      12-28-2023, 07:05 PM   #23
PRTSB1M
Drives: AW3 1M
Originally Posted by JupiterBMW View Post
Yes, I actually just saw you were using it as well, its such a great upgrade! I still have to upgrade the engine oil cooler, but I'm using the factory E9x M3 cooler, and the do88 upgrade won't fit. Likely going to set up a custom cooler from Setrab at some point.
If you reach out to HKP tuning and ask about this extension kit that mounts on the opposite side, you might be able to get another hose to go with it to expand oil cooling capacity.
https://www.hkptuning.com/products/m...35i-1m-n54-n55
      12-28-2023, 11:14 PM   #24
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
Hmmm, would be tough to daisychain that one from the factory E9x M3 oil cooler I'm using now. Would require a lot of custom work to fit. I think I'll probably just get a setrab cooler that better fits in my front bumper hole. I found that a large portion of my oil cooler is hidden behind the lower portion of the front bumper (you can see it in the front end pic I posted earlier). If I can get a cooler that fits in that opening, the airflow/heat exchange will be MUCH better.
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      12-29-2023, 06:24 AM   #25
PRTSB1M
Drives: AW3 1M
Oh wow, yeah, I hadn't noticed it is tucked in the bottom like that. Almost looks like you could just move the E9x M3 cooler you have up below the actual bumper and it would get proper air flow across it.
      12-29-2023, 02:07 PM   #26
JupiterBMW
JupiterBMW's Avatar
Yeah, and seeing it with the bumper off, you quickly see that there's no real easy way to just relocate it. The M3 hoses aren't that easy to move around. There is a company that makes -AN adapters for the oil cooler lines so I can then run custom lines/hoses to any cooler I want. Eventually I'll go this route.
      01-02-2024, 09:31 AM   #27
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
Really? I could not find anything when I built mine. I had some adapter blocks made up:
https://www.m3post.com/forums/showpo...ostcount=23386
      01-02-2024, 08:39 PM   #28
JupiterBMW
JupiterBMW's Avatar
Those look pretty good. The ones I found were from Rogue engineering, cost is low too, but then you need oil cooler lines. Not hard to make a set though. I just need to map out the right Setrab unit and then build some brackets.
https://www.rogueengineering.com/Rog...ngs_p_324.html
      01-03-2024, 02:15 AM   #29
Gneiss
9
Drives: 2009 135i
Slight tangent, but when using your Quick Jack do you use jack pad adaptors, or do the rubber lifting blocks spread the weight across evenly enough you don't need them?
      01-03-2024, 07:57 AM   #30
amg6975
amg6975's Avatar
500
Oh yeah, nice. Those definitely didn't exist when I built mine. I elected to keep as much hard line as possible since they have to route around some belts and pullies.
I ended up with a generic CSF core that I made a bracket for that seals off most of the flow in the lower opening, and then ducts down and out the bottom like the stock M3 air path. Works mint.
      01-03-2024, 11:26 AM   #31
JupiterBMW
JupiterBMW's Avatar
Awesome, would love to see some photos if you have them. I'm by no means tied to the Setrab, that's just the first website I started perusing..
      01-03-2024, 11:28 AM   #32
JupiterBMW
JupiterBMW's Avatar
I use the square rubber blocks that came with the QJ setup, and then the 4 factory blocks that plug into the underside of the car. I don't use any sort of adapters. I figure two square blocks on top of each other is pretty stable. The QJ blocks are quite a bit larger than the factory jack pads, so they get complete contact. And being lifted evenly at all 4 corners, not sure how much more stable it can get. The QJ setup was honestly some of the best money I've ever spent...
