ZPOST
  TireRack
      04-12-2013, 07:52 PM   #1
3point0
3point0's Avatar
27
Drives: 2005 z4 3.0
2006 Audi S4 Avant  [0.00]
2005 BMW Z4  [5.67]
window adjustment
Does anyone know how to remove the door handle to get to the window adjustment screws? I've been trying, in vain to tweak my drivers door window as I have a really annoying air gap around the window seal, it's driving me nuts. I've tried the reset, the adjustments at the bottom of the door, the gummi pfledge, and even removing the seal section and stuffing full of foam pieces to try and bulk it out, but I can still see a sizeable gap in the seal and i just need to lean the window inwards a bit, just like the passenger side is to create a good seal.
I read somewhere that there's an adjustment that can be made to tilt the glass inward in its raised position once the door handle / latch assembly is removed. I don't have a working version of TIS right now (my xp laptop is playing up and I can't figure out the install correctly)
Anyone have any experience with this?
Thanks
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector
OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips
      04-13-2013, 04:33 PM   #2
GP20
97
Drives: Z4M, F80 M3, 991.2 GTS
I believe it can be adjusted without removing the door handle. There's a plastic cover at the bottom of the car, closer to the back of the car. Remove it and you'll be able to adjust the window tilt from there.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      04-15-2013, 07:13 PM   #3
3point0
3point0's Avatar
27
Drives: 2005 z4 3.0
2005 BMW Z4  [5.67]
I had a quick look but I don't see anywhere obvious, maybe you can show me on Friday
      04-16-2013, 06:59 AM   #4
McKoval
Poland
Drives: z4 3.0si 2006
You can look up how to regulate the window in here:
http://bmw.workshop-manuals.com/Z_Se...ex.php?id=1612
And how to remove a door handle itself HERE:
http://bmw.workshop-manuals.com/Z_Se...ex.php?id=1468
2006 3.0si
      04-16-2013, 12:00 PM   #5
pyo
Drives: 2022 X3MC
Thanks! did not know of this resource.
I actually need to adjust my passenger side..
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      12-30-2023, 12:27 AM   #6
Tuna!
Drives: Z4 e85
This guy had the exact same problem though it was a different car.
I’m positive this problem was caused by someone replacing the window but not doing it correctly. Also because the previous owner left me with a lot of odd parts for the car and a broken square window bracket was one of them
      12-30-2023, 12:31 AM   #7
Tuna!
Drives: Z4 e85
Is there anyway to adjust the front bracket?
      12-30-2023, 12:36 AM   #8
Tuna!
Drives: Z4 e85
Also the things on the bottom of the door tilt the window inward and outward? But do they tilt the window the other axis?
      12-30-2023, 12:41 AM   #9
Tuna!
Drives: Z4 e85
Kinda thinking the front bracket needs to be adjusted but not looking like theres many options unless I completely redid the front bracket.[IMG] https://ibb.co/Qvw9fFp [/IMG]
Is the bracket supposed to have that much tilt?
adjust, adjustment, noise, seal, window
zpost
