01-15-2017, 03:58 PM | #1 |
Rep 35
Wheels look to small
Hey guys this may sound stupid but I was wanting some input from others.
Okay so I have style 437m on 225/40 and 265/35 tires and to me they look small but I saw a picture of another f30 335 with the same wheels but he is running 255/35 and 285/30 on his wheels and it looks perfect! I was wondering what is the issue why when I look at my wheels I think they are two small mine are powder coated as well and his are the stock m3 colors Thanks |
01-16-2017, 05:20 AM | #2 |
Rep 953
He has tires that are wider than yours, other than that there should be no difference unless he has wider wheels as well as the tires. If you want a wider look go for wider tires like he has.
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
01-16-2017, 08:26 AM | #4 |
697
Rep 2,079
If the wheels are the same, ofcourse the 225 will look smaller than 255 has the 225 might be too stretch. Mine are 235/40/19x8.5 265/35/19x9.5
01-16-2017, 09:11 AM | #5 |
A family of bimmers
2754
Rep 7,743
Your car is the reason i keep coming back to just wanting to order 437m reps. Looks fantastic with the rocker panel vinyl and overall color scheme of the car.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-16-2017, 10:08 AM | #6 | |
697
Rep 2,079
Pull the trigger you wont be disappointment. JUT FYI. These reps from OEMCONCEPT are not cheap reps from ebay, the quality is there and a lot of member with them. et35 front and et40 rear pair with 235/40 and 265/35 will be good fitment and same OEM high.
01-16-2017, 10:53 AM | #7 |
70
Rep 173
Drives: 2021 M340i
I have a set of these sitting in my apartment waiting to be installed once the winter weather subsides (can't come soon enough) and wanted your opinion on tire sizes. I know you mentioned in a previous thread that 235 in the front and 265 in the rear was a little wide (OEMConcept recommended 225 and 255), but wanted to know if your opinion has changed at all.
01-16-2017, 01:06 PM | #8 | |
697
Rep 2,079
In other words, for 19x9.5 wheels the 265 will fit better than 255. It would all depends on the wheels ET. Here is a shot from rear side.
M4764.50 |
01-16-2017, 01:30 PM | #9 | |
Rep 1,015
225 are just too small for 437m OEM. |
01-18-2017, 03:02 PM | #10 |
53
Rep 259
This. Wider will also help as well. Are you on stock suspension? If so, lower it and decrease the wheel gap from the wheel to the fender and it will also help the appearance.
01-19-2017, 07:11 AM | #11 |
Rep 35
Mine aren't the reps so you think if I went wider it would look better? But decrease the height instead of 40 go to a 35 in front? And 30 in rear?
01-19-2017, 07:12 AM | #12 | ||
Rep 35
01-19-2017, 07:13 AM | #13 | |
Rep 35
01-19-2017, 10:41 AM | #14 |
697
Rep 2,079
Yes, OEM are 10, so you will have to go 35/30 and try 235/265 and pray not to rub as you are on coil
01-20-2017, 12:09 PM | #15 | |
Rep 35
01-20-2017, 12:31 PM | #16 | |
Rep 35
01-27-2017, 08:03 PM | #17 | |
65
Rep 246
01-27-2017, 08:06 PM | #18 |
697
Rep 2,079
Yes, with the M performance suspension.
