Blown Pure Stage 2 Turbo
09-14-2021, 03:26 PM | #23 |
39
Rep 182
Drives: 2018 M3 zcp smb
17 psi max
82% wgdc 12.5 AFR Not an aggressive tune whatsoever. Have fun boys. https://datazap.me/u/j3good/log-1628...og=0&data=3-11 |
09-14-2021, 10:34 PM | #24 | |
Rep 711
09-14-2021, 10:50 PM | #26 |
Rep 711
Another observation - heat can damage the turbine, but you're missing a compressor blade. That would eff up balance and destroy your turbo. I'm not sure why you'd throw a compressor blade though? Have you checked your air filter? Sucking in a foreign object could probably do that. I don't know, maybe it could even break off from rubbing the compressor housing if the bearings were shot? Just spit-balling here...
09-14-2021, 11:05 PM | #27 |
Rep 711
One more thought - with how long it's taking to spool at 100% wastegate duty cycle, there's probably a ton of back pressure between your exhaust valves and your turbine before she really starts to spin. High back pressure will also promote high exhaust temp, as the gases won't expand (and therefore cool) as much coming out of the exhaust valves
09-16-2021, 02:44 AM | #29 | |
39
Rep 182
09-16-2021, 02:53 AM | #30 |
39
Rep 182
Make no mistake the guys at wedge are good at what they do and are on the conservative end when it comes to tuning
09-16-2021, 06:32 AM | #31 |
Rep 711
Sorry, I was looking at the WOT portion of your tune. I zoomed in on the WOT part of the log, and didn't bother to look at rpm, as most people won't start a WOT logging pull until around 2500 - 3000 rpm anyway to avoid lugging the engine. But my bad, I should have looked at your rpm too.
09-16-2021, 06:37 AM | #32 |
Rep 711
Anyways, being at 1700 - 2600 rpm doesn't negate the fact that you're very lean there at WOT, have way way high stft, and have a ton of corrections. Not necesarily the tune's fault, but something is going on there that's not good. If it was my car I'd be trying to get that sorted out.
bbnks21208.00 |
09-20-2021, 08:54 AM | #33 | |
1208
Rep 2,028
It's a 3rd gear log... starting a pull at 1700rpm is not uncommon at all. I usually start mine at 2,000rpm in 3rd and 2500rpm or so in 4th. Not hitting 17psi until 3500rpm is a bit excessive. 82% wgdc to make 17 psi also seems excessive. The timing corrections are also pretty bad. @J3 your car was not running well at all and the fact that you think it was is very telling as to why you ended up shooting turbo guts out the exhaust. Last edited by bbnks2; 09-20-2021 at 09:16 AM.. |
Kevin39164.00 |
09-21-2021, 07:09 PM | #34 | |
39
Rep 182
Good job on displaying your knowledge! I'll go ahead and let you keep those 2 cents in your pocket bud. Update: Pure sent me stage 1 because there was a long wait time on stage 2. Car is running fine. |
09-21-2021, 08:24 PM | #35 | |
1208
Rep 2,028
Elevation making the log look bad is still the log looking bad. But yeah blame Pure and claim your logs looked good lol. "The 5-6* timing corrections were when there was no load." Last edited by bbnks2; 09-21-2021 at 08:53 PM.. |
Kevin39164.00 |
09-25-2021, 09:07 PM | #36 | |
309
Rep 394
yeah, it calls for different AFR, valve timing, etc. but even then, a commanded AFR should not trigger fuel trims, regardless of the original AFR in the stanard fuel tables. (edit - especially if MAF is working properly AND lambda) Set spool mode max rpm to 1rpm. Try again. |
09-29-2021, 02:04 PM | #37 |
21
Rep 135
@wheela bbnks2 what's up guys ! After reading through this thread it got me super nervous but you both kinda put those nerves at ease with your comments lol I was wondering since I'm in the same boat as the OP minus the blown turbo of course I was wondering if you could look at my logs if you had the chance ? I'm pure stage 2 running an E50 mix from wedge and just wanted another set of eyes on things other than the tuner to see if there's anything you guys see that might need further looking at. Seems like you're both at the very least much more knowledgeable with these things than myself and I'd appreciate the review on the logs or any comments/concerns. These logs are 3rd and 4th gear respectively both from about 2500 RPM till redline. If anyone else wants to chip in as well feel free !
https://datazap.me/u/hunter3/wedge-t...&data=3-13 https://datazap.me/u/hunter3/wedge-tune?log=0&data=3-13 |
09-29-2021, 05:12 PM | #38 |
39
Rep 182
UPDATE:
First off, even Pure said my logs looked fine. The only concern they had was afrs in 12s but I've spoken to many people about this and it's general consensus that 12s is not considered lean or catastrophic whatsoever on these motors. I still think Pure is a great company, sometimes shit just happens. If any of you think an auto parts manufacturer can have a 100% product success rate, then you're kidding yourself. Even if it's 99% which is incredible, there's 1 out of 100 that goes bad. Is it too crazy to think maybe I got that "1"? Why else do they offer a 1 year warranty?? Pure has covered the rebuild under warranty. END OF STORY, so go suck it you keyboard experts. |
09-29-2021, 05:20 PM | #39 | |
39
Rep 182
Oh yeah- Pure has covered it under warranty so go kick rocks. Last edited by J3; 09-29-2021 at 05:34 PM.. |
09-29-2021, 05:29 PM | #40 | |
1208
Rep 2,028
IF pure is covering it under warranty and "shit happens' wwhen why are you here posting about it in a thread about them being bad turbos. |
Kevin39164.00 |
09-29-2021, 05:40 PM | #41 | |
39
Rep 182
LAST- because i want to. I want to share my experience in case anyone else goes through this and ACTUALLY BE HELPFUL TO OTHERS. I have nothing else to replace it with. I'm stuck. They already took my old core you genius. Again, I never dogged Pure. I went through a shitty situation and I'm glad they took care of me. I don't know why you got some sort of extra hard on for them but obviously you don't work for them bc THEY ARE MUCH COOLER AND HELPFUL than your arrogant ass. It's not a IF. THEY ARE COVERING IT UNDER WARRANTY Last edited by J3; 09-29-2021 at 05:50 PM.. |
09-29-2021, 09:42 PM | #42 | |
Rep 711
09-29-2021, 10:19 PM | #43 | |
Rep 711
What kind of fuel system upgrades are you running? Are you doing any port injection or just DI with upgraded pumps? |
09-30-2021, 04:06 AM | #44 |
21
Rep 135
@wheela bbnks2 thank you both for looking it over ! Glad to hear that everything looks pretty solid. The car really does feel great and it's just the base map we haven't done any revisions yet. Running dorch stage 2 HPFP and Precision Raceworks stage 2.5 bucketed LPFP. Didn't want to go the PI route just for the simple fact of not wanting to do science projects with all that lol too much thinking. Doing an E50 is simple enough for me. Problem is after I get used to this power I'm just going to want more and that seems to be the route to squeeze out some more. Alternatively I've been hoping for that Pure 800 to release and maybe have that as an option or just a bigger turbo in general not sure how much gains on the same set up with a bigger turbo would be though.
