BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
      10-12-2022, 01:08 AM   #1
Signature Wheel BMW
Signature Wheel BMW's Avatar
Drives: Signature BMW
DIY - E92 M3 Varis Style Diffuser Install - RW Carbon
Hello E9x M3'ers. I wanted to put together a comprehensive installation guide for the RW Carbon or similar Varis style full diffuser and under tray. To my knowledge and search, no one has personally documented their Varis or Varis style diffuser installs. Matt at RW Carbon asked that I help the community with a comprehensive DIY to install RW and other Varis style diffuser/under tray since the work is very intimidating for those who haven't done this type of install. Matt also asked that I push the speed threshold of this setup on the track in excess of 130mph, see if I can find any flaws with it at speeds.
I hope this DIY will help you guys and gals to be more comfortable to tackle this on your own. This DIY assumes you know how to jack a car up safely, have hex bits, socket set, vise (or a way to bend brackets), have an angled grinder or Dremel, and roll of 3M VHB tapes. Do this at your own risk as improper installation can cause damage to your diffuser, car, and cause safety concerns for others on the road driving behind you.
Main Reference:
Step 1: Prep the tray, use 5/16" drill bit to enlarge the holes of A, C, D, and E. For (B), use 3/8" drill bit to enlarge the holes by 1/4" each direction.
Step 2: Trim exhaust openings. After testing fitting with my OEM exhaust, I needed to cut 1/2" both sides of the exhaust openings. You can use an angled grinder or Dremel. Be sure to wear a mask.
Step 3: Prep hardware for (A) on the tray, using 2qty #1, 2qty #6 and 2qty #8. Note, I didn't use #8, I bought shorter M6 panhead bolts from the hardware (see below)
Step 4: Prep hardware for (F) on the tray, using 2qty #3, #9, #10, #14.
Step 5: Prep hardware for (B) and (C) on the tray, using 6qty #11, #13, 4qty short #7 for (C) and 2qty long #7 for (B).
Prepped tray:
Step 6: Prep vehicle for (A) (B) (C), remove OEM clip and replace with 8qty #6. Use flat head to assist.
Step 7: Secure bumper or heat shields to trim for (B) and (C). Once new clips are installed, use 6qty #8 or #9 to loosely align the bumper for (C) / heat shield for (B) to the plastic trims above it. Then use 6qty #15 (self tapping plastic screws) to secure the bumper / heat shield to the plastic liner above it so the holes won't move on you. Once all 6qty #15 are screwed on, remove the #8 and #9.
Step 8: Install brackets for (A). Use 2qt #2, #9, and #14 washers.
Step 9: Bend brackets for (E). Use 2qty #5 and bend exactly to how it is below. Pay attention to where the 2" are bent.
Step 10: Install brackets for (E). Use the OEM 8mm bolts, do not over tighten. Snug is fine. Add #6 clips to the brackets to secure the tray to it later.
Step 11: Bend bracket for longer point D. Pay close attention to the measurements below. Use 1qty #1, #4 and #6, assembly hardware for L brackets are #12 and #10.
Step 12: Assemble bracket for shorter point D. Use 2qty #1 and 1qty #6, assembly hardware for L brackets are #12 and #10.
Step 13: Mount both brackets for (D) to the chassis.
Step 14: Point (F) extra security. I bought 2qty M12 1.5 stainless steel bolts, large washers and drill a hole on the edge, and some springs to attach (F) to the steering arm bolts. You don't have to use springs, can use wire ties. I'm going to reach over 130mph often with this setup, so this is added security for my peace of mind.
Completed the mounting hardware:
Step 15: Prep the diffuser. Use a 5/16" drill bit to loosen up the 4 holes for easier install. Wipe down the mounting points on the diffuser and bumper with alcohol then install 3M VHB 1/2" tape.
Step 16: Install the diffuser, loosely bolt the diffuser (2 middle bolts are from reference point "A" and 2 outer are OEM 8mm bolts). Make sure it can sit flush, then remove the 3M tap then secure the diffuser with masking tape so it doesn't move. Tighten the 4 bolts holding the diffuser.
Step 17: Install the tray. Use 4qty #8 for (D) and (E) first. Note, one side of (E) may require drilling a new 5/16" hole if the bracket doesn't reach. Then tighten the rest of the bolts. For (A) assembly hardware for L brackets are #12 and #10, I use an angled needle nose to hold the nut while I bolt them down.
