10-31-2016, 07:45 AM | #67 | |
FAST
371
Rep 574
I'm almost tempted to order both the earthquake and RF and measure what one does best! Send the looser back.... If you were to just go by SPL specifications (dB @ 1w/1m), you might think the RF would be better, but just looking just at the XMax Paramater the SPL at full tilt would easily go to the earthquake. That is a lot of throw difference. The earthquake is 23mm The RF is 7mm That being said, an 8" sub with a 23mm one way excursion is a sight to see. Really, I've never heard of a thin 8" having that much movement. I actually wonder if that is real, or if the spec is fudged? Can anyone confirm that its excursion (min to max) is close to 2 inches? From the pictures, the surround doesn't even look like it would physically work. If it is real, that throw is simply amazing for such a thin speaker! I would think it would be smacking the grill that goes on top! .http://www.earthquakeeurope.com/Prod..._manual_US.pdf There is a paragraph in there that talks about the excursion Also watch this video seems to suggest it may be real: Last edited by JMon; 10-31-2016 at 07:59 AM.. |
08-20-2017, 02:17 PM | #68 |
107
Rep 254
Im going to attempt this mod!
actually, Im just going to buy all the parts and have a local shop install it. So I need: SWS-8X x2 adapter ring bracket x2 Audio Control LC2I LC2I x1 Is that correct?
C300->C63->535->S4->M4->Macan->Macan Turbo
08-24-2017, 04:51 PM | #69 |
Rep 1,835
Drives: 2020 X4M CS
AUDIO CONTROL LCI2 Is the key...i that as a line driver , high-> low converter...key here, may seem obvious but t splice into the stock subwoofer wires coming out of the stock amp, forget colors but the 4 thicker wires 2 pairs twisted...the stock dsp has great crossovers if u grab other wires ur not going to be getting the deep lows...
Also Idk if its been said but if adding aftermarket sub/amp ASD must be coded out... I never noticed ASD...and I hooked up my stereo...2 RF P3 DVC 12"S 2ohms W Kenwood 3000w 1ohm stable amp. Speakers in dual vented box wired in parallel to 1 ohm. Hooked it up sounded great...went to drive in sport+ (where ASD Is loudest) and u almost fried my stereo... Showed me ASD is mostly loud i lower frequencies...so also by disabling asd...ur stock subs will sound better bc they're not wasting power on fake engine noise |
05-07-2018, 09:06 PM | #70 |
Rep 41
I want to add a sub to my M4 convertible and already have both a sub and amp. I would would just need the LCI2. I thought the sub amp was located in the trunk? Does anyone know the wire codes and where I could tap into them instead of running extra wires from the stock woofer locations?
05-13-2018, 02:43 AM | #71 | |
13
Rep 67
You can find this cables in the big amplifier connector in the trunk. |
06-19-2018, 09:46 AM | #72 |
13
Rep 32
will this fit? : Rockford Fosgate P3SD4-8
It can be it has two drivers and can be connected as 8Ohms. Is it true that the AMP then will not heat up and eventually get destroyed if I go down this path? https://www.crutchfield.com/p_575P3S....html?tp=68848 |
06-20-2018, 02:44 PM | #73 |
13
Rep 32
I'm just trying to avoid putting together another AMP.
Is it possible to install a higher watt wirebound resistor in series with the SWS-8X x2 to achive impedence that matches the oem amp? Here is the wirebound resistor. https://www.mouser.com/ProductDetail...gEbY%2fg%3d%3d |
09-18-2018, 05:12 PM | #74 | |
You got my money?
3239
Rep 4,708
Drives: Ice Cream Truck
You attached the stock subs to an amp and it didnt blow or anything? Two 7.2ohm subs on a 4/2/1 ohm amp ok to do?
