It's under the knife!!.....I EXCITE!
08-28-2009, 06:46 PM | #24 |
Rep 10,587
just realized this afternoon that one of the mod's/admin's put my "build" thread on the front page of bimmerpost.com.............. COOL!
08-29-2009, 10:29 PM | #27 |
Rep 10,587
CLEAN!!!
08-30-2009, 07:39 PM | #28 |
Rep 10,587
UPDATE 8/30
Got a little more time....30 minutes or so and opened up the 35r to "reclock" it and rotate the compressor housing to match the old turbo. Also took the time to degrease and clean the compressor housing. Nothing crazy, more coming tomorrow night....god willing it will be mounted. Got it apart Compressor Housing (no gasket) Rotated to match the 60-1 Random parts laying around the garage, will have these organized and cleaned tomorrow too Downpipe and Wastegate pipe mid pipe and charge pipe
08-31-2009, 12:48 PM | #29 |
Rep 1,210
So, with this new found power, the deer won't walk away like last time.
08-31-2009, 02:22 PM | #30 |
Rep 10,587
exactly, I can have ground venison at will
08-31-2009, 03:06 PM | #31 | |
Rep 704
poor Sniz always reminded of that deer. Although with the size of that turbo I think he'll be able to take on Moose!
08-31-2009, 08:27 PM | #33 |
15
Rep 201
Wow Matt - you're going whole hog on that baby. I got dibs on the next ride after Scott; as long as he cleans the seat after he gets out.
08-31-2009, 09:17 PM | #34 |
Rep 10,587
UPDATE 8/31
Spent about 2 hours working on the car/turbo tonight.....work keeps getting in the way of my fun!! test fitted the gt35r to find 2 points of contact with the transmission/engine block. Problem #1 This fitting for the vacuum hose for boost control is in the wrong spot. Previous owner had the compressor housing 180 degrees in the other direction so it worked for him. Had to remove it. Will find a brass plug for this hole tomorrow and find someone to retap in a better location. Problem #2 and then the exhaust housing is/was contacting the transmission here. Spent about 30 minutes with a grinding wheel and got my clearance ITS ON BABY ok, well now its off, have to get that fitting retapped tomorrow and then it will be on for good. I have a weeping oil pan gasket and rear main seal as you can see here. These will be addressed this winter once I have more downtime on the car. thats it for today
09-04-2009, 08:01 PM | #36 |
Rep 10,587
9/4 update
Spent some more time over the past 3 days and got the turbo retapped, installed which required a few trips to Sears for shorty box ends to reach all the bolts/nuts, installed the hoses and clamps, removed all piping and degreased everything, tore apart the cooling system and installed a new Stewart water pump, low temp tstat, and tried to install a new fan switch but it seems to be the wrong one?? anyway, here are the updates, getting closer!!! drill press drilled tapped my helper....lol these things are GREAT, very adjustable and are designed for handing drywall the nuts holding the turbo onto the TT mani are a bitch to get at w/ the 35r, much worse than the regular 60-1. Anyway its up, tight and all hoses on. I put clamps on the hoses after this shot. I reclocked the compressor housing to gain as much ground clearance as possible....looks good! Ripped out all turbo hardware and piping and degreased and rinsed intercooler was cleaned and rinsed out, remounted Took out the water pump, not sure which one the old one is but it didnt look very good compared to the new Stewart one and here is the new fan switch, wrong one...hmm. new on left, old on right
09-04-2009, 08:16 PM | #38 |
Rep 10,587
no I wont....would love to be though
09-04-2009, 08:58 PM | #39 |
Rep 704
Looks like you got that fan clutch off. Wrench and hammer work out alright, or did you figure out a new way to do it?
09-04-2009, 09:09 PM | #40 |
Rep 10,587
gigantic 32mm wrench.......long ass flathead screwdriver.....and big hammer did the trick
09-04-2009, 09:34 PM | #41 |
//Mdicted
348
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
wow ! this thread is getting to be real interesting
09-05-2009, 03:51 PM | #42 |
Rep 10,587
9/5 UPDATE
worked this morning and met a very good new client.... he alone could possibly pay for this entire car and all upgrades twice over......sweeeeeeeet so i'm getting closer, put all turbo piping back on, hooked up the MAF, etc. Also rewired my HID's for the headlights and hid the ballasts so they are no longer in the engine bay...cleaner. I did run into a problem with lining up the charge piping with the new turbo, looks like I'll have to have this pipe altered a bit to make it line up, oh well. then spent almost 2 hours cleaning all the wheels and re wheel waxing them then remounted. Also refilled the cooling system but will have to wait to bleed it, which sucks. as she sits now, ready for the front bumper and other trim pieces to go back on, then on Tuesday its off to the shop for some welding and custom work and then ITS GAME TIME BABY!! funny, Adam did a little burnout in his 335, had to get a pic of this. He needs to lay down some rubber in here w/ his M5 too more to come tomorrow!! Hoping to have it all buttoned up by then. Need to wash the engine bay out, there are metal shavings everywhere from grinding down the tranny.
09-05-2009, 04:09 PM | #43 |
Rep 1,252
2012 528XI Saphire Black
Stock for now 2007 e92 335i - Monaco Blue Injen DCI w/ Cyba Scoop - M-Tech Rear - ///M3 Rear Lip Spoiler - ///M5 SMG Shift Knob & iDrive Knob - BMW Performance Hand Brake - BMWCCA Member |
09-06-2009, 04:19 PM | #44 |
Rep 10,587
last update until it comes back from the shop. Will get flatbedded Tuesday over to MA-Motorsports here in Baltimore for all the custom work. See here: http://www.mamsparts.com/
Got it all buttoned up today and ready to roll, well almost. Got the bumper mounted up with the help of our 2 trusty Craftsman detailing seats All trim and x-brace back on. It sure is nice to have some real rubber up front :evil2 Pushed it back to the wash pit to degrease the entire engine bay now that its all back together. Main concern was small metal shavings ALL over the place from where I had to grind down the tranny a bit, wanted those gone. All clean!! and before anyone says anything, I have a m50 manifold sitting ready to go in. Just haven't picked up the necessary little parts yet. Thinking of having MA custom fab me a full metal "up-pipe" from the intercooler to the MAF to get rid of that huge silicone section. Would also allow me to relocate the BOV for a little more clearance from the body. Pushed back up where it will sleep until Tuesday and in case stupid comes to town I'm seein the light at the end of the tunnel, car has only been out of commission for I think a week and a half or so but i'm already seriously antsy. Want it back on the road!! Will report back when more is happening
