comes out / 5l goes back in)...
12-27-2023, 04:41 AM | #56 |
82
Rep 192
Unless I spilt it when pouring in the container???
The bowl was an 8LTR one and looked quite full to me, going off the picture. Yet when I poured it in the bottles to dispose of, I only managed to fill one of the 5L containers. Car was not completely level but wasn’t extremely off. There was a small drip every now and then when I went to screw to bolt back on. |
12-27-2023, 05:08 AM | #58 |
1905
Rep 2,093
That'd be very low, running dangerously low wouldn't it?
12-27-2023, 10:47 AM | #60 |
82
Rep 192
Just filled the bowl I used to drain the oil and filled with 6.5L of water. I think I must of filled the 5L tub to the brim which would be more than 5 and then spilt some/wiped a lot away with rags from the bowl as the level was pretty much the same as the pic below.
You can see the oil level in the earlier pic around the rim where it’s settled. It’s just come away from that level due to being on a slope. |
danb19791904.50 |
12-28-2023, 09:00 AM | #61 |
82
Rep 192
New cabin filter put in today. Surprisingly easy and took 10 minutes at most.
Old one has seen better days! Really happy I done it myself as now I’ll never need to take it to a garage for an oil/filter changes. Saved myself about £200 once parts/oil is knocked off as garage quoted me £279 for an oil change, filter and cabin filter. |
danb19791904.50 |
12-28-2023, 09:45 AM | #62 | |
1905
Rep 2,093
J3OEF82.00 |
12-31-2023, 11:25 AM | #63 | |
20
Rep 57
danb19791904.50 |
12-31-2023, 11:48 AM | #64 | |
1905
Rep 2,093
Get stretching
Misschief19.50 |
02-03-2024, 12:15 PM | #65 |
403
Rep 41
Drives: F31 335D xDrive
I changed my oil today (2016 F31 335d)
Bought the car in June with 50k on the clock & 5 main dealer oil services. What I drained out was clearly 0w30 as it was just black water Refilled with 5w30 for the win (Previous car was a 2009 E91 with 300,000 on the clock & 6k oil changes - 5w30 / 5w40 weather dependent) |
03-21-2024, 02:11 PM | #66 |
165
Rep 219
I’m planning to do an oil change soon on my 335d.
The stupid BMW service intervals are far too infrequent for my liking. So far I’ve bought: 9L Oil suction pump from amazon £40 2x 4L bottles of Castrol Edge 5W-30 Long Life oil from opieoils £70 Mahle oil filter from opieoils £15 Total cost £125. Might replace the air filter while I’m at it.
2016 BMW 335d M Sport xDrive Touring