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
01-20-2019, 10:40 PM | #75 | |
125
Rep 290
'17 i8 Protonic Red Edition; '17 “30 Jahre” M3
'90 Z1 Red w/red/black leather, GC coilovers, Alpina Dynamic DS-02 '91 850i Mauritius Blue/Black, BBS RS-GT '85 M635CSi Alpine w/buffalo; '03 M3 Conv, Imola ‘85 323i Baur; ‘02 X5 4.6is Estoril; ‘95 Racing Dynamics K30.4 |
04-01-2019, 08:02 PM | #76 |
Rep 1
Can I add a powered sub via speaker level inputs?
It sounds like I can tap into the subwoofer connections on the HK factory wire harness in the trunk. Has anyone done this and figured out exactly which wires to use? Which one is the turn on wire?
I am trying to connect a powered subwoofer. https://www.crutchfield.com/p_575P30...10.html?tp=114 Crutchfield sent me a harness diagram but it doesn’t match my F80 at all. Is it better to connect this using one of the harnesses I see or just pay someone to do it? |
04-10-2019, 01:47 PM | #77 | |
Rep 1,835
Drives: 2020 X4M CS
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
04-10-2019, 04:07 PM | #78 |
Rep 1,835
Drives: 2020 X4M CS
There aren't any generic amps that will last through 30V spikes, even if the Impedance is much lower....BUT A good LOC, Line Driver, DSP can turn high level inputs into low level and fill in missing audio informtion s well s other features....I Use Audio Control Products...The LCi2 works insnely well to prevent roll off and open ur options....That with the Hifonics Bass Restortion processor....Im anal with audio and very happy...ppl cant believe I only have one P3 12" DVC wired to 1 ohm with a 1 ohm stble 2000watt RMS Kenwood Amp....Also spray insulted the trunk...only draw down is i need to leave 1 or both back seats down or you barely hear the bass...And had to fix a few rattles...
04-01-2020, 11:39 PM | #79 |
21
Rep 135
would you recommend the SWS subs replacements to be 4 ohm or 2 ohm?
and would you go with a Class D amplifier (mono, 2ch)? How much power you think? I read the subs there go to 200hz and most class D amps go to 150, would this have a huge sound gap?
330i '04 sold
335xi '07 400hp sold 435xi '14 360hp sold M3 CP '17 444hp |
04-05-2020, 07:17 AM | #80 |
Rep 84
I am trying to get an Audison DMI and an Audison F8.9 Amplifier...
What harness is required to hook this up in place of my OEM HK amplifier.....Any advise would be appreciated... |
Trevorstein150.00 |
05-22-2020, 10:57 PM | #81 | |
21
Rep 135
Do you have a vid?
Are you still running that sony amp? Did you end up doing an LOC? Quote:
330i '04 sold
06-17-2020, 12:05 PM | #82 |
Rep 19
may i ask if anyone had done HK retrofit based in a HIFI system?
using all the upgraded speakers? |
Trevorstein150.00 |
06-22-2020, 10:42 AM | #83 |
Rep 2
Hello,
I recently upgraded the factory amp to JL for the interior speakers and added JL subs and JL amp for the sub. sound is great and clean! only issue i am having is the GONG/PDC sound is too loud. Are you experiencing any of this? I turned it down on the HU -5 but still too loud as the speakers are powered with AMP. any advise? |
07-02-2020, 05:13 AM | #84 | |
FAST
371
Rep 574
07-23-2020, 10:53 PM | #85 | |
Rep 1,714
Drives: 22 X3MC MBB - C-17 Globemaster
09-09-2020, 07:12 PM | #86 |
BMW Veteran
310
Rep 503
if any of you want to get rid of your HK amp after you go through with an upgrade to aftermarket, let me know. My factory HK amp just shit the bed and i'm on the hunt for a replacement. My amp has 9393194 on the label, part #65129393194.
10-15-2021, 02:33 PM | #87 |
27
Rep 54
If anyone is interested in doing this with a Bavsound and aftermarket amp/sub setup. I have everything for sale brand new and at a serious discount here: https://f80.bimmerpost.com/forums/sh...5#post28145995
thanks
E71 X6M Daily Fun Car
E46 M3 convertible, warm summer night car Previous F8x's |
