M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      09-19-2017, 03:03 PM   #23
UnfoundLegend
UnfoundLegend's Avatar
Drives: '14 F13 M6 Coupe
Here's the video of my DTML
The RPM spectrum is very nonlinear
      09-19-2017, 03:04 PM   #24
kevn23
30
Drives: -
My car would get Drive Train Malfunction with the SSP filter (also installed SSP Spec-R). I would lose 2, 4, 6. Then as the car comes to a stop all the higher gears (7, then 5, then 3) and finally only have 1st gear. Restart and everything is fine, but then DTM a minute later. Swapped out SSP filter for OEM filter and everything was great, haven't had a problem since.
      09-19-2017, 03:09 PM   #25
schnell1982
Drives: FAST
Interesting. Thank you for sharing.
By chance have you contacted Kris at SSP about this issue ?
      09-19-2017, 05:35 PM   #26
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1090
Drives: 2018 RS3, 991 Turbo
My view is that its not mechanical nor the sensors (part of the TCU). When I swapped trans, I kept the original TCU... and no issues.
It is possible the valve body assembly deteriorates. I haven't done much research but the valve body that pumps oil to facilitate the 4-5 shift may be getting clogged or have some inherent weakness. So, the shaft doesn't move correctly and throws a code. If it was mechanical the symptoms will be different. Upon inspection of my DCT, there were NO obvious mechanical issues
      09-19-2017, 08:00 PM   #27
ARC550
Drives: M3, X5, 720s, X5, 750xi
Very interesting fine... perhaps if a full trans flush is done with new OEM filters this could greatly improve if not fully eliminate this issue.. kind of like a artery Cleanout ahhahaha
      09-19-2017, 08:11 PM   #28
apexlocator
Drives: 2014 M5
I had this issue also. Except I didnt go as far as driving around with the SSP filter installed. When the installer told me the car would not complete the relearn process after the filter was put in, I had him leave it out. This was done when I was having the SSP specR clutches put in. Zero problems with OEM filter and SSP clutches.
I contacted Kris and will send the filter back for him to look at.....havent gotten around to it yet.
2014 "AW/SO"me M5
Mission Performance/3.5 Bar
RK Autowerks/ CSF ICs
SSP Spec-R
KW V3/ Corsa Axle back
      09-19-2017, 09:31 PM   #29
Mcc420
Mcc420's Avatar
475
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I'm thinking it's a software issue. A computer is probably seeing to much torque in this gear. I say a computer because I don't know which one but its most likely the one people aren't tuning. So it's probably the dct ecu that's not liking the torque value for that gear.
      09-19-2017, 10:29 PM   #30
ARC550
Hmmmmm... I wonder to what extent if any if ECU for the Trans is tuned when the Car is tuned for more power.
      09-19-2017, 11:08 PM   #31
allmotor_2000
1090
It isn’t torque values - I tried stock flash and various power/boost levels and once the problem occurs it occurs at all power levels.
Mcc420475.00
      09-20-2017, 12:40 PM   #32
schnell1982
Drives: FAST
Interesting, I have installed 3 SSP Spec-R DCT clutches along with the cooling system upgrades and have not experienced this with any of the cars.
      09-22-2017, 11:18 AM   #33
allmotor_2000
1090
I have a research paper on the BMW DCT if anyone is interested - you can learn everything about its design and operation. It's around 1.7MB
      09-22-2017, 11:53 PM   #34
M5Rlz
249
Drives: R8, f10m59(Rip), m4, GTR
You ain't seen nothing yet... some big power coming from a few people!!
I'll be curious how your gears hold up, not these computer glitches causing limp modes, but actually losing a part.
      09-23-2017, 03:37 PM   #35
allmotor_2000
1090
Let’s wait and see....
      09-23-2017, 03:56 PM   #36
M5Rlz
249
For GTrs they are quite capable at holding power, but when they get hot (repeated pulls) thats when even the strong/ lucky ones go.
Might be worth giving that a try with yours since you're the platform test mule lol
      09-29-2017, 12:50 PM   #37
granjef3
Drives: 2014 M5 Competition
could you PM that to me? Or if possible post it up for everyone.
      09-29-2017, 10:36 PM   #38
allmotor_2000
1090
Too big to post but can email!
      01-19-2018, 05:57 PM   #39
V8munro
V8munro's Avatar
49
Drives: F10 M5 Sakhir Orange
Everynight i am hunting through pages of dct threads. Had ssp spec r clutch fitted 9weeks ago and car never made it out the workshop. Car is throwing a high pressure fault on clutch 2. Does this when selecting reverse, sometimes (30% going first to second and always going 2nd to first) doesnt actually shift to first either. Gearbox software has been updated. Clutch install and c clips have been checked multiple times. Kris has cleaned the mechatronics unit, car went through the gears before adaptions were done and completed adapations successfully. I have a jb4 (was set to diagnostic map 4) and i have a flash tune. Going to try flashing car to stock and after that seems i may be needing to install another box. Using new bmw oil and filter since mechatronics was sent back. Im reading about clutch line pressure beig affected by flashes or jb4 and im seeing alot about these rod errors. Only case of high pressure i could find also had rod error and turned out to be c clips mixed up. I cant find any cases matching my issues. Never had any issues with box previous to this.
      01-19-2018, 06:16 PM   #40
allmotor_2000
1090
I would replace the valve body assembly. Mechatronics is unlikely to be the cause as it is mostly a bunch for sensors.
      01-19-2018, 06:36 PM   #41
V8munro
V8munro's Avatar
49
Thanks for reply i was tempted to message you but dont really know you to be bombarding your inbox with questions. The valve assembly is what kris cleaned for me said it looked really clean (car has alot of miles as well 50k) guess its not just a case of cleaning and when they fail thats it. Secondhand box for its valve assembly seems to be the likely fix.
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
      01-20-2018, 09:10 AM   #42
steeve13m
61
Drives: F10 M5
I also have the rod shift error but only when I shift manual mode....on auto dct never had the issue.....i just smoked my dodson superstock clutch so I am on the market for a new one
      01-20-2018, 10:31 AM   #43
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Dodson just released a new line with more clutches for our DCT which is supposed to hold more power the SSP and be as smooth. The old ones made the car drive like shit. Know one guy who has them on his car right now and said they drive like stock. However, the SSP spec R with baskets is what I have and can say they are proven to work well.
      01-20-2018, 04:16 PM   #44
ARC550
Ssp Or nothing!
Also if you have the 5-7 gear rod.. it's not your clutch lol.. it's your trans.
m5post
