Blown Pure Stage 2 Turbo
05-19-2021, 03:12 PM | #1 |
Member
41
Rep 102
Just want to let everyone know that my Pure Turbo Stage 2 blew yesterday on my E92 N55. The turbo lasted around 6000 miles.
The car was running on a 19psi Wedge Performance tune the entire time. Prior to this, I have witnessed four Pure Stage 2 turbos blowing--- 3 of them being from the same owner who additionally blew two warranty turbos (one had a seized wastegate as soon as he drove off). The labour cost wasnt making him too happy, but Pure Turbo didn't care. Just a heads up coming from a person who has seen and experienced it. Go with a Big Boost or don't upgrade at all. These stock housings can not handle the back pressure of even 75% wgdc. Crap turbo, but at the end its your choice!
12' 335i xDrive
Pure Stage 2 11.4s@120mph (Full Weight + 50lb ea wheel on street) // E30 Wedge Performance |
05-20-2021, 09:05 AM | #3 |
24351
Rep 191,163
Im sorry to hear that OP, for a better context in i suggest you post datalogs of your custom tune to see what caused the failure.
It could be a bad turbo or a bad a map that's too aggressive
E93Beast632.50 |
05-20-2021, 10:18 AM | #4 | |
Rep 1,068
335xi
05-20-2021, 01:46 PM | #5 |
Rep 410
I got the 1st gen stage 2 and it's been fine for years honestly, all the way up to 22psi no issues.
08-23-2021, 07:45 PM | #7 | |
39
Rep 182
Drives: 2018 M3 zcp smb
08-23-2021, 08:16 PM | #8 |
21
Rep 135
Well this is a bit frightening to hear I installed a pure stage 2 about 4 months ago and am running a wedge E50 tune has been running perfectly for now.
08-23-2021, 09:07 PM | #9 |
Rep 517
Coming from the n54 side of things, the pure turbos are one of the two most reliable options. What makes this happen with the n55? I know it's a completely different turbo but I would think if they figured out how to do it on n54 they could replicate that reliability with n55.
E93Beast632.50 |
08-23-2021, 09:15 PM | #10 |
Member
41
Rep 102
Too much backpressure for stock n55 turbo housing. I don't blame the tuner at all just failed design.
Go bigboost or go home imo but sold the car. Rod bearing spun, put an f30 motor in my e92 then the last thing I thought would blow blows lol. Buddy with M2 also just blew his ps2 last month as well, also tuned by wedge and no he doesnt go to the same shop as me.
12' 335i xDrive
08-23-2021, 09:28 PM | #11 |
Member
41
Rep 102
Forgot to show you guys the updates lol
12' 335i xDrive
08-24-2021, 08:21 AM | #12 |
39
Rep 182
What's even more sad is when I think about it- I wasn't even pushing the turbo hard. Boosting 18psi, with tiny spikes in the 19s every once in awhile.
It happened in a first gear pull and reached a peak of 16psi. I'm terribly disappointed and frustrated as this is my daily driver. Yeah the car will run still minus the turbo whistling/ howling and clouds of white smoke be blown everywhere. |
08-24-2021, 01:16 PM | #13 |
Rep 1,525
Something here smells fishy. I was one of the original 10 or so to go with a Pure 1, then later a Pure 2. I am running strong. PI with 24 psi boost. Not one guy has come here with a blown Pure turbo in all these years. Now all of a sudden somebody comes here with 3, or is it 4 failures? Is it the lack of octane in the fuel up north?
08-24-2021, 03:13 PM | #14 | |
39
Rep 182
08-27-2021, 04:57 PM | #15 |
Rep 601
Unfortunate. I was thinking about upgrading turbos but seeing threads like this makes me change my mind.
I'm on 16-18 psi on stock turbo with mhd/jb4 for 45k miles on 92 octane and the car still boosts up to target fine.
Vermillion Red
08-27-2021, 06:10 PM | #16 |
Rep 1,525
You better stay away from the rod bearing threads Vampire.
08-27-2021, 06:21 PM | #17 |
Rep 601
My n55 engine is late 2011.
BMW made revisions to each engine by the build month and date for the N55. A part of this was rod bearings and fixing the vanos issues The pistons on the n55 suck though. Especially since bmw runs these cars hot. I still see metal shavings in my oil and don't expect my car to last "forever". They made the pistons better on the m2 n55 which was the N55B30T0. The torque and power on x drive tuned with a curb weight of 3800 lbs is too fun to give up or get something else lol. With the hydraulic steering and upgraded suspension all around the car is more fun to drive than a lot of performance cars I have driven
Vermillion Red
08-28-2021, 10:05 PM | #18 | |
Rep 710
08-28-2021, 10:41 PM | #19 | |
Rep 601
I purchased my car at 60k miles years ago and did a few oil analysis with the vehicle tuned to see if I should put money into the car and if the engine is good. I sent the results as an attachment. I haven't done an oil analysis the past 20k miles because I thought it would all be the same. I change my oil every 5k miles. I use liqui moly 5w30. I am at 104k miles right now One thing I'm worried about is the vehicle is running hotter than usual the past few months. really don't know why or if it's me reading all these threads popping up with tuned cars and rod bearings as these engines are tested as time goes on and more information comes out. I changed my water pump/thermostat since I was getting BSD codes and the car still runs the same heat. I just recently did an oil change and saw metal shavings but car has no knock. I thought small shavings is normal in oil. My car doesn't sputter and it drives smooth with no nose from engine as rpm goes up. I noticed during my recent oil change the oil smells like gas and I believe that was because my pcv breather valve was damaged and not allowing the engine to breath properly. Seeing threads like this gives me some hope because my metal shavings are similiar to this person https://www.e90post.com/forums/showthread.php?t=1582205 Im sending my recent oil change to see if it's anything alarming.
Vermillion Red
09-05-2021, 04:11 AM | #20 |
39
Rep 182
So disappointed
09-08-2021, 09:19 AM | #21 | ||
1208
Rep 2,028
Cut your filter open and see what's in the pleats. Anything more than a handful of flakes across the entire filter and you've got an issue... The N55 is 10+ years old of course you will see failures. All engines fail and it's nothing "new" coming out. The N55 pistons suck? What do you mean... how so? BMW changed the rod bearings? How so? Elaborate please if you're going to make statements like this. And without posting logs of your car you can't just blindly blame PURE. Maybe WEDGE is the common denominator in those turbo failures? Or maybe it's the owners... With that being said, a handful of blown PS2 means nothing. They've sold thousands of them across the vast lineup of N55 vehicles. For a hybrid turbo the failure rate is extremely low. Stock turbos fail too lol. It's still not common. EDIT: Quote:
Either the owners with broken cars or WEDGE giving people tunes that are too aggressive for their setup/fuel. Last edited by bbnks2; 09-08-2021 at 09:32 AM.. |
Torgus3781.50 |
09-09-2021, 06:37 AM | #22 |
309
Rep 394
