BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      10-18-2022, 03:07 PM   #23
s0ldats
54
Drives: 2011 E90 M3 stripper
i'm waiting to see how oem rear section sounds with titanium x pipe, but will likely grab the ti version of this eventually. i'll circle back if i end up getting it!
      10-18-2022, 03:27 PM   #24
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Waiting on an email response. Might pull the trigger soon if I can get the SS for $1000 shipped
2009 BMW 335i 6MT
*big single (eventually)*
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      10-18-2022, 04:18 PM   #25
chicagob5
Drives: E90 ZCP
Just got my order in. Likely won't be able to get it on the car before the car gets put away for winter but will try my best. If I get it on, I'll grab sound clips and post a review.
Appreciate 4
Soden82478.50
FinalLe13.50
LTY122419.50
      10-19-2022, 03:48 PM   #26
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Just purchased. Will also try to get it installed with a sound clip prior to the winter. Doug also told me to stop by turner so he could hear it/check it out (since I'm local).
2009 BMW 335i 6MT
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      10-19-2022, 06:00 PM   #27
chicagob5
Drives: E90 ZCP
If you end up going by to check it out, I'd love to hear what you're impressions are.
Soden82478.50
      10-20-2022, 11:12 PM   #28
Fl4tsix
10
Drives: 2013 M3 e92
Same here!
Sound clip with test pipes or x pipe would be amazing!
Seems like a great deal!
      10-21-2022, 11:07 AM   #29
chicagob5
Drives: E90 ZCP
Mine came in today. Initial impressions are very good, the system looks very well put together. Quick pic attached.
Worth mentioning,Turner packaging is really good too, it was very well protected.
Appreciate 4
Soden82478.50
Davisca4552207.50
exVtekGuy115.00
      10-21-2022, 11:26 AM   #30
Bimmer Barney
Bimmer Barney's Avatar
1250
Drives: 2011.5 E90M ZCP
Nice, mine arrives tomorrow afternoon per tracking.
2011.5 E90 M3 DCT ZCP Slicktop
      10-21-2022, 11:54 AM   #31
Ervin87
Ervin87's Avatar
Drives: E92 M3 | B5 S4 | E30
I hope this does not drone like 95% of the other exhausts on the market.
      10-21-2022, 12:03 PM   #32
chicagob5
Drives: E90 ZCP
Ditto, I got rid of a Supersprint race axleback due to the drone and put the OEM back on. Really hoping there is no drone with valves closed atleast. I can deal with a little 2-3k RPM drone with valves open during spirited driving since I'll be in the higher RPM's anyway.
Really looking forward to impressions from someone who can get this on sooner than I can.
Ajolives922.00
      10-21-2022, 02:12 PM   #33
Bimmer Barney
1250
Mine will be on by Monday
chicagob5256.50
      10-21-2022, 03:38 PM   #34
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2019 Audi SQ5  [0.00]
2008 BMW M3  [0.00]
In the video I only heard induction noise with valves closed, seems to be pretty tame, should be safe.
Just ordered mine and I'll gladly report on drone with HFC and secondary delete.
chicagob5256.50
      10-21-2022, 05:10 PM   #35
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Mine will be here tomorrow
2009 BMW 335i 6MT
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      10-21-2022, 05:55 PM   #36
s0ldats
54
did anyone get the titanium version?
      10-23-2022, 07:30 PM   #37
Bimmer Barney
1250
Unboxed. I'll start the install this evening and wrap up tomorrow most likely.
Appreciate 4
      10-23-2022, 08:11 PM   #38
chicagob5
Drives: E90 ZCP
Nice, curious where you plan to put the valve controller. I'm planning to use a
fuse tap and ground by the fuse box but mount under the cowl. Seems like a good central area and easy to get to the vacuum lines from there but wondering what others will do.
Ajolives922.00
      10-23-2022, 09:08 PM   #39
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
When installing their exhaust on my 335i, I drilled a small pilot hole through the spare tire area of the trunk to run the vacuum lines, then wired the solenoid to a power source in the trunk
2009 BMW 335i 6MT
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
chicagob5256.50
      10-23-2022, 10:44 PM   #40
Bimmer Barney
1250
I'll probably do that same. That's how turners install guides shows it. Brake booster for vacuum?
      10-24-2022, 01:21 AM   #41
chicagob5
Drives: E90 ZCP
I was gonna use the line from the fuel breather valve under the plenum
      10-24-2022, 11:22 AM   #42
Bimmer Barney
1250
11 lbs lighter than the Supersprint F1 Race system. Both are stainless construction.
      10-24-2022, 04:32 PM   #43
Bimmer Barney
1250
I'll do a write up in this thread soon. Everything is done except pulling the plenum to connect vacuum. Teaser shots:
Appreciate 4
Ajolives922.00
chicagob5256.50
Soden82478.50
Thumbie95.50
      10-24-2022, 04:34 PM   #44
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2008 BMW M3  [0.00]
Nice mine should be here by the weekend. I'm already planning/prepping so I can get it in one shot. I was thinking of running the vacuum line above the underside plastic running boards but the trunk looks waaay easier.
Install go well?
m3post
