09-22-2023, 09:50 PM | #89 |
Rep 19
09-23-2023, 05:21 AM | #91 |
44
Rep 98
Got them installed on my 2019. Was plug and play. Everything worked without coding but there were malfunctions thrown sporadically even though everything was working. Just no return signal basically from from the lights to the FEM. Marius was able to fix it with some fdl coding.
Below are pictures One picture is next to a pre-lci White M4. You can see the DRL brightness difference pretty well here. Last edited by F80manz; 09-23-2023 at 05:31 AM.. |
djpeetur170.00 |
09-23-2023, 10:12 PM | #92 |
9
Rep 16
09-24-2023, 03:03 PM | #93 |
107
Rep 164
I got no regrets, well worth the money. Headlight have held up great for almost a year already. Only thing is I wish I put on a clear bra on the headlight prior for rock chips
10-29-2023, 09:50 AM | #94 |
6MT Grigio Telesto/ Full Amaro Brown
Rep 16
Any update on the best place to purchase these and the final verdict for which model headlights require harness + coding vs. Which do not? Seems like F80manz was plug and play but there is conflicting information earlier in the thread
11-13-2023, 06:24 AM | #96 | |
44
Rep 98
As for which ones require a wiring harness, all pre-lci adaptive headlight cars require the extra wiring. The kits are plug and play for pre-lci and lci non adaptive lights. However, keep in mind that all retrofits will need coding in some capacity. As far as the seller tells me, no you can not. But I haven't tried to take off any of the modules yet. |
11-18-2023, 07:14 PM | #97 |
Rep 1,117
12-01-2023, 11:49 PM | #102 |
10
Rep 81
Man this has me really wanting a set of these. coding is ok but why cant they just get the plugs and pins right so we don't need another harness? geez 2k and cant get the right plug on the head lights..... there has to be a new version by now?
12-05-2023, 12:38 PM | #103 | |
Slow Guy
9
Rep 36
6 pin for adaptive pre lci led's 8 pin for non adaptive xenons Last edited by 30FF; 04-10-2024 at 05:00 PM.. Reason: Typos, additions |
M4rqu3z0.00 |
12-14-2023, 01:01 PM | #104 |
136
Rep 72
Looks good! We also do IKON headlights.
12-15-2023, 07:48 AM | #105 | |
375
Rep 212
I've read nothing but negative comments about bimmerplug in numerous threads. Also, your link says "designed by bimmerplug in california". I don't believe that for a second. Those are even the same pictures from Alibaba/aliexpress of the headlight housings. They're the same lights, marked up. Which is in line for most of what i've read about your products. |
12-19-2023, 12:49 AM | #106 | |
Rep 7
12-19-2023, 03:05 PM | #107 | |
Rep 7
12-19-2023, 03:52 PM | #108 | |
Slow Guy
9
Rep 36
auto highbeams work? do you mean the low beams come on during night? if that's the case yes, welcome lights work fine as well. |
12-19-2023, 03:55 PM | #109 |
Slow Guy
9
Rep 36
Did not need wiring for xenon everything worked straight away besides the adaptive fault, and yes adaptive does not work and needs to be coded out.
12-19-2023, 04:05 PM | #110 | |
Rep 7
You do I have a 15 with the pre LCI adaptative LED |
