03-16-2024, 10:52 PM | #155 |
44
Rep 98
I got some light wrap sitting in my house which I'm gonna throw on once it's warmer. Will post pictures when able. I did also reach out to the seller and there is currently no way to make only the DRLs yellow
03-18-2024, 06:58 AM | #156 |
Rep 4
04-01-2024, 10:52 AM | #157 |
Rep 9
Good day guys. Just want to confirm i have a 2015 with xenon head light..
Which one should i go for 8 pins or 9 pins. The top or bottom one according to the picture. Thank you guys. |
04-02-2024, 03:22 PM | #158 |
Rep 21
So I recently installed these headlights and have been getting a battery fault code on start up that says “battery discharging while stopped” may be some type of parasitic drain on the battery while the cars sleeping. Has anyone else encountered this?
I’ve reached out to my coder Marius and he informed me I am not the only person to reach out to him about this same fault code after installing these lights. My car is at the dealership right now getting the fault code checked out and they are helping me track down the source of drain, and so far they say it is pointing to the headlights but not conclusive yet. I just wanted to check in to see if anyone else has had this issue and if so if you were able to resolve it. I’ve also reached out to the vendor I purchased these lights from to see about a replacement if my set may be defective. Thanks |
04-03-2024, 12:19 PM | #160 | ||
43
Rep 217
Depends if you have Adaptive Xenons or not. I originally ordered 8pin from my seller but realized 9pin is required for my adaptive xenons. Alternatively, You could do 8pin and get a harness from Marius Quote:
04-03-2024, 01:22 PM | #161 | |
44
Rep 98
04-03-2024, 07:14 PM | #162 | ||
Rep 21
I do vaguely recall now that message popping up during install, but I didn't think anything of it as I figured it was because I had the hood open for a couple days since the installation spanned over an entire weekend. But now its been installed for a few weeks and it continues to come up I began to suspect its something with the headlights. Really hoping it's not but I'll keep everyone posted on what they find. |
04-07-2024, 07:16 PM | #163 |
44
Rep 98
Tint still has to "cure" for clarity but just got it put on. The slight haze will be gone in a few days
04-10-2024, 09:46 AM | #164 |
Rep 2
Drives: e30 325i, e92 m3, e36 m3, f30
So I’ve got a 2017 F80 M3 in silverstone with the Adaptive headlights, does anyone know what pin these would be? Kinda assuming all of them are 9 pin but not sure
04-19-2024, 06:39 AM | #165 |
Rep 2
Assuming you mean adaptive LED’s then yes, 9 pin will do it. I also had pre lci adaptive LED which is 10 pin and got the 9 pin and it worked.
04-25-2024, 09:08 PM | #169 |
43
Rep 217
Finally got mine in.
- low and high beam light output is excellent - Fitment is near perfect - Angel eye brightness is OK.. about the same as the xenon's - Self levelling screws were a pain to get out of the OEM lights (spinning nut). - Passenger wiring JUST makes it to the plug on the lights, wish there was more slack - got mine from AOKEDING for 850USD on aliexpress Last edited by mwalter14; 04-25-2024 at 09:29 PM.. |
04-26-2024, 07:46 AM | #170 | |
Rep 1
I have 9 pin as well. Plan to do the VO coding myself with Bimmergeeks Protool. Excited to see the brightness and beam pattern, i’ll def aim them as well. |
Yesterday, 07:06 PM | #171 |
Rep 4
Yesterday, 07:46 PM | #172 | |
44
Rep 98
Holding up well! My buddy has installed this tint on plenty of cars and everyone's had a good experience with light wrap |
