05-27-2021, 11:30 AM | #45 |
449
Rep 277
Thanks! The uprights are from HARD Motorsport, the E90 kit. Not sure on fitment for the CSL lid.
2009 Widebody 135i ///Build Thread
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. |
06-04-2021, 09:59 AM | #47 |
449
Rep 277
So, 5 weeks and still no Turbos, but supposedly Pure is building the N54 turbos this week. Anyway, in preparation for this I started the work to pull the stockers. I have had no issues with my water pump, but I'll most likely replace the thermostat, pump, and some of the hoses while I have easy access. Car is at 46k.
The parts I do have are the second oil cooler, front Ohlins coilovers and relocation inlets and outlets.
06-04-2021, 03:36 PM | #48 |
449
Rep 277
Turbs ready to come out. Time for a beer(s).
wdb4736.50 |
06-09-2021, 04:39 PM | #49 |
449
Rep 277
Some of the boring stuff arrived, still no turbos..
wdb4736.50 |
06-09-2021, 05:10 PM | #50 |
California-bound
385
Rep 1,480
Looks like a fun build.
Friendly tip: re-think those spring rates/shocks. For the amount of tire and aero you're planning, the car will be massively under-sprung.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
06-09-2021, 08:20 PM | #51 | |
449
Rep 277
I spoke with Barry from 3DM about my setup and the 80/140 is what he recommended for track use. Since I am changing so much at once, and since theres not another build quite like this it's hard to know exactly what to expect.
06-10-2021, 04:10 PM | #52 |
California-bound
385
Rep 1,480
The dampers are nice units, however, if I was doing my build over again (I've since demodded my track 1er and made it a fun daily), knowing what I know now, with my old setup (255/265 track tire, max effort stock body fitment), my car was way too soft with 400 lb/in fronts and a 700 lb/in rear spring. Tire wear sucked and the car handled lazily.
Even with my stock body fitment, I would start at something like 500 lb/in fronts and a minimum 800 lb/in rear spring, and probably settle on something like a 900-1000# rear spring, given the awful motion ratio that the E82 is working with. If those shocks can keep up with spring rates in that area, great! I suspect with that big wing, you'll end up migrating towards a very stiff rear spring in the end. For perspective: my new track chassis has the same basic suspension setup, similar tire sizing, less weight, with a slightly better rear end MR and I've landed at 600/1000, no aero, and it's fantastic. A lot of factors (setup, tracks, driver preference) go into the numbers I'm tossing around, so consider it a rough starting point, and information I wish I had all those years ago. Be mindful reading the forums here that most people parrot information blindly, and the actual fast drivers have long since learned from the collective thoughts and posts from years ago. I listened to this the "common consensus" on here many ears ago and my car sucked to drive until I started thinking more critically about setup and actually testing changes on track, and backing them up with lap times...
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 Last edited by Ginger_Extract; 06-10-2021 at 04:16 PM.. |
dtla1827.50 |
06-10-2021, 09:47 PM | #53 | |
219
Rep 361
-Mark
2011 BMW 128i - Check out my STX build thread!
06-11-2021, 10:29 AM | #54 |
449
Rep 277
Appreciate the advice. I'm sure I will have a lot of adjustments to make when the car is finished and I get some seat time. Based on your experience, it sounds like my springs (450/800) will be under sprung. The car will still see some street use so it may not be too bad of a starting point.
06-15-2021, 08:31 PM | #55 |
449
Rep 277
Turbos are out. My Pures should arrive tomorrow. All in all I'd say it took about 9 hours.
I noticed far more carbon buildup on the rear turbo than the front. I also noticed some oil in the inlet. I dont run a catch can, but I probably should pick one up and replace the PCV valve. My other dilemma is, I bought MMP silicone relocation inlets and outlets, probably 4 years ago and they've been sitting, waiting until I replaced the turbos. Based on what I've read, the silicone outlets commonly fail, so I am debating using the silicone replacement inlets with stock outlet, or get an upgraded aluminum outlet. Not sure an upgraded outlet would do much except potentially cause reliability issues. Thoughts?
wdb4736.50 |
06-16-2021, 05:14 PM | #56 |
449
Rep 277
Turbos arrived. They forgot to send the install kit though..
