2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2015 Adaptive LCI LED Headlights Upgrade
      05-26-2018, 06:16 AM   #89
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
Originally Posted by imraank7 View Post
Hi All, sorry this might be slightly off topic but I just want to know if i can replace the dim angel eyes module (marker) which i have on my halogen headlight unit with brighter ones that come off the xenon headlight unit? If that makes sense 🤔
These are from xenon headlights and want install on mine
No, you would have to change the headlights completely.
      07-04-2018, 10:38 PM   #90
addy27
Drives: F10 550i
These guys are using image from this thread to sell their fake LCI LEDs..
https://www.ebay.co.uk/itm/Full-LED-...4697%7Ciid%3A1
      07-05-2018, 10:13 PM   #91
jonobro
Drives: bmw f10 535i
Originally Posted by SLVSRFR View Post
For those who are interested:
The replica LCI headlights are on eBay. $1700
Make sure you order the correct ones (whether your stocks are Halogen or Xenon) and you'll need to code out the adaptive lights if you have it.
I personally think they look good, but not worth the price as an upgrade from my Xenons. If I had halogens, I'd probably do it.
link me please, which ones would I need exactly for the upgrade I have a 2011 535i
      11-24-2018, 09:53 PM   #92
Dietani83
Drives: 2012 550i m package
Led headlights
Hey did you changed the FRM MODULE? I have a 2012 550 and I have the headlights full Assy but I don’t know what else i need
      11-24-2018, 11:50 PM   #93
jonobro
Where'd you get the headlights ?
      11-26-2018, 07:58 PM   #94
Borracho
Drives: 328i
I love the look of that front end!
      11-27-2018, 09:23 PM   #95
Dietani83
I bought it from ebay
      11-27-2018, 09:23 PM   #96
Dietani83
Oem Headlights
      11-27-2018, 09:37 PM   #97
jonobro
Oem Headlights
Link me !
      08-13-2019, 07:57 AM   #98
marclind
Drives: F11 520d 2011
Help!!!
Bought a pair of very expensive OEM led headlights for my Pre-lci F11 (Xenon) and i've got no clue where to start.
Need help with wiring and what FRM 3 module that will work. My current FRM is 61359247062901
Have ZGW and NBT retrofitted and a computer with ESYS but i'm to scared to try programming myself. But I could do it with assistance or perhapps get help through teamviewer
I've also bought a mirror that has S5ACA Headlight assistance in case it will be needed for the install
      08-13-2019, 02:31 PM   #99
addy27
Drives: F10 550i
The route im going is to add a whole harness for the headlights from the rear fusebox all the way to the headlights. This will allow me to essentially be able to go back just in case, but also keep the factory harness intact. The wiring diagrams I've attached and another member confirmed in the other thread. I have yet to do the NBT/ZGW retrofit but that's next and after that I will also do the headlights since I have them sitting on a shelf still (its been close to a year now.. )
      08-13-2019, 06:01 PM   #100
jonobro
Why are you wanting to do NBT retrofit ? I'm thinking about it but nowadays they have androids that have ID6/7 interface lol
      08-14-2019, 03:18 AM   #101
marclind
A whole harness!?! Ive heard that three cables to FRM from rear fusebox and one from the one in the glovecompartment.
Two CAN wires to each headlight..
But my senses tell me that two of the wires from rear fusebox should go straight to the headlights instead?
But all of this makes me wounder if its better to try to sell the lights instead
      08-14-2019, 12:25 PM   #102
addy27
Drives: F10 550i
Its 3 cables from rear fuse box to the headlights, 1 wire from front/glovebox fusebox to headlight (NOT FRM). for a total fo 4 power lines to the headlights. Then you have to get 2x CAN 3 cables to each headlight from the ZGW. And then LIN cables from FRM to Headlights. Total of 8 wires to each headlight and you can buy the headlight connectors as well as all the other connectors.
Some ppl have used some splicing of other power cables but im not sure that's the safest as each headlight power line needs a unique fuse just for itself.
Its not the easiest retrofit but its definitely doable..
      08-14-2019, 12:27 PM   #103
addy27
Drives: F10 550i
Its 3 cables from rear fuse box through the firewall, to the headlights, 1 wire from front/glovebox fusebox to headlight (NOT FRM). for a total of 2 power lines to each headlight. Then you have to get 2x CAN 3 cables to each headlight from the ZGW. And then LIN cables from FRM to Headlights. And then 2 ground wires but they can be attached to the ground hubs in the front right near the headlights so they don't need to be run through the car. Total 8 wires to each headlight and you can buy the headlight connectors as well as all the other connectors.
Some ppl have used some splicing of other existing power cables but i'm not sure that's the safest as each headlight power line needs a unique fuse just for itself.
      08-14-2019, 12:28 PM   #104
addy27
Drives: F10 550i
I wanted to add NBT and then also swap KAFAS1 for KAFAS2 and keep stuff as OEM as I can.
      08-14-2019, 01:41 PM   #105
jonobro
I'm thinking about adding NBT but what's the difference between that and CIC can you tell me ? and where are you going to purchase retrofit kit EbAy?
      08-15-2019, 10:53 PM   #106
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
https://www.bimmer-tech.net/blog/ite...cic-nbt-nbtevo
      08-16-2019, 12:48 AM   #107
marclind
Thank you! Finally something that give me some clearance!
This is very helpfull and makes sense, do i need new connectors as well?
What about the FRM, do you know if i can use my old one?
(6135-9247062.9.01)
      08-16-2019, 03:16 AM   #108
addy27
Drives: F10 550i
(6135-9247062.9.01)
Honestly I don't have the answer to that. But I know if you look up FRMs on Bmwfans or realo, you find the same part number between LCI and Non LCI cars starting 10/6 build dates.. so if you have anything newer, you should be fine. But do double check that you have the FRM3 module and not just FRM
      08-16-2019, 03:35 AM   #109
marclind
You are a lifesaver!!!
It says FRM3 on my module but it seems that i need to exchange it.. Its just about 200$ for a used one so compared to the headlights its not so expensive
      08-16-2019, 06:29 AM   #110
marclind
Oh, forgot.. And the connectors? Do I need to exchange them aswell?
5post
