04-29-2021, 02:08 PM | #1 |
Rep 596
Roofing questions
I'm getting a new roof (NE FL). I'm getting mixed messages about types of underlayment. Do any of you have any input on cons of getting "peel and stick" versus more traditional, non peel and stick? (Like the old tar paper except that nowadays it's a synthetic, plastic or tyvek-like material.)
Gracias! |
04-29-2021, 03:27 PM | #2 |
6684
Rep 2,343
Drives: 9Y0 Cayenne S
Do you live in a typical Florida "community"? The past two times I have visited Florida, there have been several houses in the communities getting new roofs. The type of construction is generally consistent within a local area. I haven't noticed the underlayment in these examples, only that the outer material was tile, with grout filling in key places.
Who are you asking about underlayment? Homeowners or roofing companies? Try visiting 2 different Home Depots and 2 different Lowe's in your area and ask at the pro desks what is best/most common. |
04-29-2021, 04:27 PM | #3 |
Loves me some MHD!
1866
Rep 1,725
We're in NoFla, just a tad bit west of you, and did a new roof & skylights about 5 years ago. Used the peel & stick because the advantages far, far outweigh the issue of, maybe, should it ever be needed, removing it being a hassle 15-20 years down the road.
P&S underlayment is, from what I've seen, actually really great for laying over, so unless it doesn't do it's job there shouldn't be any reason to remove it. If you do need to, you're replacing plywood, making the process not really all that bad. Otherwise just install the new and move on. After that we're probably 40 years down the road, and won't be using wood products any more.... (minor sarcasm, but ya never know...)
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
charlie fairmont478.00 |
04-29-2021, 04:50 PM | #4 |
Rep 1,004
Also if you’re coastal, talk to your insurance company - you may find one or another type of roof has a significant discount (or premium) in your ins rates.
We’re between St. A and Daytona |
04-29-2021, 05:18 PM | #5 | |
Rep 3,219
04-29-2021, 08:41 PM | #6 |
Rep 596
Thanks for the insights. I can't figure out how to multiquote.
Chassis, I've been asking roofers, which is what prompted the question here. P&S is an upcharge but rather than trying to push it, several advised against it. And mercifully, I'm not in a "community." 1and1, thanks for the comments. Absent any horror stories that pop up on the next few days, I'll be going the p&s route. 2000cs, good thought. Hopefully there's a material benefit. I was recently disappointed with the discount I got for newly installed hurricane-rated windows. Or maybe neither by themselves was worth much but taken together it'll be a nice savings. Chihuahua, thanks for the inside know-how. Up here we've largely escaped the miami-dade codes (as far as I know) but like the windows I just had done, I like the idea of miami-dade code even if we don't get hurricanes like you guys do. The package I'm looking at and about to pull the trigger on is all GAF so that's nice to hear that's what a roofer chose for his own house. |