07-09-2021, 04:52 PM | #57 |
449
Rep 277
Haven't had much time to wrench lately. Just got the Pures on loosely. Going to ditch the silicone outlet pipe and stick with the stocker. I've read nothing but problems with aftermarket outlets. I will be putting the relocation inlets on.
wdb4736.50 |
07-11-2021, 03:30 PM | #58 |
449
Rep 277
So after loosely fitting the turbos/inlets, I've determined that heat will definitely be an issue here. I am going to get a pair of turbo blankets and I may also add the RB turbo manifold heatshield with heat tape.
For the heat blankets there are options from Forge, PTP, Mishimoto, and Heatshield products. They're all rated for 1800F continuous, and all are made from similar materials. I'll most likely go with Forge since it's the least costly, and looks to be on par with the others. I could then wrap the metal shield in Heat Tape and position the rear turbo inlet over this, and it should keep IAT cool. I am hopeful that all of this insulation with shorter and larger diameter passenger side inlets that the IAT will be cooler than what can be achieved with any driver side inlets.
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. Last edited by Dieselboy; 07-11-2021 at 03:36 PM.. |
houtan707.00 |
07-14-2021, 12:22 AM | #59 | |
Boost
1354
Rep 3,693
Drives: 135i M-Sport
I real liked the 550/850 setup with stock rear sway and Dinan front. If I ever get back on track again (newborn+new job+moving has really killed my track time) I'll definitely invest in some adjustable sway bars... Wish I picked some up sooner to dial in the car at a test and tune day. Build looks awesome! Excited to see the finished product.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
07-15-2021, 07:58 PM | #60 |
449
Rep 277
The turbo manifold blankets arrived. Not impressed with the stitching on these, but once they're in they should be fine. I also wrapped the outlets with heat reflection tape. I may wrap the inlets as well, but I'm not sure how well it will hold up on the silicone. Getting the rear inlet on is going to be a nightmare...
07-23-2021, 05:58 PM | #61 |
449
Rep 277
I pulled the stock oil lines from the stock oil cooler. There was a small protrusion on the fitting that didn't allow my adapter to sit flush so I took an end mill to it. Now i will be running AN lines from the engine to the stock cooler, over to the Setrab cooler and back to the engine.
I also bought a welder so I'll be custom fabricating a mounting bracket for the new oil cooler.
wdb4736.50 |
07-25-2021, 08:41 PM | #63 |
449
Rep 277
Thanks! You and me both.
Got the Turbofold blankets on. Got the manifold heatshield wrapped in the heat tape. Heat shield and blankets on. Secret to getting the rear inlet on, remove the wastegate actuator bolts and swing it out of the way. I thought this was going to be a nightmare based on what I read, but it wasn't bad, and if the vertical portion of the inlet was longer it would have been cake. Inlets relocated. Turbos, new water pump, low temp thermo, etc.. installed.
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. Last edited by Dieselboy; 07-25-2021 at 08:52 PM.. |
08-01-2021, 05:09 PM | #64 |
449
Rep 277
So I bought a welder. It's something that I've wanted to learn and should be useful for this build. Flux core should be fine to start with, but eventually I'll buy a shielding gas cannister and move on to MIG.
Next step is to get the second oil cooler mounted. I am going to try and mount it in a similar location to stock and buy the left side 1M oil cooler ducting to optimize air flow. I'll cut the left side fender liner to match the right side air duct exit with BMW parts. I'll also need to relocate the horns.
SKI-R159.00 |
08-03-2021, 12:17 PM | #65 |
Rep 647
FYI you can buy the driver's side ducting and brackets and everything directly from BMW, I don't have the PN on hand but there's a kit that includes the horn relocation and everything.
08-05-2021, 11:28 AM | #66 |
449
Rep 277
I saw that. The 1M duct is quite a bit smaller than the Setrab cooler I have so I may customize the stock 135i duct to feed into a bigger shroud.
