01-20-2018, 03:23 AM | #67 |
Rep 6
Hi Tony, The date for the . dir is 01/01/2010 03:00.
When I do dir c:\programdata /tw /a it's the same date and time. For the RearmLauncher.cfg file: Created: 01 Jan 2010, 02:00:00 Modified: 19 Jul 2017 (date I tried to change to in a previous test, but note: this time, and the previous time I reported above, I kept today's date unchanged) Accessed: 01 Jan 2010, 02:00:00 Hope this helps! |
01-20-2018, 03:56 AM | #68 | |
124
Rep 274
The modified date of RearmLauncher.cfg is the problem. Why is that modified? Delete the file and extract it from the package again. It should be dated 01 Jan 2010. Despite the error, I think my script did work and the Launcher probably works. Cheers, Tony Last edited by Tony Twoclicks; 01-20-2018 at 10:21 AM.. Reason: typos |
01-20-2018, 04:03 AM | #69 | |
124
Rep 274
You might also want to try keeping your system date reverted while coding. Could be that E-sys has a problem if the system clock is past the expiry date of the EST token file. |
01-20-2018, 05:15 AM | #70 |
Rep 6
progress..
Hi, some progress I think (although I still always get the Windows System folder warning in my previous screenshot).
Using E-Sys Version 3.31.0 (build 50446), tried setting date to 19/07/17, got this when E-Sys Launcher tried launching E-Sys: " WARNING!!! There are 30 file(s) with suspect status. These files will not be loaded and will cause instability. It's highly suggested that you abort launching E-Sys and reinstall. Continue? " then the error in the attached screenshot. So I tried setting the date to 22/09/17. Got further, Windows asked if Java could access local networks. Then this E-Sys Launcher Error: Unsuppoerted Version - E-Sys Version 3.31.0. I'll try and find a previous version of E-Sys and go again. Last edited by Ian-F80M3-UK; 01-20-2018 at 05:16 AM.. Reason: forgot attachment |
01-20-2018, 09:47 AM | #72 | |
124
Rep 274
Yeah, as E-sys Launcher Premium is no longer developed by Tokenmaster, the latest E-sys versions are not supported. Please read Tokenmaster's blog for more info about what works and what not. My script can't change that. If you need support for higher E-sys versions, please buy E-sys Launcher Pro from Tokenmaster. The reason you still get the error about locked system folders is due to the Last Modified Date of RearmLauncher.cfg. My script compares this to the dates of c:\ProgramData afterwards to see whether it was succesfull. In your case there is a mismatch, resulting in the error. I'm curious, what program do you use to extract the package and what's the Modified date of RearmLauncher.cfg right after extraction on your system? Last edited by Tony Twoclicks; 01-20-2018 at 10:18 AM.. Reason: typo |
01-20-2018, 10:17 AM | #73 |
124
Rep 274
01-20-2018, 10:57 AM | #74 |
BMW Lover
Rep 37
I keep getting an error running the 1.5.0 file. “The syntax of the command is incorrect.”
The dates show as 1/10/2010 but the launcher still says there is date manipulation. |
01-20-2018, 11:35 AM | #75 |
9
Rep 14
Followed directions to the T!!! Worked perfectly!!! Thanks Tony Twoclicks for the blessing!
One thing that I'll mention for anyone that is having issues. I have to keep my date reverted while running E-Sys. Otherwise it won't work and continue to search for the key. Solution...Just revert your time back anytime you need to use E-Sys... Hope this helps... Last edited by C-Poppy; 01-20-2018 at 11:42 AM.. Reason: Forgot to add... |
01-20-2018, 12:47 PM | #76 |
Rep 6
For your package I use the native Windows 10 'Extract' option that pops up for zips in the File Explorer. I used the same for E-Sys Launcher, and had to use WinRAR for the e-sys 3.28.1.
I just re-extracted your rearmer 1.5 into a temp folder and the timestamp is now 18:43, 20/01/18 (i reset the clock to get back on the net, chrome doesn't like it otherwise). Let me know if you need anything else |
01-20-2018, 01:29 PM | #77 | |
Rep 506
Does anyone know how to fix this? The script does not work, despite executing it with admin privileges and disabling Windows Defender. Last edited by Celestion; 01-20-2018 at 04:49 PM.. |
01-20-2018, 03:58 PM | #78 | |
124
Rep 274
Cheers, Tony |
01-20-2018, 04:03 PM | #79 | |
124
Rep 274
01-20-2018, 04:30 PM | #80 | |
124
Rep 274
OK, so it seems like the native Windows extractor doesn't retain the original Modified Dates of the files it extracts. That's typical... You can use WinRAR to extract and you should be fine. Too bad this forum won't allow to attach the .RAR format to a post, that would solve the problem immediately. Don't worry, I'll use another method of doing the self-check in the next version Last edited by Tony Twoclicks; 01-20-2018 at 05:59 PM.. |
01-20-2018, 04:50 PM | #81 | |
Rep 506
Now I can launch e-sys, but I am unable to FDL code and instead I am given a FreeToken.est error. |
01-20-2018, 04:50 PM | #82 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Hey Fellas
Thank you Tony for doing this hack. However I noticed Tokenmaster is now advertising Launcher Pro 3.0. Is there a reason why we can't use that? Or what is the reason for continuing to use Premium? I haven't coded my car in a while, but I found some other mods I'd like to do, so am curious as to best course of action prior to starting again. -A
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
01-20-2018, 05:58 PM | #83 | |
124
Rep 274
01-20-2018, 06:00 PM | #84 | |
Rep 1,703
01-20-2018, 06:02 PM | #85 | |
Rep 742
I tried looking online to see which esys works with psdzdata 63 as I need one of the caf files for the 6wb dkombi. Do you know if I can use psdzdata 60 and just pull the 1 CAFD I need from 63?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-20-2018, 06:15 PM | #86 | |
124
Rep 274
Do a search on Google and read Tokenmaster's blog to see what combinations of E-sys, launcher and psdzdata work for other people. I think your Launcher is too old if I had to make a guess. |
01-20-2018, 06:29 PM | #88 | |
Rep 742
I'm waiting on ShawnSheridan to send me a link to the newst esys. Thanks for your help!
clock, date, esys, launcher, premium |
