2010 2011 BMW 5 Series Forum F10 F10 550i electromechanical power steering help |
01-12-2019, 09:16 PM | #1 |
Rep 704
Having issue with my steering. Every time drive and turn the wheel to left or right I hear a grabbing sound on the passenger side. It sounds like the brake pads is grabbing. I already changed wheel hub bearing assembly, brake pads and rotors and steering fluid (11s) noise still there!
01-12-2019, 09:37 PM | #2 |
Rep 590
01-12-2019, 10:32 PM | #5 |
Rep 704
01-12-2019, 11:46 PM | #6 |
Rep 590
01-12-2019, 11:57 PM | #8 |
Rep 590
01-13-2019, 03:20 PM | #10 |
Rep 5,365
I didn't saw often, I said regularly. I would follow BMW on the brake fluid. I would flush the trans and change the diff every 75Kish miles. I would do the coolant every 2 years. I would do the P/S fluid every 2 years also, if I had mechanical P/S.
01-13-2019, 05:46 PM | #12 |
Rep 704
01-13-2019, 05:59 PM | #13 |
Rep 5,365
01-13-2019, 09:06 PM | #14 | |
Rep 704
When I reset my EPS via ISTA+ the sound went away and came back after reboot. Then when I am turning left and right while moving with little throttle the sound is more pronounce. Like the brake pads is grabbing. |
01-13-2019, 10:12 PM | #15 |
Rep 704
my theory is that my EPS is about to get fkd. EPS is more to the right of the car and that's where I hear most of the noise coming form. specially when turning.
01-15-2019, 05:51 PM | #17 |
Rep 704
UPDATE! UPDATE! UPDATE! The shop mechanic says that it is my ARS... Hmmm. It make sense and after searching ARS it shows that it is an issue to some as well. Hope extended warranty will be able to cover it.
04-09-2019, 08:20 AM | #18 |
97
Rep 204
04-09-2019, 02:11 PM | #19 |
Rep 704
04-10-2019, 12:35 AM | #20 | |
Rep 659
04-10-2019, 12:11 PM | #21 |
97
Rep 204
If you don't mind me asking, where did you get the part? And did you order the EPS motor only?
04-10-2019, 04:11 PM | #22 |
Rep 704
I had the dealership do the TSB due to the extended warranty wont payout to replace the valve block if TSB is not complete. less than $200 to install the bushing. The EPS does not come separate. I had to order the whole system which is lessl than $3k after the core has been returned. Installation should be pretty straight forward coz it is electric and not hydraulic.