Extra security using springs for (F) (you can use wires instead)
I have EAS 80mm exhaust tips, which were riveted to the OEM modded muffler. I had a local shop fab 1.5" longer base for the tips to rivet to in order to extend the tips further back. Otherwise, the stock tips or non-adjustable tips will be too sunken in.
Enjoy. I've personally tested this tray to 135mph. Track season is at an end, will do more testing in the springs. Cheers.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
Appreciate 9
      10-26-2022, 12:12 PM   #2
Signature Wheel BMW
Dat A$$
Still hanging on at 130mph+... cough, on the "track"
Checked all bolts, none were missing.
Update after 500mi: I will use 3M panel adhesive for the diffuser part to glue it to the bumper. 3M VHB ain't holding due to little touch points. Once 3M panel adhesive is applied, it's stuck to the bumper for life. The tray is fine with bolts, don't glue that part, lol.
Appreciate 5
      10-29-2022, 02:11 PM   #3
Rochen_00
Rochen_00's Avatar
350
Drives: M3 e92
Thank you very much bro
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position
      02-19-2023, 04:04 PM   #4
Signature Wheel BMW
Titanium Hardware Upgrade
Alight guys, here's the update on the RW Carbon Under Tray and Diffuser.
For the diffuser, I went ahead and took the tape off then use 3M Body Panel Adhesive to make it permanent. 3M VHB tape kept coming off after car washes and drove me nuts.
For the tray, RW Carbon's supplier uses non-zinc coated hardware so it started rusting. Other than that, I have 0 complaints about the product which is holding strong at speeds and strong wind gusts. I replaced the hardware with titanium bolts below and 304 SS nuts. I'm loving the look and the couple ounces of weight savings
Titanium bolts:
(22) M6 x 15mm
(2) M6x12mm
https://www.aliexpress.us/item/2251832460881302.html
(2) M6x25mm
https://www.aliexpress.us/item/3256804544484260.html
1 pack of M6 Serrated 304 SS Nuts:
https://www.amazon.com/dp/B071XHYWLW...roduct_details
Appreciate 3
      04-06-2023, 02:58 PM   #5
jmeenach
Drives: E92 M3
How has it held up in the months since install?
      04-08-2023, 06:40 PM   #6
Jsmith
23
Drives: tesla model 3
Great write up. I hope to get one of these installed someday. Fingers crossed for a good deal on one.
      04-22-2023, 05:00 PM   #7
Signature Wheel BMW
Plus Nuts
Update: Swapped the clips out with Plus Nuts. For faster removal and installs (track vehicles, nice to be able to remove the trays for diff service / links etc.).. You will need to remove the rear bumper (super easy) and replace the clips supplied with these M6 plus nuts.
Note, plus nuts (makes a plus when contracted with a tool) are stronger than rivnuts (expands). Tray help up great at 130mph with 40mph cross gusts.
      09-16-2023, 05:49 PM   #8
nyc_dude
nyc_dude's Avatar
Drives: 09 //M3 e90 Interlagos Blue
Got the titanium bolts on Amazon. Great tip.
Varis Undertray and 3D Design on an E90 M3 Sedan coming soon. Custom Holes...
PPF and ceramic coat are 50% the cost of the CF Japanese parts.
Great DIY and a tip of the hat to Matt at RW Carbon.
Cheers
      09-18-2023, 04:21 PM   #9
Signature Wheel BMW
Cheers
Glad it was helpful.
Get the plus nuts, remove rear bumper and install M6 plus nuts. You'll cuss a lot less whenever you remove and reinstall the tray, lol.
      11-09-2023, 01:00 PM   #10
Ayamazin
Drives: BMW 435i
2013 BMW M3  [0.00]
This is amazing thank you. Any chance you have a list of the hardware that’s needed? Hard to tell which size bits, bolts, washers, etc.
      11-17-2023, 04:13 PM   #11
Signature Wheel BMW
RW Carbon shipped with hardware. I upgraded most to titanium which I've listed. Most M6x 12mm and 15mm.
      11-17-2023, 04:20 PM   #12
Signature Wheel BMW
Over a year in!
Over a year in and a track season... Once I've updated most hardware to titanium and true stainless, changed the bumper M6 clips to M6 plus nuts, everything is still held on strong..
e92 m3 diffuser, rw carbon, signature wheel, sv602, track e92m3, under tray, varis style diffuser
m3post
