      09-19-2008, 08:49 PM   #67
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Will be getting my 135i soon and this sounds like something I'd wanna do pretty soon. I have an 03 330xi manual atm (not sure if this has a CDV).
Anyway, I'm not a mechanic or anything but I'm usually pretty good when it comes to installing/tinkering around with things. Would you say I could do this by myself with a buddy at my own house or is it best to bring it into some shop?
      09-19-2008, 09:14 PM   #68
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
If you tinker, you can easily do this!
      09-30-2008, 11:19 PM   #69
lannypoffo
Drives: 2013 Dodge Charger SRT8
I still just dont really get this mod. Reason being I've never had a problem with my 1-2 shift. Ever. But it seems like everyone else does.
I read in another post that this will make the clutch wear out faster, but in turn makes it easier on the differential. As BMW would rather have to replace a clutch than a differential under warranty.
I might still do it, but I keep thinking why bother if I have no problem shifting?
      10-02-2008, 05:24 PM   #70
HPADDICT
Drives:
I have no problem with the shift on the street. But when you are shifting very fast like at the track its definitly hard to get it into second.
      11-19-2008, 05:03 AM   #71
cuizhuoyi01
EVO
Drives:
Will the modified CDV will make clutch wear out faster? or the stock one make clutch wear out faster??
135 EVO
      11-19-2008, 08:39 AM   #72
lannypoffo
The modified CDV will make the clutch wear slower. And will be more harsh on the rear end. (The whole point of CDV).
The stock CDV is harder on the clutch and causes more slippage, but eases the shock to the rear end and drivetrain making it last longer.
      11-19-2008, 11:05 AM   #73
audi2bmw1
audi2bmw1's Avatar
21
Drives: 09 montego 135i/acura vigor
^^^ this wouldnt harm the rear end at ALL IMO...the hole that is ported is larger but its still there and is still restrictive..now if u do what some do and leave out the valve that might cause an issue...i dont really think this MOD alone will hurt anything at all....now with power adding mods that create more torque sure it can wear out the stock components faster...im waiting till my 1500 breakin oil change to install this CDV and im hoping it will help mainly with the 1st to 2nd shift
09 135i montego blue 6speed..RR catch can,CDV,DCI intakes,stett charge pipe and tial bov, the above mods are not installed on my car, i just want to seem cool
Devils own water/meth dealer-PM me for info
former car/ 2001 audi TT ~290bhp :w00t:
      11-19-2008, 03:21 PM   #74
ronnyek
Drives: 2010 Evo MR Touring
as observant as I am (I can usually tell any little teeny tiny difference in drivability, sound etc)... I honestly didnt notice much if any diff at all after installing cdv... Its not going to hurt, but nowhere near shifting/drivability of the sti even after
      11-30-2008, 03:58 PM   #75
reddayz
Portugal
Drives:
Hi there
Does anyone know where I can buy a modified CDV in Europe?
Thanks a lot for your help
      11-30-2008, 04:50 PM   #76
Rephlex
Drives:
Originally Posted by reddayz View Post
Hi there
I bought mine directly from Riss Racing. It arrived after a few days and shipping was cheap.
      03-05-2009, 08:22 AM   #77
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Does the modded CDV cause the clutch to feel stiffer/firmer? I LOVE the current clutch weight, and although the 1-2 shift is notchy, it is still nowhere as bad as the 350Z/G35 I've owned. I'd definitely invest in a short shifter kit down the road because I feel the throws are a bit on the long side though. If the clutch feel is different with the CDV, I'll probably pass on this one.
E90 LCI N54 6AT
      03-05-2009, 10:39 AM   #78
MastaMind
I like beer
32
Drives: AW 135
The weight will be unaffected. The "feel" will change due to a less vague engagement point, but it's a change for the better.
      03-06-2009, 04:26 PM   #79
mynew135
assistant to the regional manager
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
Hi there
Just take the stock CDV off, put a screw driver down the small end and hit it with a hammer. It will knock the restrictor out. Viola, you have what people pay $20 for.
      05-17-2009, 12:50 PM   #80
Upgrade+
Good life
Upgrade+'s Avatar
130
Drives: 2008 E90 M3 AW
For the people that did this with the C-clamp method, how does your clutch height feel now? I'm going to do mine this way, but I'm just concerned on how the pedal might drop. Will pumping the clutch and brake really help?
      05-17-2009, 06:07 PM   #81
200Duece
200Duece's Avatar
45
Drives: '73 2002,'18 X5 35d,'17 328d T
I used a pair of vice grips with a rag in between them to clamp the hose shut. worked fine and the pedal pumping does work.
      05-18-2009, 01:56 PM   #82
BlackjackMulligan
Most interesting Roadster
Drives: '01 Z3.0 Roady;'10 C300 Sport
Did you open the bleeder valve while you were pumping the pedal?
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh
      05-18-2009, 04:04 PM   #83
Upgrade+
Good life
Upgrade+'s Avatar
130
I was going to do it the C-clamp way, but I read that all that I have to do after is pump the clutch and brake until it feels normal again.
      05-22-2009, 07:09 AM   #84
Olivier_TFE
sport pilot
Spain
Drives: BMW 135i Alpine White
I just put off the CDV today (but no drive because I'm doing many others modifications on my car: Bilstein, exhaust, differential Quaife, etc.).
Very easy to do.
I have this key, good for purge the clutch:
My "small" lifting equipment:
      06-01-2009, 03:46 PM   #85
BlackjackMulligan
Excellent photos of the lifting points, thanks!
- Joe Walsh
      06-01-2009, 05:59 PM   #86
akak1997
akak1997's Avatar
64
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
^ +1 Great photo! Thanks
      07-04-2009, 12:44 AM   #87
fshek
fshek's Avatar
Hong Kong
Drives: BMW 135i, Alpine White 6M/T
I am pretty annoyed by the jerky 1-2 gear shifting.... not sure if it is related to my skill or the CDV. So I have done the following experiment:
1. Shifting from 1 to 2 at higher Rev (e.g. 3,000-3,500rpm in my case, instead of 2,000-2,500 in my old Silvia S15) could reduce the jerky action.
2. Jerky action when shifting from 1 to 2 at 2,000-2,500rpm could also be reduced IF you shift really really fast from 1 position to 2 position....
My theory:
If you target to shift at 3,000rpm for example, when you lift the clutch pedel, CDV delays the engagement of the clutch, more time to let rev drop; rev not matched, jerky action resulted...
So "shiting at higher rev", or "quicker shifting action" help reduce the rev mis-match and jerky behavior.
But I am tired of learning shifting all over again ~>.<~
      07-04-2009, 05:18 AM   #88
Papito135
Papito135's Avatar
Puerto Rico
Drives: 2009 BMW 135i
I did the clamp method. Clutch pedal felt spongy at first but it went away after a drive around the block. I did not bleed the clutch.
US Army 11C 1983-1993
09 Sedona Red Metallic 135i
09 Ford F-150 Platinum
